楼主: toply13
询问读取文本文件内容的方法(lisp编程)
发表于 2010-10-25 20:54:00 | 显示全部楼层
唉 看不到啊 赶紧发帖
发表于 2010-10-26 07:33:00 | 显示全部楼层
   谢谢版主
下载来学习研究一下。
或许能利用的上
谢谢
 不知道读取什么文件?
试了几个文件都显示出现有误:
C:TT
命令:  HELP
命令: tt ; 错误: 参数类型错误: stringp 1
命令:
命令:  TT ; 错误: 参数类型错误: stringp 1
命令:
命令:
命令:
  望得到指教。
在此先谢了
发表于 2010-10-26 19:36:00 | 显示全部楼层
看看,学习一下了。
发表于 2010-10-27 13:03:00 | 显示全部楼层
可以定义一个函数,将带,或空格等符号的字符串转为一个LST。比如
STR="2,23234,4554"
执行一个命令(str->lst str)就等到 (2 23234 4554)这样用起来就很方便了。不用SUBSTR.
(defun String->list (Strs / P TMP_LIST TMP_STR)
  (while (vl-string-search "\t" strs)
    (setq strs (vl-string-subst " " "\t" strs))
  (while (vl-string-search "," strs)
    (setq strs (vl-string-subst " " "," strs))
  (while (vl-string-search ";" strs)
    (setq strs (vl-string-subst " " ";" strs))
  (while (vl-string-search "  " strs)
    (setq strs (vl-string-subst " " "  " strs))
  (if (read strs)
      (setq tmp_list '())
      (while (setq p (vl-string-search " " strs))
 (setq tmp_str (substr strs 1 p))
 (if (Read tmp_str)
   (setq tmp_list (cons tmp_str tmp_list))
 (setq strs (vl-string-subst "" (substr strs 1 (1+ p)) strs))
      (if (Read strs)
 (setq tmp_list (cons strs tmp_list))
      (setq tmp_list (reverse tmp_list))
发表于 2010-10-31 14:40:00 | 显示全部楼层
谢谢了
发表于 2010-10-31 18:30:00 | 显示全部楼层
学习学习,为什么我使用时不带路径,就找不到文件呢
发表于 2010-10-31 22:44:00 | 显示全部楼层
使用DOSLIB函式库之DOS_STRTOKENS函数将字串转成串列较为简捷,但须依CAD版别载入DOSLIB函式库
假设有一个文本档案为aaa.txt,文件内容如下: 1,2133,4645 2,123123,4564
读取后串列资料为 ALAN_S=' ("1,2133,4645" "2,123123,4564")
(DEFUN C:ALAN (/ ALAN_S ITEMLIST NUM A B)
  (LOAD_DOSLIB)
  (SETQ ALAN_S '("1,2133,4645" "2,123123,4564") ITEMLIST '() NUM 0)
   (REPEAT (LENGTH ALAN_S)
     (SETQ ITEMLIST (APPEND ITEMLIST (LIST (DOS_STRTOKENS (NTH NUM ALAN_S) ","))))
     (SETQ NUM (+ NUM 1))
   (SETQ A (NTH 0 (NTH 1 ITEMLIST)) B (NTH 2 (NTH 1 ITEMLIST)))
 (DEFUN LOAD_DOSLIB (/ AC_VER);←依CAD版别载入DOSLIB函式库
   (SETQ AC_VER (SUBSTR (GETVAR "ACADVER") 1 2))
   (IF (NOT DOS_DRIVE)
        (PROGN
         (COND ((AND (= AC_VER "13")(WCMATCH (STRCASE (GETVAR "PLATFORM")) "*DOS*"))
                     (XLOAD "DOSLIB13")
                    ((= AC_VER "12")(XLOAD "DOSLIB12"))
                    (T (ARXLOAD (STRCAT "DOSLIB" AC_VER)))
 (PRINC "\nALAN 程式已载入 !")(PRINC "\n")
 (PROMPT "----------------------------<< C:ALAN >>------------------------------\n") (PRINC)
上网搜寻DOSLIB就可下载
发表于 2010-11-1 00:14:00 | 显示全部楼层
版主的这句似乎有错:
(while (/= (setq s (substr i 2)) ",")
  •    (setq tmp (strcat tmp (substr s 1 1)) i (1+ i))
    (while (/= (setq s (substr s2 i 2)) ",")
       (setq tmp (strcat tmp (substr s2 i 1)) i (1+ i))
    发表于 2010-11-1 13:03:00 | 显示全部楼层
    先收藏了,以后会用上!!
    发表于 2010-11-1 17:11:00 | 显示全部楼层
    看看,学习了
    GMT+8, 2026-1-15 17:25 , Processed in 0.168399 second(s), 19 queries , Gzip On.
