查看: 1344|回复: 9
[求助]急急急,哪位高手帮帮忙看看这段程序,为何在CAD2008和2009中运行不了,在视
发表于 2008-12-10 17:45:00 | 显示全部楼层 |阅读模式
[求助]急急急,哪位高手帮帮忙看看这段程序,为何在CAD2008和2009中运行不了,在视口内操作也会出错。[br]
(defun NB_makeblock (sset baspoint   name          /
             blkobj    activespace          BlockDef
             blocks    sArray       idx          doc
             vla-objects       regen_flag errorsave
  (setq errorsave *error*)
  (defun *error* (msg)
    (setq *error* errorsave)
  (setq baspoint (trans baspoint 1 0))
  (setq    doc    (vla-get-activedocument (vlax-get-acad-object))
    blocks (vla-get-blocks doc)
  (setq    activespace
     (cond ((= (vla-get-activespace doc) 1) (vla-get-modelspace doc))
           ((= (vla-get-activespace doc) 0) (vla-get-paperspace doc))
  (setq    vla-objects
    idx -1
    regen_flag
     nil
    self_ref nil
  (repeat (sslength sset)
    (setq vla-objects
       (append vla-objects
           (list
             (vlax-ename->vla-object (ssname sset (setq idx (1+ idx))))
  (if (not (vl-catch-all-error-p
         (vl-catch-all-apply 'vla-item (list blocks name))
      (initget 1 "Yes No")
      (if
    (= (getkword
         (strcat "\n" name "已定义。是否重定义? (Yes or No) ")
       "Yes"
       (if
         (apply
           'or
           (mapcar
         '(lambda (x)
            (and (= (vla-get-objectname x) "AcDbBlockReference")
             (= (vla-get-name x) name)
         vla-objects
          (progn (princ (strcat "\n" name "自参照。建块失败。"))
             (exit)
       (setq regen_flag T)
       (setq BlockDef (vla-item blocks name))
       (vlax-for itm BlockDef
         (vla-delete itm)
       (princ "\n函数被取消")
       (exit)
  (foreach itm vla-objects
    (vla-move itm
          (vlax-3d-point baspoint)
          (vlax-3d-point '(0 0 0))
  (setq
    blkobj (vla-add blocks (vlax-3d-point '(0 0 0)) name)
    sArray
       (vlax-safearray-fill
         (vlax-make-safearray
           vlax-vbObject
           (cons 0 (1- (length vla-objects)))
         vla-objects
  (vla-copyobjects doc sArray blkobj)
  (mapcar 'vla-delete vla-objects)
  (if regen_flag
    (vla-regen doc acAllViewports)
  (vla-insertblock
    activespace
    (vla-get-name blkobj)
    1
    1
    1
    0
 ;;返回块名
 (CDR (ASSOC 2 (ENTGET (vlax-vla-object->ename blkobj))))
这是一个制作图块的功能,我觉得非常的好用。
急急急,哪位高手帮帮忙!!!
 楼主| 发表于 2008-12-10 21:03:00 | 显示全部楼层
哪位高手关注一下呀。
 楼主| 发表于 2008-12-11 09:27:00 | 显示全部楼层
版主,请关注一下呀。
发表于 2008-12-11 09:39:00 | 显示全部楼层
我在cad2009测试没问题
 楼主| 发表于 2008-12-11 14:16:00 | 显示全部楼层
在视口内操作不行!!!
 楼主| 发表于 2008-12-12 00:04:00 | 显示全部楼层
在视口内操作不行!!!
 楼主| 发表于 2008-12-12 00:46:00 | 显示全部楼层
这是一个“给定选择集创建块或者匿名块”的程序。
 楼主| 发表于 2008-12-12 00:59:00 | 显示全部楼层
(NB_makeblock <选择集> pt <"块名"> )
发表于 2008-12-12 08:52:00 | 显示全部楼层
问题出在这里
(setq    activespace
改为
  (if (and (= (vla-get-activespace doc) 0)
           (= (getvar "cvport") 2))
    (setq activespace (vla-get-paperspace doc))
    (setq activespace (vla-get-modelspace doc))
 楼主| 发表于 2008-12-12 13:44:00 | 显示全部楼层
非常感谢caoyin!!!
GMT+8, 2025-7-30 05:38 , Processed in 0.210287 second(s), 26 queries , Gzip On.
