查看: 1433|回复: 1
[求助]属性文字怎么修改不成功?
发表于 2008-9-28 12:20:00 | 显示全部楼层 |阅读模式
(setq mydoc (vla-get-activedocument(vlax-get-acad-object)))
(setq blks (vla-get-blocks mydoc))
(setq blk (vla-item blks "TITLE"))
(setq go t i 0)
(while go
     (setq typ(vla-get-objectname(setq obname(vla-item blk i))))
     ;(print typ)
     (cond
       ((equal "AcDbAttributeDefinition" typ)
       (setq j 0)
       (setq tag (vla-get-tagstring obname))
    ;(print (vlax-dump-object obname t))
       (repeat (vl-list-length sign_list)
            (if (equal tag (nth j sign_list))
        ;(print (vla-get-textstring obname))
               (vla-put-textstring obname "11111");修改成功但是图面上就是没有更新
        ;(print tag)
         ;(print (vlax-dump-object obname t));已经变了
        (vla-update obname)
            (setq j (1+ j))
     (setq i (1+ i))
     (if (= i (vla-get-count blk))(setq go nil))
     (setq i (1+ i))
(entupd blk)
GMT+8, 2026-1-16 10:08 , Processed in 1.128502 second(s), 25 queries , Gzip On.
