楼主: 87282374
[求助]关于lisp中command调用scale命令的问题!
发表于 2008-5-24 09:03:00 | 显示全部楼层
看了半天主要想改块的比例?利用vla-put-XScaleFactor,vla-put-YScaleFactor,vla-put-ZScaleFactor不就可以了???为什么一定要用scale命令?
 楼主| 发表于 2008-5-24 12:04:00 | 显示全部楼层
问题已解决!谢谢个位提供的帮助!!
  1. (defun c:tykb (/      a1     a0        a1e       a1n      szj     str0    ssa1
  2.            sn     n         a1on   ne       na1e      roscal xscale    yscale
  3.            yscale cmd
  4.           )
  5.   (setq    a1   (entsel "请选择图块:")
  6.     a0   (car a1)
  7.     a1e  (entget a0)
  8.     a1n  (assoc 2 a1e)
  9.     na1e (assoc 50 a1e)
  10.     ax   (assoc 41 a1e)
  11.     cmd  (getvar "cmdecho")
  12.     szj  (ssadd a0)
  13.   )
  14.   (Setq    str0 (getreal "\n请输入要缩放块的比例: ")
  15.   )
  16.   (setq roscal (strcat "\n比例因子为:" (rtos str0)))
  17.   (setq    ssa1 (ssget "x" (list a1n))
  18.     sn   (sslength ssa1)
  19.   )
  20.   (sssetfirst ssa1 szj)
  21.   (princ (strcat "\n您选择的块名为:"
  22.          (cdr a1n)
  23.          "; 共有 "
  24.          (itoa sn)
  25.          "个。 "
  26.          "旋转角度为: "
  27.          (angtos (cdr na1e))
  28.          "   比例因子为: "
  29.          (rtos (cdr ax))
  30.      )
  31.   )
  32.   (princ "\n")
  33.   (princ)
  34.   (setq n 0)
  35.   (repeat sn
  36.     (progn
  37.       (setq a1on (ssname ssa1 n)
  38.       )
  39.       (setq a1on (vlax-ename->vla-object a1on))
  40.       (setq xscale (vla-get-xscalefactor a1on)
  41.         yscale (vla-get-yscalefactor a1on)
  42.         zscale (vla-get-zscalefactor a1on)
  43.       )
  44.       (princ "\n*******")
  45.       (if (> xscale 0)
  46.     (setq xscale str0)
  47.     (setq xscale (- str0))
  48.       )
  49.       (if (> yscale 0)
  50.     (setq yscale str0)
  51.     (setq yscale (- str0))
  52.       )
  53.       (vla-put-xscalefactor a1on xscale)
  54.       (vla-put-yscalefactor a1on yscale)
  55.       (vla-put-zscalefactor a1on zscale)
  56.     )
  57.     (setq n (1+ n))
  58.   )
  59.   (sssetfirst nil nil)
  60.   (setvar "cmdecho" cmd)
  61.   (alert (strcat "您选择的块名为:"
  62.          (cdr a1n)
  63.          "; \n共有 "
  64.          (itoa n)
  65.          " 个 \n被改变为  "
  66.          roscal
  67.      )
  68.   )
  69.   (princ)
  70. )
GMT+8, 2026-1-20 05:15 , Processed in 0.265352 second(s), 19 queries , Gzip On.
