楼主: userzhl
[求助]在非世界坐标中插入文字出错了,求助高手,帮忙解决一下。
 楼主| 发表于 2008-8-30 22:49:00 | 显示全部楼层
真是郁闷,解决不了.
发表于 2008-8-31 01:56:00 | 显示全部楼层
发表于 2008-8-31 09:18:00 | 显示全部楼层
发表于 2008-8-31 23:55:00 | 显示全部楼层
请再再试一下!
(defun c:qqqq_1()
   (if (not (tblsearch "layer" "cen"))
       (command "_.layer" "_new" "cen" "_color" "1" "cen" "_ltype" "center" "cen" "")
   (command "layer" "s" "cen" "")
   (if (not (tblsearch "UCS" "NNN"))
       (command "ucs" "S" "NNN")
   (command "ucs" "v")
(setq in (getpoint "\n 请选择文字位置:"))
(if in
  (if (> (cdr(assoc 40 (tblsearch "STYLE" (getvar "TEXTSTYLE")))) 0)
   (command ".TEXT" in "" "插入文字测试")
   (command ".TEXT" in "5" "" "插入文字测试")
(command "ucs" "R" "NNN")
(command "ucs" "D" "NNN")
(prin1)
 楼主| 发表于 2008-9-1 08:13:00 | 显示全部楼层
问题已搞定,非常感谢yoyohosailorcwxZZXXQQ以及各路高手的关注
GMT+8, 2025-12-18 07:12 , Processed in 0.157929 second(s), 21 queries , Gzip On.
