楼主: tanle2020
[推荐]修改任何文字(包括属性块、有名无名块)
发表于 2009-6-10 14:04:00 | 显示全部楼层
我試過05版本可以用到 08版本就不行啦!不知道是什麽原因
发表于 2010-7-24 16:01:00 | 显示全部楼层
学习一下!
发表于 2010-7-25 23:19:00 | 显示全部楼层
7楼的可否把源码发下,让我等菜鸟看下………………
发表于 2010-7-26 10:36:00 | 显示全部楼层
我发下吧,刚刚改好的。
;;; 自定义UnDo范围
(defun EF:UNDOBegin ()
  (setvar "CMDECHO" 0)
  (command "_.undo" "_group")
;;; end defun
(defun EF:UNDOEnd ()
  (command "_.undo" "_end")
;;; end defun
(defun c:tt (/ dcl_id1 oba ob1 obn obt ptn otxt txt sty styno lay cyn layno
        hig wid ang col cnu etlst style layer
  (graphscr)
  (EF:UNDOBegin)
  (setq olderr *error*)
  (defun *error* (msg)
    (princ "\n*ERROR*...")
    (princ msg)
  )           ; end defun error.
  (defun set_color (conm / costr)
    (defun map_color (ckey mno)
      (start_image ckey)
      (fill_image 0 0 (DimX_tile ckey) (DimY_tile ckey) mno)
      (end_image)
    )           ; end defun
    (cond
      ((= 0 conm)
 (setq costr "Byblock")
      ((= 1 conm)
 (setq costr "Red")
      ((= 2 conm)
 (setq costr "Yellow")
      ((= 3 conm)
 (setq costr "Green")
      ((= 4 conm)
 (setq costr "Cyan")
      ((= 5 conm)
 (setq costr "Bule")
      ((= 6 conm)
 (setq costr "Magenta")
      ((= 7 conm)
 (setq costr "color")
      ((= 256 conm)
 (setq costr "Bylayer")
      (t
 (setq costr "")
    )           ; end cond
    (cond
      ((= 0 col)
 (map_color "col" 7)
      ((= 256 col)
 (map_color "col" (cdr (assoc 62 (tblsearch "layer" lay))))
      (t
 (map_color "col" conm)
    )           ; end cond
    (if (= 256 conm)
      (set_tile "cnu" (strcat "<" (itoa (cdr (assoc 62 (tblsearch "layer"
          lay
      ) ">" costr
      (set_tile "cnu" (strcat "<" (itoa conm) ">" costr))
    )           ; end if
  )           ; end set_color
  (defun map_keylist (key keylst)      ; set popuplist
    (start_list key)
    (mapcar
      'add_list
      keylst
    (end_list)
  )           ; end map
  (defun layer_get_all (/ lay layer layname)
    (setq layer nil         ; All layer
   lay (tblnext "LAYER" T)
    (while (/= lay nil)
      (setq layname (cdr (assoc 2 lay))
     layer (cons layname layer)
      (setq lay (tblnext "LAYER"))
    (setq layer (ACAD_Strlsort layer))
    layer          ; all layer.
  )           ; end defun
  (defun style_get_all (/ sty style sty_list)
    (setq sty_list nil
   sty (tblnext "style" t)
    (setq style (cdr (assoc 2 sty)))
    (while style
      (if (/= "" style)
 (setq sty_list (append
    sty_list
    (list style)
      (setq sty (tblnext "style"))
    )           ; end while]
    (setq sty_list (ACAD_Strlsort sty_list))
    sty_list
  )           ; end defun
  (defun set_error (str)
    (set_tile "error" str)
  )           ; end defun
  (defun sub_mtext (color entlist / ei newlist)
    (setq ei 0
   newlist nil
    (while (< ei (length entlist))
      (setq newlist (cons (nth ei entlist) newlist))
      (if (= 8 (car (nth ei entlist)))
 (setq newlist (cons (cons 62 color) newlist))
      )           ; end if
      (setq ei (1+ ei))
    )           ; end while
    (reverse newlist)
  )           ; end defun
  (setq ob1 (entsel "\n选择要修改的任何文本:"))
  (SETQ obn (car ob1)
 ptn (car (cdr ob1))
  (setq obt (car (nentselp ptn)))
  (setq oba (cdr (assoc 0 (entget obt))))
  (if (or
 (= oba "TEXT")
 (= oba "MTEXT")
 (= oba "ATTRIB")
    (setq otxt (cdr (assoc 1 (entget obt))))
  )           ; end if
  (if (= oba "ATTDEF")
    (setq otxt (cdr (assoc 2 (entget obt))))
  )           ; end if
  (if otxt
      (setq sty (cdr (assoc 7 (entget obt)))
     lay (cdr (assoc 8 (entget obn)))
     hig (cdr (assoc 40 (entget obt)))
     wid (cdr (assoc 41 (entget obt)))
     ang (cdr (assoc 50 (entget obt)))
      )           ; end setq
      (if (or
     (= oba "TEXT")
     (= oba "MTEXT")
     (= oba "ATTRIB")
 (setq col (cdr (assoc 62 (entget obt))))
 (setq col (cdr (assoc 62 (entget obn))))
      )           ; end if
      (setq ang (* 180 (/ ang pi)))
      (if (null col)
   (setq cyn 0)
   (setq col 256)
 (setq cyn 1)
      (setq style (style_get_all))
      (setq layer (layer_get_all))
      (setq styno (- (length style) (length (member sty style))))
      (setq layno (- (length layer) (length (member lay layer))))
      (setq dcl_id1 (load_dialog "文字修改.DCL"))
      (if (not (new_dialog "文字修改" dcl_id1))
 (exit)
      (set_color col)
      (set_tile "text" otxt)
      (set_tile "hig" (rtos hig 2 2))
      (set_tile "wid" (rtos wid 2 2))
      (set_tile "ang" (rtos ang 2 2))
      (mode_tile "text" 2)
      (map_keylist "sty" style)
      (set_tile "sty" (itoa styno))
      (map_keylist "lay" layer)
      (set_tile "lay" (itoa layno))
      (action_tile "text" "(setq txt $value)")
      (action_tile "sty" "(setq styno (atoi $value))")
      (action_tile "hig" "(setq hig (distof $value))(if (>= 0 hig)(progn (mode_tile \"hig\" 3)(mode_tile \"hig\" 2)(set_error \"Input error ! \"))(set_error \"\"))")
      (action_tile "wid" "(setq wid (distof $value))(if (>= 0 wid)(progn (mode_tile \"wid\" 3)(mode_tile \"wid\" 2)(set_error \"Input error ! \"))(set_error \"\"))")
      (action_tile "lay" "(setq layno (atoi $value))")
      (action_tile "col" "(if (setq cnu (ACAD_ColorDlg col))(progn (setq col cnu)(set_color col)))")
      (action_tile "ang" "(setq ang (distof $value))")
      (action_tile "accept" "(done_dialog 1)")
      (action_tile "cancel" "(done_dialog 0)")
      (if (= 1 (start_dialog))
 (if txt
     (setq sty (nth styno style))
     (setq lay (nth layno layer))
     (setq ang (* (/ ang 180) pi))
     (setq etlst (entget obt))
       (setq etlst (subst
       (cons 2 txt)
       (assoc 2 etlst)
       etlst
       (setq etlst (subst
       (cons 1 txt)
       (assoc 1 etlst)
       etlst
     )          ; end if
     (setq etlst (subst
     (cons 7 sty)
     (assoc 7 etlst)
     etlst
     (setq etlst (subst
     (cons 40 hig)
     (assoc 40 etlst)
     etlst
     (setq etlst (subst
     (cons 41 wid)
     (assoc 41 etlst)
     etlst
     (setq etlst (subst
     (cons 50 ang)
     (assoc 50 etlst)
     etlst
     (if (= 1 cyn)
       (setq etlst (subst
       (cons 62 col)
       (assoc 62 etlst)
       etlst
       (if (= "MTEXT" oba)
  (setq etlst (sub_mtext col etlst))
  (setq etlst (cons (cons 62 col) etlst))
       )          ; end if
     )          ; end if
     (entmod etlst)
     (entupd obt)
     (entupd obn)
 )          ; end if
      )           ; end if
      (if (= 11 (start_dialog))
 (Command "_help")
    )           ; end progn
  )           ; end if
  (setq *error* olderr)
  (EF:UNDOEnd)
;;; end defun
发表于 2010-7-26 16:21:00 | 显示全部楼层
duotu007
你的程序好像无法使用
发表于 2010-10-9 15:47:00 | 显示全部楼层
谢谢楼上兄弟的分享,参考下,非常感激!
发表于 2010-11-13 21:47:00 | 显示全部楼层
多谢了
发表于 2011-1-19 08:50:46 | 显示全部楼层
学习一下
发表于 2011-1-19 17:18:46 | 显示全部楼层
严重鄙视7楼的行为,支持楼主共享
发表于 2012-1-5 17:19:06 | 显示全部楼层
     楼主的程序用不了,  编译的SD与我的外挂又重名了,
GMT+8, 2026-1-20 08:28 , Processed in 0.175988 second(s), 18 queries , Gzip On.
