楼主: nonsmall
[求助] 这个字符串怎么eval 值?
发表于 2009-1-5 22:11:00 | 显示全部楼层
nonsmall发表于2009-1-5 18:16:00精简一下(setq str \"\\"(setq a (strcat \\"\\"new\\"\\" \\"\\"disk\\"\\" \\"\\"d:\\\\\\"\\"))\\"\")(while (/= str (setq str (vl-string-subst \"@\" \"\\"\\"\" str))))(while (/= str
另辟蹊径,一个函数6行代码包打无限多重字符化的表达式求值
$eval = 执行多次字符化的表达式字符串 ----- by 狂刀 2009.1.6
(setq str "\"(setq a (strcat \"\"new\"\" \"\"disk\"\" \"\"d:\\\\\"\"))\"")
($eval str)
-> "newdiskd:\\"
(vl-prin1-to-string str)
-> "\"\\\"(setq a (strcat \\\"\\\"new\\\"\\\" \\\"\\\"disk\\\"\\\" \\\"\\\"d:\\\\\\\\\\\"\\\"))\\\"\""
($eval (vl-prin1-to-string (vl-prin1-to-string str)))
-> "newdiskd:\\"
(vl-prin1-to-string (vl-prin1-to-string (vl-prin1-to-string (vl-prin1-to-string str))))
->"\"\\\"\\\\\\\"\\\\\\\\\\\\\\\"\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"(setq a (strcat \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"new\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\" \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"disk\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\" \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"d:\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"))\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\"\\\\\\\\\\\\\\\"\\\\\\\"\\\"\""
($eval (vl-prin1-to-string (vl-prin1-to-string (vl-prin1-to-string (vl-prin1-to-string str)))))
-> "newdiskd:\\"
 楼主| 发表于 2009-1-6 09:17:00 | 显示全部楼层
vl-prin1-to-string逆运算函数 收了
GMT+8, 2025-12-18 07:52 , Processed in 0.154053 second(s), 20 queries , Gzip On.
