程序类似黑箱,从这头送个东西作原料,那头送出我们想要的东西 (成品)
您只须依您上传的图形截个部分图面应该就够了
1(setq n (vl-string-search "/" text) ) 求出 /出现的序号
2 (setq newstr (substr (+ n 2) 3)
3 vla-put-textstring 把文字改成 10m即可
按照楼上的写的编进去好象没成功啊.我把文件上传了.就和图中一样
通配符是****dB/####m(暗装)
需要得到的结果是把所有文字只保留####部分
能不能帮我写个完整的vlisp式子 ...
Andyhon发表于2008-10-30 16:27:00Command: (vl-string->list \"/\")(47)Command: (vl-list->string (cdr (member 47 (vl-string->list \"0.4dB/5m\"))))\"5m\"
向你学习了,Andyhon...
练练手...
(defun c:tt (/ /*m elist ename i ss v1) (setq echo (getvar "cmdecho")) (setvar "cmdecho" 0) (command "._undo" "_begin") (if (setq ss (ssget '((0 . "*TEXT*") (1 . "*dB/*m(暗装)")))) (progn (setq i 0) (while (< i (sslength ss)) (setq ename (ssname ss i)) (setq elist (entget ename)) (setq v1 (cdr (assoc 1 elist))) (setq /*m (vl-list->string (cdr (member 47 (vl-string->list v1))) ) ) (setq /*m (vl-string-right-trim "m(暗装)" /*m)) (entmod (subst (cons 1 /*m) (assoc 1 elist) elist ) ) (entupd ename) (setq i (1+ i)) ) ) ) (command "._undo" "_end") (setvar "cmdecho" echo) (princ))
ygp820601 发表于 2011-8-17 20:47 (defun c:tt(/ regex s seltext i objtext oldtext) (princ "\n明经通道文本模糊替换示例--将S3*A替换为 ...
YAOSHIWEI 发表于 2012-5-31 20:25 (vlax-put-property regex "Pattern" "(.{5,})/(.{1,})m(.{4,})") (setq s(vlax-invoke-method ...
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2025-12-17 21:53 , Processed in 0.191410 second(s), 20 queries , Gzip On.
