http://www.experts-exchange.com/Applications/CAD/Q_21731171.html Sub VTC() 'short for SystemVariableToClipboard toClipboard End Sub Sub toClipboard() 'short for SystemVariableToClipboard Dim objectList As New DataObject Dim param As String Dim parameterArray() As String Dim ref As String parameterArray() = Split(ThisDrawing.Utility.GetString(False), " ") For i = 0 To UBound(parameterArray) ref = ref & getSysVar(parameterArray(i)) If UBound(parameterArray) > 0 Then ref = ref & vbNewLine Next i objectList.SetText ref objectList.PutInClipboard End Sub Private Function getSysVar(varName As String) As String Dim SysVar As String Dim i As Integer On Error Resume Next SysVar = ThisDrawing.GetVariable(varName) If Err <> 0 Then Err.Clear SysVar = varName ElseIf varName = "DWGNAME" Then 'REMOVE DRAWING FILE EXTENSIOIN IE '.dwg' Do If Mid(SysVar, Len(SysVar) - i, 1) = "." Then SysVar = Left(SysVar, Len(SysVar) - i - 1) i = Len(SysVar) Else i = i + 1 End If Loop While i < Len(SysVar) End If getSysVar = SysVar End Function Sub tt1() Dim a As New DataObject a.SetText "ABC" a.PutInClipboard End Sub Sub tt2() Dim a As New DataObject a.GetFromClipboard MsgBox a.GetText End Sub
