楼主: ZZXXQQ
[讨论]为何求图元外框程序对SPLINE曲线有误差?
发表于 2012-2-18 18:30:16 | 显示全部楼层
呵呵,确实是数学问题。QJCHEN和highflybird应该能解决
发表于 2012-2-18 20:21:36 | 显示全部楼层
Spline的最小包围框可以通过精度拟合逼近!
下面是我的求任何物体的最小包围框通用函数:
  1. ;;;(gxl-GetRealBox e1 d) 获取物体真实实体外矩形框,d为拟合逼近Spline最小长度
  2. ;;参数 e1 图元名或Vla对象 d = Spline最小拟合间距
  3. (defun gxl-GetRealBox  (E1 D / OBJ MINPOINT MAXPOINT DD PTS LEN)
  4.   (if (= 'ENAME (type e1))
  5.     (setq obj (vlax-ename->vla-object e1)) ;_ 转换图元名
  6.     (setq obj e1)
  7.     )
  8.   (cond        ((= "AcDbSpline" (vla-get-ObjectName obj))
  9.           (setq        len (vlax-curve-getDistAtParam
  10.                       obj
  11.                       (vlax-curve-getEndParam obj))
  12.                 )
  13.           (if (or (equal d 0 1e-6)
  14.                   (> (/ len d) 1000)
  15.                   )
  16.             (setq d (/ len 1000.))
  17.             )
  18.           (setq        dd  d
  19.                 pts (list (vlax-curve-getStartPoint obj))
  20.                                )
  21.           (while (< dd len)
  22.             (setq pts (cons (vlax-curve-getPointAtDist obj dd) pts)
  23.                   dd  (+ dd d)
  24.                   )
  25.             )
  26.           (cons (vlax-curve-getendPoint obj) pts)
  27.           (list        (apply 'mapcar (cons 'min pts))
  28.                 (apply 'mapcar (cons 'max pts)))
  29.           )
  30.         (t
  31.          (vla-GetBoundingBox obj 'minpoint 'maxpoint) ;_ 取得包容图元的最大点和最小点
  32.          (setq minpoint (vlax-safearray->list minpoint)) ;_ 把变体数据转化为表
  33.          (setq maxpoint (vlax-safearray->list maxpoint)) ;_ 把变体数据转化为表
  34.          (list minpoint maxpoint)
  35.          )
  36.         )
  37.   )
参与人数 1明经币 +3 金钱 +30 收起 理由
ZZXXQQ + 3 + 30 赞一个!
发表于 2012-2-18 22:37:15 | 显示全部楼层
;我做了修改
(DEFUN C:waik ()
(vl-load-com)
(SETVAR "CMDECHO" 0)
(SETQ OLDOS (GETVAR "OSMODE"))
(IF (SETQ S1 (CAR (ENTSEL "\nSelect One Object 选择一个图元 :"))) (PROGN
  (vla-getboundingbox (vlax-ename->vla-object S1) 'minpoint 'maxpoint)
  (setq pmax (vlax-safearray->list maxpoint)
        pmin (vlax-safearray->list minpoint))
   (setq bk1 (- 10 (car pmin))
         bk2 (- 10 (cadr pmin))
         bk3 (+ 10 (car pmax))
         bk4 (+ 10 (cadr pmax)))
    (setq pmin (list bk1 bk2))
    (setq pmax (list bk3 bk4))
  (SETVAR "OSMODE" 0)
  (COMMAND ".RECTANG" PMIN PMAX)
  (SETVAR "OSMODE" OLDOS)
(SETVAR "CMDECHO" 1)
(PRINC)
为何左下角的坐标偏移10有问题啊。
发表于 2013-4-9 14:33:21 | 显示全部楼层
请问如何才能多选呀
GMT+8, 2025-12-18 09:52 , Processed in 0.162203 second(s), 20 queries , Gzip On.
