楼主: cj52000
[求助]关于坐标标注的问题(附图),各位请进!
发表于 2009-10-17 21:05:00 | 显示全部楼层
  1. (defun c:md(/ DXF70 ENT ENTDXF)
  2.   (if (setq ent (entsel))
  3.     (progn
  4.       (setq ent (car ent))
  5.       (setq entdxf (entget ent))
  6.       (setq dxf70 (cdr (assoc 70 entdxf)))
  7.       (if (= dxf70 38)(entmod (subst (list 14 (cadr(assoc 14 entdxf)) (caddr(assoc 13 entdxf)) (cadddr(assoc 14 entdxf))) (assoc 14 entdxf) entdxf)))
  8.       (if (= dxf70 102)(entmod (subst (list 14 (cadr(assoc 13 entdxf)) (caddr(assoc 14 entdxf)) (cadddr(assoc 14 entdxf))) (assoc 14 entdxf) entdxf)))
  9.       )
  10.     )
  11.   (princ)
  12.   )
发表于 2009-10-17 21:28:00 | 显示全部楼层
insufficient display
要以原图(*.dwg) 为准
(请上传)
且一并列出其余实务状况.....
(方便调试之用....)
 楼主| 发表于 2009-10-18 02:31:00 | 显示全部楼层
谢谢sailorcwx的程序,很好用,正合我意,就是能不能提个小小要求,如果要是能多选就好了,不用一个个点,能否帮忙改下,谢谢大家的热心!
 楼主| 发表于 2009-10-20 18:57:00 | 显示全部楼层
sailorcwx兄,请关注我的另一个贴子:
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=78806
和您写的那个程序有点相反,谢谢!
发表于 2009-10-20 19:46:00 | 显示全部楼层
我一般标注成直的就是直的,折线行式的也就随它了
不过还是等待高手的出现,我也很想知道答案。
发表于 2009-10-21 00:06:00 | 显示全部楼层
我很奇怪,同样是手动标注,但有些坐标标注为什么会是230的dxf组码,将11楼的程序改成支持多选,但是230的标注使终改不了!
;by sailorcwx
(defun c:qa(/ DXF70 ENT ENTDXF)
    (setq os (getvar "osmode"))
    (setvar "cmdecho" 0)
    (command "undo" "be")
    (setq ss (ssget '((0 . "DIMENSION"))))
    (setq i 0)
    (while (< i (sslength ss))
       (setq ent (ssname ss i))
       (if (= dxf70 230)(entmod (subst (list 14 (cadr(assoc 13 entdxf)) (caddr(assoc 14 entdxf)) (cadddr(assoc 14 entdxf)))
       (setq i (+ i 1))
    (setvar "osmode" os)
    (command "undo" "e")
GMT+8, 2026-1-15 17:37 , Processed in 0.185629 second(s), 19 queries , Gzip On.
