楼主: yjpzc
[基础] 求教高手,我这个程序应怎么循环
发表于 2009-11-20 08:09:00 | 显示全部楼层
xianaihua发表于2009-11-19 21:20:00这个朋友的要求还很高呀,不过好像也能实现
應使用原(command "_.pline")來實現,並配合entmake 文字
发表于 2009-11-24 12:23:00 | 显示全部楼层
;;(V2 2)
(defun V2 (TXTHEIGHT / A ANG HS HX S PT1 PT2)
  (command "_.layer" "s" "0" "")
  (setvar "cmdecho" 1)
  (command "_.pline" PAUSE)
  (setq PT1 (getvar "lastpoint"))
  (while (= 1 (getvar "cmdactive"))
    (command PAUSE)
    (setq PT2 (getvar "lastpoint"))
    (if (not (equal (getvar "lastpoint") PT1))
 (setq S (distance PT1 PT2))
 (setq A (rtos S 2 2))
 (setq ANG (angle PT1 PT2))
 (setq HS (/ S 2))
 (setq HX (polar PT1 ANG HS))
 ;;這段程序我在公司電腦沒有效果(R2008)
 ;;家裡(R2008)卻可以,有點悶.....???
 (entmake (list (cons 0 "TEXT")
         (cons 100 "AcDbEntity")
         (cons 100 "AcDbText")
         (cons 10 HX)
         (cons 40 TXTHEIGHT)
         (cons 1 A)
         (cons 50 ANG)
 (setq PT1 PT2)
(prompt "\n <<length>>在圖中直接寫出長度")
GMT+8, 2025-12-17 06:27 , Processed in 0.167704 second(s), 19 queries , Gzip On.
