楼主: userzhl
[求助]如何能设置标注点到标注线的距离?(禁止liminnet xchrimp跟贴)
 楼主| 发表于 2009-7-20 14:43:00 | 显示全部楼层
是呀,也是菜鸟一个,才刚学会搞菜单。。。总到网上忽悠人,还经常换马甲,最近好像又换成了xchrimp,还仿人家高手名字,让人总容易误会是xshrimp我在好多个群里的人都说他不地道,包括院长。
发表于 2009-7-20 16:24:00 | 显示全部楼层
userzhl发表于2009-7-19 21:47:00经过测试,有问题,当标注起点与标注线距离为0时,会有出错。
这也不能全怪人家,当起点和标注线距离为0时,用户必须提供一个距离和矢量,才能修改新的起点,所以给 AutoCAD 的数据一定要足够!!
通过组码10 13 14求 标注对象箭头位置是不科学的!!
发表于 2009-7-20 16:40:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-7-20 17:41:00 | 显示全部楼层
;;-已经修改
(defun c:TT (/ lt:dim-definingPoint ss i di en ent p13 p14 p1 p2 a p13@ p14@ p ang)
(defun lt:dim-definingPoint (edata / dxf typ p10 p13 p14 ang)
  (setq dxf (lambda (x) (cdr (assoc x edata)))
        typ (- (dxf 70) 32)
        p10 (dxf 10)
        p13 (dxf 13)
  (list (cond
          ((zerop typ)
           (setq ang (dxf 50) p13 (list (car p13) (cadr p13) (last p10)))
           (inters p10 (polar p10 ang 1) p13 (polar p13 (+ ang (/ pi 2)) 1) nil)
          ((= typ 1)
           (setq p14 (dxf 14) ang (if (equal p14 p13 1e-7) 0 (angle p14 p13)))
           (if (equal p10 p14 1e-7)
             p13
             (polar p10 ang (dxf 42))
        p10
(if (and (setq ss (ssget '((0 . "DIMENSION"))))
           (initget 7)
           (setq di (getdist "\n指定标注界限长度: "))
  (repeat (setq i (sslength ss))
    (setq en  (ssname ss (setq i (1- i)))
          ent (entget en)
          p13 (cdr (assoc 13 ent))
          p14 (cdr (assoc 14 ent))
    (mapcar 'set '(p1 p2) (lt:dim-definingPoint ent))
    (setq a    (+ (angle p1 p2) (/ pi 2))
          p13@ (inters p1 p2 p13 (polar p13 a 1) nil)
          p14@ (inters p1 p2 p14 (polar p14 a 1) nil)
    (if (or (and (equal p13 p13@ 1E-6)
                 (equal p14 p14@ 1E-6)
            (not (equal (angle p14 p14@) (angle p13 p13@) 1E-6))
        (redraw en 3)
        (setq p   (getpoint "\n无法判断标注界限方向,请重新指定: ")
              ang (angle (inters p1 p2 p (polar p a 1) nil) p)
        (redraw en 4)
      (setq ang (angle p13@ p13))
    (setq p13 (cons 13 (polar p13@ ang di))
          p14 (cons 14 (polar p14@ ang di))
    (entmod (subst p14 (assoc 14 ent) (subst p13 (assoc 13 ent) ent)))
 楼主| 发表于 2009-7-20 18:25:00 | 显示全部楼层
为什么是错的?版主:
选择对象:  ; 错误: 参数类型错误: 二维/三维点: nil
发表于 2009-7-20 19:39:00 | 显示全部楼层
我测试无错,请把测试文件发上来
 楼主| 发表于 2009-7-20 19:54:00 | 显示全部楼层
院长已经解决。
发表于 2009-7-20 22:59:00 | 显示全部楼层
我找到了以前写的一个函数可以用,liminnet 以前求救的帖子中我发过,但对于“样式替代”的错误至今没有修改!
;; [功能] 获取标注的定义点
;; [参数] edata---标注对象的 DXF 定义数据
;; [返回] 包含两个点的表,依次为 (第一个尺寸线定义点 第二个尺寸线定义点p10)
        typ (- (dxf 70) 32)
        p10 (dxf 10)
        p13 (dxf 13)
  (list (cond
          ((zerop typ)
          ((= typ 1)
             p13
        p10
发表于 2009-7-20 23:39:00 | 显示全部楼层
找vla对象参考去吧!
发表于 2009-7-21 01:20:00 | 显示全部楼层
24楼已经修改
GMT+8, 2026-1-23 20:15 , Processed in 0.162926 second(s), 18 queries , Gzip On.
