请龙龙仔看看这程式,lisp程式程式不能运行 (VMON) (DEFUN C SEC1 (/ s1 ba1 l mm un ss1 chk ap3 ap4 layold) (CHECK1) (setq layold la) (setq mm m xxyy nil s1 nil chkxpline nil ) (setq ucsp (getvar "UCSORG")) (load_dcl "life171" "p_sec1") (if (= ga#1 nil) (setq ga#1 35.0) ) (if (= dtm_ nil) (setq dtm_ (getvar "DIMTXT")) ) (if (= #dec nil) (setq #dec 2) ) (if (= p_seclen nil) (setq p_seclen 22.0) ) (if (not p-sec12m0) (lifeload "145") ) (setq v1 (getvar "CLAYER")) (p-sec12pt v1) (if (= taper_046 nil) (setq taper_046 "N") ) (if (= dim_046 nil) (setq dim_046 "Y") ) (if (= cdim_046 nil) (setq cdim_046 "Y") ) (if (= call_046 nil) (setq call_046 "N") ) (if (/= wmark_046 "0") (setq wmark_046 "1") ) (if (= ta_046 nil) (setq ta_046 1.0) ) (if (= td_046 nil) (setq td_046 3.0) ) (if (= cc1_046s nil) (setq cc1_046s 1.0) ) (if (= hc1_046s nil) (setq hc1_046s 1.0) ) (set_tile "dg1" (rtos ga#1 2 1)) (set_tile "sl1" (rtos p_seclen 2 2)) (set_tile "th1" (rtos dtm_ 2 1)) (set_tile "dp1" (rtos #dec 2 0)) (set_tile "ta1" (rtos ta_046 2 2)) (set_tile "td1" (rtos td_046 2 2)) (set_tile "sc1" (rtos cc1_046s 2 2)) (set_tile "hc1" (rtos hc1_046s 2 2)) (set_tile "rw1" wmark_046) (if (= taper_046 "Y") (set_tile "taper" "1") (set_tile "taper" "0") ) (if (= call_046 "Y") (set_tile "call" "1") (set_tile "call" "0") ) (if (= dim_046 "Y") (set_tile "dim" "1") (set_tile "dim" "0") ) (if (= cdim_046 "Y") (set_tile "cdim" "1") (set_tile "cdim" "0") ) (if (or (= p_sec046 nil) (= p_sec046 "") ) (setq p_sec046 4) ) (cond ((= p_sec046 1) (set_tile "up" "1") ) ((= p_sec046 2) (set_tile "down" "1") ) ((= p_sec046 3) (set_tile "left" "1") ) ((= p_sec046 4) (set_tile "right" "1") ) (action_tile "sel_ha" "(setq chk (chk046)) (done_dialog 2)") (action_tile "sel_ob" "(setq chk (chk046)) (done_dialog 1)") (action_tile "cancel" "(done_dialog 0)") (setq ee2 (start_dialog)) (unload_dialog dd_id) (if (/= chk nil) (progns (if (= ee2 1) (progn ;;; (if (= life_v2004 "Y") (setq s1 (ssget '((0 . "ARC,CIRCLE,LINE,INSERT,LWPOLYLINE"))) ) (setq s1 (ssget '((0 . "ARC,CIRCLE,LINE,INSERT")))) ;;; ) ) ) (if (= ee2 2) (select_hatch_line046) ) (if (/= s1 nil) (progn (setq ss1 s1 ot p_seclen7 lay (cdr (assoc 8 (entget (ssname s1 0))) ) ) (snaphelp) (command "ucs" "w") (initget 1) (lifetype "Base point: " "基准点: " #a71_t02) (setq ba1 (getpoint)) (load_aeh_style) (setvar "blipmode" 0) (if (= life_ver "5") (setq un (getvar "LUPREC")) (setq un (getvar "DIMDEC")) ) (p-sec12pt lay) (if (/= ot p_seclen) (progn (lifetype "Section thick <" "侧视图厚度 <" #046_t04) (princ p_seclen) (setq l (getreal ">: ")) (if (/= l nil) (setq p_seclen l) ) ) ) (046MAIN) (setq se1 (getvar "DIMSE1") se2 (getvar "DIMSE2") ) (setvar "DIMSE1" 0) (setvar "DIMSE2" 0) (setq sca5 (getvar "dimscale")) (if (= dimscale_yn "Y") (setq dtm_ (* dtm_ sca5)) ) (if (or (= p_sec046 3) (= p_sec046 4) ) (PRRSEC3) (PDDSEC3) ) (if (/= ss1 nil) (p-sec12m0) ) (if (= dimscale_yn "Y") (setq dtm_ (/ dtm_ sca5)) ) (if (= taper_046 "Y") (sec_taper) ) (if (= call_046 "Y") (progn (if (not c:cut_line) (lifeload "147") ) (c:cut_line) ) ) (setvar "DIMSE1" se1) J (setvar "DIMSE2" se2) (if (= life_ver "5") (setvar "LUPREC" un) (setvar "DIMDEC" un) ) (command "layer" "s" layold "") (command "undo" "E") (check99) (setvar "osmode" mm) (command "ucs" "o" ucsp) (setq chk_punch 1) (setq fl1 (open (strcat life_path dieno ".tol") "a")) (setq k "chk_punch ") (out187 chk_punch) (close fl1) ) ) (setq #ll nil xxyy nil ap3 nil ap4 nil p2 nil pl nil pu nil cp1 nil cp2 nil cp4 nil cp3 nil lay nil ns nil p12 nil p23 nil p34 nil p14 nil st1 nil p1 nil p3 nil p3r nil p3l nil p0 nil p1234 nil fl1 nil cp1 nil cp2 nil nn nil cp4 nil cp5 nil s4 nil c0 nil c1 nil chkxpline nil ) ) ) ) ) (DEFUN PRRSEC3 (/ d1 d2 d3 d4 d41 d31 d52 qaa qa qa1 nn cp4 nn1 cla c0 c1 s s4 cp5 ap3 ap4 m1 ) (setq nn (length #ll) cp1 (cadar #ll) cp2 (cadr (nth (- nn 1) #ll)) ) (if (= life_v2004 "Y") (setq cp1 (cadr (nth 0 #ll)) cpd2 (car (last #ll)) ) ) (if (= p_sec046 4) (setq #00 0) (setq #00 #180) ) (046M1MM) (setq cp4 (polar cp3 #00 p_seclen) cp5 (polar cp3 (angle cp4 cp3) (* ga#1 0.3)) ) (command "osnap" "non") (setq la lay) (dash_lay) (setq ns nn) (while (/= nn 0) (setq p1 (cadr (nth (- nn 1) #ll)) c0 (nth (- nn 1) #ll) c0 (polar c0 #00 1.0) c1 (list (car cp5) p1) s (ssget "c" c0 c1) ) (if (/= s nil) (setq s4 (sslength s)) (setq s4 0) ) (if (or (= nn ns) (= nn 1) ) (setq s4 0) ) (setq pl (list (car cp3) p1) pr (list (car cp4) p1) ) (if (= s4 0) (command "layer" "s" lay "" "line" pl pr "") (progn (setq la lay) (dash_lay) (command "line" pl pr "") ) ) (setq nn (- nn 1)) ) (if (/= xxyy nil) (progn (command "layer" "t" "cen" "s" "cen" "") (setq nn1 (length xxyy) p1 (atof (nth m1 xxyy)) ap3 (polar cp3 (+ #00 #180) center_line) ap4 (polar cp4 #00 center_line) ) (while (< m1 nn1) (if (< m1 (- nn1 1)) (setq p2 (atof (nth (+ m1 1) xxyy))) ) (if (/= p2 p1) (progn (setq pl (list (car ap3) p1) pr (list (car ap4) p1) ) (command "line" pl pr "") (if (= nla nil) (setq cla "DASH") ) (if (= cla nil) (setq cla nla) ) $* (setq l (strlen nla)) (if (> l 4) (setq cla (strcat (substr nla 1 (- l 4)) "1")) ) (if (/= cla "DASH") (command "change" "l" "" "p" "la" cla "" "change" "l" "" "p" "lt" "center" "" ) ) ) ) (setq m1 (+ m1 1) p2 nil ) (if (< m1 nn1) (setq p1 (atof (nth m1 xxyy))) ) ) (command "layer" "s" lay "") ) ) (setq d1 (list (car cp3) cp2) d2 (polar d1 #00 p_seclen) d4 (list (car cp3) cp1) d3 (polar d4 #00 p_seclen) d51 (polar d4 #00 (/ p_seclen 2.)) d52 (polar d51 #90 (* dtm_ 1.5)) ’ d41 (polar d4 #90 2.) d31 (polar d3 #90 2.) p41 (polar d4 (angle d4 d1) (/ (distance d4 d1) 2.) ) p12 (polar d1 (angle d1 d2) (/ (distance d1 d2) 2.) ) p23 (polar d2 (angle d2 d3) (/ (distance d2 d3) 2.) ) p34 (polar d3 (angle d3 d4) (/ (distance d3 d4) 2.) ) ) (command "layer" "s" lay "" "line" d1 d4 "" "line" d2 d3 "") (if (> cc1_046s 0.1) (command "osnap" "non" "pedit" p34 "y" "j" p41 p12 p23 p34 "" "" "chamfer" "d" cc1_046s cc1_046s "chamfer" "P" "L" "explode" "L" ) ) (if (= dim_046 "Y") (prognoa (setq la lay) (ddim_lay) (command "dim" "hor" d4 d3 d52 "") (if (= p_sec046 3) (setq p0 d1) (setq p0 d2) ) ) ) (if (and (> cc1_046s 0.2) (= cdim_046 "Y") ) (progn (setq cc cc1_046s j0 (polar p0 pi cc) j1 (polar p0 #90 cc) j (polar j0 (angle j0 j1) (/ (distance j0 j1) 2.0) ) j0 (polar j #315 (* dtm_ 1.5)) j0 (polar j0 #45 (* dtm_ 0.5)) j1 (polar j #315 (* dtm_ 7.5)) aa (* dtm_ 0.8) i0 list_language ) (if (> cc (fix cc)) (setq n 1) (setq n 0) ) (cond ((= i0 "0") (setq ab0 "(㏄)")) ((= i0 "1") (setq ab0 #046_t03)) ((= i0 "2") (setq ab0 "(ALL)")) ) (setq str (strcat "C" (rtos cc 2 n) ab0)) (command "line" j j1 "" "text" j0 dtm_ 315 str "insert" "arrow1" j aa aa "315" ) (setq cc nil j0 nil j1 nil j nil aa nil str nil ) ) ) ) (DEFUN PDDSEC3 (/ lm d1 d2 d3 d11 d21 d52 qaa qa1 qa cp4 t0 nn1 c0 c1 s s4 m1 cx cy cp5 ns nn ) (setq t0 (getvar "DIMTIH") nn (length #ll) cp1 (cadar #ll) @ cp2 (cadr (nth (- nn 1) #ll)) ) (if (= life_v2004 "Y") (setq cp1 (car (nth 0 #ll)) cp2 (car (last #ll)) ) ) (if (= p_sec046 1) (setq #00 #90) (setq #00 #270) ) (046M1MM) (setq lm p_seclen) (setq cp4 (polar cp3 #00 lm) cp5 (polar cp3 (angle cp4 cp3) (* ga#1 0.3)) ) (command "osnap" "non") (setq la lay) (dash_lay) (setq ns nn) (while (/= nn 0) (setq p1 (cadr (nth (- nn 1) #ll)) c0 (nth (- nn 1) #ll) cx (car c0) cy (cadr c0) ) (if (= life_v2004 "Y") (setq c0 (list cx cy) p1 cx ) (setq c0 (list cy cx)) ) (setq c0 (polar c0 #00 1.0) c1 (list p1 (cadr cp5)) s (ssget "c" c0 c1) ) (if (/= s nil) (setq s4 (sslength s)) (setq s4 0) ) (if (or (= nn ns) (= nn 1) ) (setq s4 0) ) (setq pu (list p1 (cadr cp3)) pd (list p1 (cadr cp4)) ) (if (= s4 0) (progn (command "layer" "s" lay "" "line" pu pd "") ) (progn (setq la lay) (dash_lay) (command "line" pu pd "") ) ) (setq nn (- nn 1)) ) (if (/= xxyy nil) (progn (command "layer" "t" "cen" "s" "cen" "") (setq nn1 (length xxyy) p1 (atof (nth m1 xxyy)) ap3 (polar cp3 (+ #00 #180) center_line) ap4 (polar cp4 #00 center_line) ) (while (< m1 nn1) (if (< m1 (- nn1 1)) (setq p2 (atof (nth (+ m1 1) xxyy))) ) (if (/= p2 p1) (progn (setq pu (list p1 (cadr ap3)) pd (list p1 (cadr ap4)) ) (command "line" pu pd "") (if (= nla nil) (setq cla "DASH") ) (if (= cla nil) (setq cla nla) ) (setq l (strlen nla)) (if (> l 4) (setq cla (strcat (substr nla 1 (- l 4)) "1")) ) (if (/= cla "DASH") (command "change" "l" "" "p" "la" cla "" "change" "l" "" "p" "lt" "center" "" ) ) ) ) (setq m1 (+ m1 1) p2 nil ) (if (< m1 nn1) (setq p1 (atof (nth m1 xxyy))) ) ) (command "layer" "s" lay "") ) ) (setq d1 (list cp1 (cadr cp3)) d2 (polar d1 #00 lm) d4 (list cp2 (cadr cp3)) d3 (polar d4 #00 lm) d51 (polar d4 #00 (/ lm 2.)) d52 (polar d51 pi (* dtm_ 1.5)) p41 (polar d4 (angle d4 d1) (/ (distance d4 d1) 2.) ) p12 (polar d1 (angle d1 d2) (/ (distance d1 d2) 2.) ) p23 (polar d2 (angle d2 d3) (/ (distance d2 d3) 2.) p34 (polar d3 (angle d3 d4) (/ (distance d3 d4) 2.) ) ) (setvar "dimtih" 0) (command "layer" "s" lay "" "line" d1 d4 "" "line" d2 d3 "") (if (> cc1_046s 0.1) (command "osnap" "non" "pedit" p34 "y" "j" p41 p12 p23 p34 "" "" "chamfer" "d" cc1_046s cc1_046s "chamfer" "P" "L" "explode" "L" mc ) ) (if (= dim_046 "Y") (progn (setq la lay) (ddim_lay) (command "dim" "ver" d4 d3 d52 "") (if (= p_sec046 2) (setq p0 d1) (setq p0 d2) ) ) ) (if (and (> cc1_046s 0.2) (= cdim_046 "Y") ) (progn (setq cc cc1_046s j0 (polar p0 pi cc) j1 (polar p0 #270 cc) j (polar j0 (angle j0 j1) (/ (distance j0 j1) 2.0) ) j0 (polar j #45 (* dtm_ 1.5)) j0 (polar j0 #135 (* dtm_ 0.5)) j1 (polar j #45 (* dtm_ 7.5)) aa (* dtm_ 0.8) ) (if (> cc (fix cc)) (setq n 1) (setq n 0) ) (if (= list_language "0") (setq str (strcat "C" (rtos cc 2 n) "(㏄)")) (setq str (strcat "C" (rtos cc 2 n) "(ALL)")) ) (command "line" j j1 "" "text" j0 dtm_ 45 str "insert" "arrow1" j aa aa "45" ) (setq cc nil j0 nil j1 nil j nil aa nil str nil ) ) (setvar "dimtih" t0) ) ) ) (DEFUN 046M1MM (/ l) (if (= life_ver "5") (setvar "LUPREC" #dec) (setvar "DIMDEC" #dec) ) (cond ( (= p_sec046 4) (setq cp3 (list (+ (car ba1) ga#1) (cadr ba1))) ) ((= p_sec046 3) (setq cp3 (list (- (car ba1) ga#1) (cadr ba1))) ) ((= p_sec046 1) (setq cp3 (list (car ba1) (+ (cadr ba1) ga#1))) ) ((= p_sec046 2) (setq cp3 (list (car ba1) (- (cadr ba1) ga#1))) ) ) ) (DEFUN 046MAIN (/ fp string str t-1 ll n c0) (command "osnap" "non") (menucmd "S=X") (menucmd "S=AUTOF") (if (= life_ver "6") (progn (setq ss4 (ssadd) ll (sslength s1) n 0 ) (while (> ll n) tz (setq t-1 (cdr (assoc -1 (entget (ssname s1 n)))) c0 (cdr (assoc 0 (entget (ssname s1 n)))) ) (if (/= c0 "INSERT") (ssadd t-1 ss4) ) (setq n (+ n 1)) ) ) ) (if (/= life_v2004 "Y") (progn (setq fp (open (strcat life_path "out.dat") "w") #ll nil ) (if (or (= p_sec046 1) (= p_sec046 2)) (write-line (strcat "X " (rtos (cadr ba1) 2 2)) fp) (write-line (strcat "Y " (rtos (car ba1) 2 2)) fp) ) (write-line "QUA" fp) (close fp) (if (= life_ver "6") (command "dxfout" (strcat life_path "out") "V" "R12" "E" ss4 "" "16" ) (command "dxfout" (strcat life_path "out") "e" s1 "" "8") ) (if (not a_sort_nb) (cload (strcat life_exe "a_life")) ) (a_sort_nb) (setq fp (open (strcat life_path "in.dat") "r") string "" ) (while string (setq string (read-line fp)) (if (/= string nil) (progn (setq str (read (strcat "(" string ")"))) (if (or (= p_sec046 4) (= p_sec046 3) ) 折 (setq #ll (append #ll (list str))) (progn (setq str (list (cadr str) (car str))) (setq #ll (append #ll (list str))) ) ) ) ) ) (close fp) (if (= chkxpline "Y") (command "undo" "e" "u") ) ) (progn (setq p p_sec046) (cond ((= p 1) (setq b1 (polar ba1 #90 20)))
((= p 2) (setq b1 (polar ba1 #270 20 ) ) ) ((= p 3) (setq b1 (polar ba1 pi 20 ) ) ) ((= p 4) (setq b1 (polar ba1 0 20 ) ) ) ) (if (not lhj_xyaxis) (cload (strcat life_exe "a_elsp")) ) (if (or (= p_sec046 1) (= p_sec046 2) ) (setq xy "X") (setq xy "Y") ) (if (= xy "X") (setq x0 (cadr b1)) (setq x0 (car b1)) ) ) ) ) |
