查看: 2569|回复: 4
.NET有COM的CopyObjects吗?找到方法了!
发表于 2009-9-21 00:41:00 | 显示全部楼层 |阅读模式
com有object.CopyObjects(Objects[, Owner][, IDPairs]) ,object是MSITStore:E:\New%20Study\CAD\acadautovba.chm::/idh_database_object.htm">Database, MSITStore:E:\New%20Study\CAD\acadautovba.chm::/idh_document_object.htm">Document用于将一个document的图形复制到另外一个document当中,而且在 CopyObjects 操作期间,被 Objects 参数中的源对象拥有或引用的对象也将被复制。
不知道.net有没有相同功能的函数?查看了对象浏览器的document和database对象,都没有类似的方法
 楼主| 发表于 2009-9-21 01:23:00 | 显示全部楼层
找到方法了!
使用WblockCloneObjects
注意红色的部分,不过不知道能不能复制块参照,并且把块参照的引用块定义也一起复制过去,com里的copyobjects方法可是可以做到这一点的,我试验过。
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
[CommandMethod("CopyObjectsBetweenDatabases", CommandFlags.Session)]
public static void CopyObjectsBetweenDatabases()
  ObjectIdCollection acObjIdColl = new ObjectIdCollection();
  // Get the current document and database
  Document acDoc = Application.DocumentManager.MdiActiveDocument;
  Database acCurDb = acDoc.Database;
  // Lock the current document
  using (DocumentLock acLckDocCur = acDoc.LockDocument())
      // Start a transaction
      using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
          // Open the Block table record for read
          BlockTable acBlkTbl;
          acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId,
                                       OpenMode.ForRead) as BlockTable;
          // Open the Block table record Model space for write
          BlockTableRecord acBlkTblRec;
          acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace],
                                          OpenMode.ForWrite) as BlockTableRecord;
          // Create a circle that is at (0,0,0) with a radius of 5
          Circle acCirc1 = new Circle();
          acCirc1.SetDatabaseDefaults();
          acCirc1.Center = new Point3d(0, 0, 0);
          acCirc1.Radius = 5;
          // Add the new object to the block table record and the transaction
          acBlkTblRec.AppendEntity(acCirc1);
          acTrans.AddNewlyCreatedDBObject(acCirc1, true);
          // Create a circle that is at (0,0,0) with a radius of 7
          Circle acCirc2 = new Circle();
          acCirc2.SetDatabaseDefaults();
          acCirc2.Center = new Point3d(0, 0, 0);
          acCirc2.Radius = 7;
          acBlkTblRec.AppendEntity(acCirc2);
          acTrans.AddNewlyCreatedDBObject(acCirc2, true);
          // Add all the objects to copy to the new document
          acObjIdColl.Add(acCirc1.ObjectId);
          acObjIdColl.Add(acCirc2.ObjectId);
          // Save the new objects to the database
          acTrans.Commit();
      // Unlock the document
  // Change the file and path to match a drawing template on your workstation
  string sLocalRoot = Application.GetSystemVariable("LOCALROOTPREFIX") as string;
  string sTemplatePath = sLocalRoot + "Template\\acad.dwt";
  // Create a new drawing to copy the objects to
  DocumentCollection acDocMgr = Application.DocumentManager;
  Document acNewDoc = acDocMgr.Add(sTemplatePath);
  Database acDbNewDoc = acNewDoc.Database;
  // Lock the new document
  using (DocumentLock acLckDoc = acNewDoc.LockDocument())
      // Start a transaction in the new database
      using (Transaction acTrans = acDbNewDoc.TransactionManager.StartTransaction())
          // Open the Block table for read
          BlockTable acBlkTblNewDoc;
          acBlkTblNewDoc = acTrans.GetObject(acDbNewDoc.BlockTableId,
          // Open the Block table record Model space for read
          BlockTableRecord acBlkTblRecNewDoc;
          acBlkTblRecNewDoc = acTrans.GetObject(acBlkTblNewDoc[BlockTableRecord.ModelSpace],
                                              OpenMode.ForRead) as BlockTableRecord;
          // Clone the objects to the new database
          IdMapping acIdMap = new IdMapping();
          acCurDb.WblockCloneObjects(acObjIdColl, acBlkTblRecNewDoc.ObjectId, acIdMap,
                                     DuplicateRecordCloning.Ignore, false);
          // Save the copied objects to the database
          acTrans.Commit();
  // Set the new document current
  acDocMgr.MdiActiveDocument = acNewDoc;
发表于 2009-9-21 09:28:00 | 显示全部楼层
还有深度Clone
db.DeepCloneObjects(...)
 楼主| 发表于 2009-9-21 19:27:00 | 显示全部楼层
深度clone有什么不一样吗?
发表于 2009-9-21 19:43:00 | 显示全部楼层
深层拷贝-复制数据
浅层拷贝-只复制引用
具体的要在使用的过程中去理解它
GMT+8, 2025-8-2 04:46 , Processed in 0.162413 second(s), 24 queries , Gzip On.
