楼主: zhongys
一次性建立多个层,自定义函数通不过,大家帮忙解决一下
发表于 2009-9-4 23:05:00 | 显示全部楼层
(defun zgx-mklayer (layname color ltype linewid / lst1 lst2)
  (if (and (not (tblobjname "ltype" ltype))
    (not (command "_.-linetype" "_load" ltype "acad.lin" "")
      )     ;and
    (setq ltype "CONTINUOUS")
  (setq lst1 (list 0 100 100 2 62 6 70 370)
 lst2 (list "layer"       "AcDbSymbolTableRecord"
     "AcDbLayerTableRecord"
     layname       color
     ltype       0
     linewid
  (setq lst2 (mapcar 'cons lst1 lst2))
  (entmake lst2)
发表于 2009-9-5 15:02:00 | 显示全部楼层
VBA建立的图层。
  1. Function Maked3DModelLayer(cadApp As AcadApplication, EntArr As Variant, EntColorArr As Variant) As Variant
  2.   Dim LayerArray, LayerColorArray
  3.   Dim oLayer As AcadLayer
  4.   For Each oLayer In cadApp.ActiveDocument.Layers
  5.     If InStr(oLayer.Name, "中心线") > 0 Then
  6.       Exit Function
  7.     End If
  8.   Next oLayer
  9.   LayerArray = Array("粗实线", "虚线", "细实线", "中心线", "点划线", "尺寸线", "文本", "明细表材料表", "件号", "标题栏")
  10.   Maked3DModelLayer = LayerArray
  11.   LayerColorArray = Array(1, 255, 3, 4, 4, 6, 2, 131, 124, 4)
  12.   Dim TestLayer As AcadLayer
  13.   For ii = 0 To UBound(LayerArray)
  14.     Set TestLayer = cadApp.ActiveDocument.Layers.Add(LayerArray(ii))
  15.     TestLayer.Color = LayerColorArray(ii)
  16.   Next ii
  17.   For ii = 0 To UBound(EntArr)
  18.     Set TestLayer = cadApp.ActiveDocument.Layers.Add(EntArr(ii))
  19.     TestLayer.Color = EntColorArr(ii)
  20.   Next ii
  21.   With cadApp.ActiveDocument
  22.     .Linetypes.Load "ACAD_ISO03W100", "acad.lin"
  23.     .Linetypes.Load "ACAD_ISO04W100", "acad.lin"
  24.     .Linetypes.Load "ACAD_ISO05W100", "acad.lin"
  25.     .Layers("中心线").Linetype = "ACAD_ISO04W100"
  26.     .Layers("虚线").Linetype = "ACAD_ISO03W100"
  27.     .Layers("点划线").Linetype = "ACAD_ISO05W100"
  28.     '.SendCommand "ltscale" & vbCr & 10 & vbCr
  29.   End With
  30. End Function
  31. '''
发表于 2009-9-5 21:04:00 | 显示全部楼层
龙龙仔版主的mapcar用法太强.学习
发表于 2009-9-11 11:56:00 | 显示全部楼层
思路都很好,学习了
发表于 2009-9-11 17:14:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-9-16 19:44:00 | 显示全部楼层
大家给的程序都非常好。谢谢。
发表于 2011-4-29 01:22:31 | 显示全部楼层
学习啦
发表于 2012-4-10 13:45:43 | 显示全部楼层
xyp1964 发表于 2009-9-2 13:14
很棒,不知能不能 在修改一下, 每个层有对应想线型,比如中心线层,就自动加载 虚线。
发表于 2012-6-3 00:01:48 | 显示全部楼层
在程序里面能加LWDEFAULT变量(线宽)
GMT+8, 2026-1-19 21:35 , Processed in 0.159633 second(s), 19 queries , Gzip On.
