楼主: 啵浪鼓
[求助]能输数字和字符的代码
 楼主| 发表于 2009-10-6 01:01:00 | 显示全部楼层
龙版主的程序好难懂,结果是ok,但自已一段一段执行下去想找到接口点,插程序进去就不行,; 错误: 参数类型错误: stringp 10.0
因为我想在龙版主的程序里插入如果用户输入空格将执行默认字高(if (= gs nil) (setq gs 3)),目前龙版主的程序不能接受空回车
本来很简单的程序,被我自已整的昏头了,下面的程序被整的无厘头了
(defun c:tt ()
  (setvar "cmdecho" 0)
  (command "style" "HP-CHINESET" "txt.shx,CHINESET.shx" "" "0.7" "" "N" "N" "N")
  (if(not(tblsearch "layer" "TEXT"))
     (command "layer" "new" "TEXT" "set" "TEXT" "c" "4" "TEXT" "")
     (command "layer" "set" "TEXT" "c" "4" "TEXT" "")
  (princ "\nPick position to display Filename/Path : ")
  (setq vc (getvar "viewctr"))
  (setq pt (list (car vc) (cadr vc)))
  (setq dwgp (getvar "dwgprefix"))
  (setq dwgp0(substr dwgp 3 222))
  (setq dwgp1 "SERVER")
  (setq dwgn (getvar "dwgname"))
  (setq username (getvar "loginname"))
  (if (= "Server" (substr dwgp0 1 6))
      (setq dwgp2(substr dwgp 9 222))
      (setq dwgp2(substr dwgp 3 222))
;(defun C:TT (/ ENP FLAG)
  (setq FLAG t)
  (while FLAG
    (cond
      ((= (progn (initget 128)
   (setq ENP
   (getpoint
     (strcat "\n FileName<A>/FilePath<B>/文字高度<" (rtos gs) ">:"    ;程序不能接受默认值或者空回车
   NIL
       (setq FLAG t)
      ((wcmatch (substr ENP 1 1) "[0-9]")
       (setq ENP  (atof ENP)
      FLAG NIL
      ((wcmatch (setq ENP (strcase (substr ENP 1 1))) "[AaBb]")
       (setq FLAG NIL)
;  ENP
  (cond
       ((and (= "B" enp)(= "b" enp))  ;如果enp=b时,gs文字高度应该为默认值
              (command "text" (list (car pt) (cadr pt)) gs (list (+ (car pt) 10) (cadr pt))
                 (strcat dwgp1 dwgp2 dwgn))
       ((and (= "A" enp)(= "a" enp))  ;如果enp=a时,gs文字高度应该为默认值
                (setq filename(substr dwgn 1 (- (strlen dwgn) 4)))
                (command "text" (list (car pt) (cadr pt)) gs (list (+ (car pt) 10) (cadr pt)) filename))
       (t (progn (setq filename(substr dwgn 1 (- (strlen dwgn) 4)))      ;如果enp等于数字时,执行此段  ;目前此段根本就不成立,不管输入数字或是字母都是T
          (command "text" (list (car pt) (cadr pt)) enp (list (+ (car pt) 10) (cadr pt)) filename)))
  (command "move" (entlast) "" (list (car pt) (cadr pt)) pause )
发表于 2009-10-6 08:31:00 | 显示全部楼层
(defun C:TT (/ DWGN DWGP DWGP0 DWGP1 DWGP2 ENP FILENAME FLAG ;|GS|;
      PAUSE PT USERNAME VC)
    ""   "0.7"        ""      "N"
    "N"   "N"
  (if (not (tblsearch "layer" "TEXT"))
  (setq VC (getvar "viewctr"))
  (setq PT (list (car VC) (cadr VC)))
  (setq DWGP (getvar "dwgprefix"))
  (setq DWGP0 (substr DWGP 3 222))
  (setq DWGP1 "SERVER")
  (setq DWGN (getvar "dwgname"))
  (setq USERNAME (getvar "loginname"))
  (if (= "Server" (substr DWGP0 1 6))
    (setq DWGP2 (substr DWGP 9 222))
    (setq DWGP2 (substr DWGP 3 222))
  (if (= GS NIL)
    (setq GS 3)
  ;;(defun C:TT (/ ENP FLAG)
  (setq FLAG t)
  (while FLAG
     (cond
   (setq ENP
   (getpoint
      (rtos GS)
      ">:" ;程序不能接受默認值或者空回車
   NIL
      (setq FLAG t)
      FLAG NIL
      GS   ENP
       (setq FILENAME (substr DWGN 1 (- (strlen DWGN) 4)))
       (command "text"
  (list (car PT) (cadr PT))
  ENP
  (list (+ (car PT) 10) (cadr PT))
  FILENAME
       (setq FLAG NIL)
       (cond
  ((or (= "B" ENP) (= "b" ENP)) ;如果enp=b時,gs文字高度應該為默認值
   (command "text"
     GS
     (strcat DWGP1 DWGP2 DWGN)
  ((or (= "A" ENP) (= "a" ENP)) ;如果enp=a時,gs文字高度應該為默認值
   (command "text"
     GS
     FILENAME
  ;;  ENP
  (command "_.move"
    (entlast)
GMT+8, 2025-12-23 18:59 , Processed in 0.162073 second(s), 18 queries , Gzip On.
