楼主: 3527188
[求助]版主高手请进~自动线性标注
发表于 2011-1-5 22:32:00 | 显示全部楼层
       写好了一个,想请   ZZXXQQ  版主帮完善下
1,    交互输入时点左键 能退出程序
2,   想做6楼的效果还没有实现
;对象长宽标注 明经 ZZXXQQ 2009.1.8
(defun c:quickdimension1(/ dimtx minx0 miny0 maxx0 maxy0 ss end end_data i p1 p2 p3 p4 P5 p6
    keyh p7 p8 p9 p10)
(vl-load-com)
(command "undo" "be")
(setvar "cmdecho" 0)
  (setq keyh nil)
  (setq dimtx (getvar "dimtxt"))
(command "ucs" "w")
(if (and (princ "\nSelect object to dim :") (setq ss (ssget))) (progn
  (setq minx0 1e6 miny0 1e6 maxx0 -1e6 maxy0 -1e6)
  (setq i 0)
  (repeat (sslength ss)
   (setq end (ssname ss i))
   (setq end_data (entget end))
   (Min_Max)
   (setq i(1+ i))
  );end repeat
  (setq p1 (list minx0 miny0)    p2 (list minx0 maxy0)
        p3 (list maxx0 maxy0)    p4 (list maxx0 miny0))
  (autodrawline)
  (command "DIMLINEAR" "non" p1 "non" p2 "non" (polar p2 pi p5))
  (command "DIMLINEAR" "non" p1 "non" p4 "non" (setq p6 (polar p4 (/ pi -2) p5)))
    (princ "\n Please give height ...default<25>:")
    (if (= (car (grread)) 3) (exit))
    (if (= keyh nil) (setq keyh 25))
    (setq p7 (list minx0 (- miny0 p5 (* 8 dimtx))))
    (setq p8 (list maxx0 (- miny0 p5 (* 8 dimtx))))
    (setq p9 (list maxx0 (- (- miny0 p5 (* 8 dimtx)) keyh)))
    (setq p10 (list minx0 (- (- miny0 p5 (* 8 dimtx)) keyh)))
    (vl-cmdf "line" p7 p8 p9 p10 p7 "")
  (command "DIMLINEAR" "non" p7 "non" p10 "non" (polar p2 pi p5))
  (command "undo" "e")
;;;子程序,求选集是大外形坐标
(defun Min_Max(/ minx maxx miny maxy)
(vla-getboundingbox(vlax-ename->vla-object end) 'minp 'maxp)
(setq minp (vlax-safearray->list minp)
       maxp (vlax-safearray->list maxp))
(setq minx (car minp)
       maxx (car maxp)
       miny (cadr minp)
       maxy (cadr maxp))
(if (> minx0 minx) (setq minx0 minx))
(if (> miny0 miny) (setq miny0 miny))
(if (< maxx0 maxx) (setq maxx0 maxx))
(if (< maxy0 maxy) (setq maxy0 maxy))
;;  defun grread
(defun ZML-GRREAD (LST / test tmp mode val tmp2)
    (setq TEST t)
    (while TEST
(setq TMP  (grread 2)
       MODE (car TMP)
       val  (cadr tmp)
(cond ((= mode 2)
        (if (and (setq TMP2 (assoc mode LST))
   (setq tmp2 (cdr tmp2))
   (setq tmp2 (assoc val tmp2))
     (eval (cons 'progn (cdr TMP2)))
       );row end
       ((setq TMP2 (assoc MODE LST))
       (t (princ tmp))
;;;;;;;;;;;;;auto draw line
(defun autodrawline(/ SS lst PT PT0)
     (setq LST
       (list '(5
        (setq pt val)
        (redraw)
        (grdraw PT p1 3)
      ;;left press
       (3
        (setq pt val)
(setq p5 (distance PT p1))
        (redraw)
        (setq TEST NIL)
      '(25
        (redraw)
        (setq TEST NIL)
      '(11
        (redraw)
        (setq TEST NIL)
     (ZML-GRREAD lst)
在cad2005 下调试通过
发表于 2011-1-6 22:49:17 | 显示全部楼层
      自已顶起
发表于 2011-4-20 23:11:36 | 显示全部楼层
期待热心人士出现,非常需要,最好在加个批量标注
发表于 2011-4-21 02:57:51 | 显示全部楼层
常用到的标注外形,关注中。。。
发表于 2011-4-21 07:05:25 | 显示全部楼层
发表于 2011-4-21 10:53:47 | 显示全部楼层
回复 xyp1964 的帖子
院长的高招!可以发一个上来吗?
发表于 2011-4-21 11:26:44 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-4-21 12:32:34 | 显示全部楼层
         恳切希望院长发个程式上来大家学习下,
  顶起
发表于 2011-4-21 12:34:30 | 显示全部楼层
          15楼高手,请出实用的招
发表于 2011-5-5 12:30:47 | 显示全部楼层
          院长,大侠
GMT+8, 2026-1-2 02:25 , Processed in 0.163290 second(s), 19 queries , Gzip On.
