查看: 1472|回复: 2
能否新建一个菜单条?
发表于 2008-1-8 11:04:00 | 显示全部楼层 |阅读模式
如题,如何创建菜单条
发表于 2008-1-8 21:43:00 | 显示全部楼层
可以编辑acad.mns文件,也可以在cad工具条处右击,在弹出的对话框中,拖动一个命令到工具栏处。
发表于 2008-1-8 23:51:00 | 显示全部楼层
Sub addmenu()
Dim currMenuGroup As AcadMenuGroup
Dim newMenu As AcadPopupMenu
On Error Resume Next
'建立新菜单
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
Set newMenu = currMenuGroup.Menus.Add("custom_menu")
'增加菜单项
Dim newMenuitem As AcadPopupMenuItem
Dim Macrostr(4) As String
Macrostr(1) = Chr(3) & Chr(3) & Chr(95) & "-vbarun ""aaa.dvb!ddd""" & Chr(32)
Macrostr(2) = Chr(3) & Chr(3) & Chr(95) & "-vbarun ""bbb.dvb!eee""" & Chr(32)
Macrostr(3) = Chr(3) & Chr(3) & Chr(95) & "-vbarun ""ccc.dvb!fff""" & Chr(32)
Macrostr(4) = Chr(3) & Chr(3) & "(startapp " & Chr(34) & "ggg.exe" & Chr(34) & ")" & Chr(13)
Set newMenuitem = newMenu.AddMenuItem(newMenu.Count + 1, "菜单一", Macrostr(1))
newMenuitem.HelpString = "菜单一"  ' 为菜单项增加状态栏帮助
Set newMenuitem = newMenu.AddMenuItem(newMenu.Count + 1, "菜单二", Macrostr(2))
newMenuitem.HelpString = "菜单二"
Set newMenuitem = newMenu.AddMenuItem(newMenu.Count + 1, "菜单三", Macrostr(3))
newMenuitem.HelpString = "菜单三"
Set newMenuitem = newMenu.AddSeparator(3)   '菜单分隔符
Set newMenuitem = newMenu.AddMenuItem(newMenu.Count + 1, "菜单四", Macrostr(4))
newMenuitem.HelpString = "******制作"
If Err.Number Then Err.Clear
'菜单条上显示菜单
currMenuGroup.Menus.InsertMenuInMenuBar "custom_menu", 8
End Sub
西北凡人------http://www.abofanyi.com/blog
GMT+8, 2026-1-5 09:41 , Processed in 0.166609 second(s), 23 queries , Gzip On.
