用下面的代码把当前图纸中所有的图形复制到一张新建dwg中,其他图形都是好的,就是标注没有复制过去 Sub main() Dim doc1 As AcadDocument, doc2 As Object Dim ssetObj As AcadSelectionSet Dim objCollection() As Object Set doc1 = Application.ActiveDocument Set ssetObj = doc1.ActiveSelectionSet ssetObj.Select acSelectionSetAll If ssetObj.Count > 0 Then ReDim objCollection(ssetObj.Count - 1) As Object For k = 0 To ssetObj.Count - 1 Set objCollection(k) = ssetObj(k) Next k Set doc2 = Documents.Add doc1.CopyObjects objCollection, doc2.ModelSpace End If End Sub
