楼主: ahopera
.net Api怎么实现Lisp里面(textscr)函数的功能
发表于 2009-9-3 19:18:00 | 显示全部楼层
 ublic Sub Command(ByVal ParamArray args() As Object)
这样声明
 楼主| 发表于 2009-9-3 19:20:00 | 显示全部楼层
这个问题已经解决啦,但是为什么
<CommandMethod("tscr")> Sub TextScr()
        Dim CmdStr() As Object = {"RECTANG", New Point2d(0, 0), New Point2d(1, 1)}
        Command(CmdStr)
        'Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        'doc.Editor.WriteMessage("\nHi")
    End Sub
就会出错呢?
 楼主| 发表于 2009-9-3 20:20:00 | 显示全部楼层
经版主指点,这样的代码可以正确执行:
VB.net Code:
  1. Imports System
  2. Imports System.Runtime.InteropServices
  3. Imports Autodesk.AutoCAD.Runtime
  4. Imports Autodesk.AutoCAD.DatabaseServices
  5. Imports Autodesk.AutoCAD.EditorInput
  6. Imports Autodesk.AutoCAD.ApplicationServices
  7. Module Example
  8.     <DllImport("acad.exe")> Public Function acedCmd(ByVal vlist As IntPtr) As Integer
  9.     End Function
  10.     Public Sub Command(ByVal args() As Object)
  11.         Dim rb As ResultBuffer
  12.         Dim val As Object
  13.         For Each val In args
  14.             rb = New ResultBuffer()
  15.             If (val Is Nothing) Then
  16.                 rb.Add(New TypedValue(CInt(LispDataType.Text), ""))
  17.             Else
  18.                 Select Case val.GetType().Name
  19.                     Case "String"
  20.                         rb.Add(New TypedValue(CInt(LispDataType.Text), val))
  21.                         Exit Select
  22.                     Case "Point2d"
  23.                         rb.Add(New TypedValue(CInt(LispDataType.Point2d), val))
  24.                         Exit Select
  25.                     Case "Point3d"
  26.                         rb.Add(New TypedValue(CInt(LispDataType.Point3d), val))
  27.                         Exit Select
  28.                     Case "ObjectId"
  29.                         rb.Add(New TypedValue(CInt(LispDataType.ObjectId), val))
  30.                         Exit Select
  31.                     Case "SelectionSet"
  32.                         rb.Add(New TypedValue(CInt(LispDataType.SelectionSet), val))
  33.                         Exit Select
  34.                     Case "Double"
  35.                         rb.Add(New TypedValue(CInt(LispDataType.Double), val))
  36.                         Exit Select
  37.                     Case "Int16"
  38.                         rb.Add(New TypedValue(CInt(LispDataType.Int16), val))
  39.                         Exit Select
  40.                     Case "Int32"
  41.                         rb.Add(New TypedValue(CInt(LispDataType.Int32), val))
  42.                         Exit Select
  43.                     Case "TypedValue"
  44.                         rb.Add(val)
  45.                         Exit Select
  46.                 End Select
  47.             End If
  48.             Try
  49.                 acedCmd(rb.UnmanagedObject)
  50.             Catch
  51.             Finally
  52.                 rb.Dispose()
  53.             End Try
  54.         Next val
  55.     End Sub
  56. End Module
发表于 2009-9-8 22:48:00 | 显示全部楼层
在theswamp看过你的贴了:)
总结下,解决方案如下
1、引用acmgdinternal.dll
Autodesk.AutoCAD.Internal.Utils.TextScr()
Autodesk.AutoCAD.Internal.Utils.GraphScr()
2、P/Invoke
        [DllImport("acad.exe")]
        private static extern int acedTextScr();
        private static extern int acedGraphScr();
        public static bool DisplayTextScreen
            set
                if (value)
                    acedTextScr();
                else
                    acedGraphScr();
        [CommandMethod("ts1")]
        public static void tt1()
            DisplayTextScreen = true;
        [CommandMethod("ts2")]
        public static void tt2()
            DisplayTextScreen = false;
3、AutoCad2010最简单
Application.DisplayTextScreen = true;
GMT+8, 2025-12-18 04:15 , Processed in 0.130063 second(s), 17 queries , Gzip On.
