查看: 5248|回复: 11
[基础] [求助]vlisp/lisp能否判断图层使用了"真彩色"?
发表于 2010-2-1 22:30:00 | 显示全部楼层 |阅读模式
请教大家:
发表于 2010-2-1 23:00:00 | 显示全部楼层
vla-get-truecolor + vla-get-red / green / blue
发表于 2010-2-2 00:23:00 | 显示全部楼层
(assoc 420 (entget(tblobjname "layer" layerName)))
返回nil说明没使用真彩色,反之则是
 楼主| 发表于 2010-2-2 07:50:00 | 显示全部楼层
请教caoyin:
比如assoc 420 (entget(tblobjname "layer" "col-p1")))
返回420 . 16571297),  如何把16571297算成原来的真彩色数值:252,219,161
发表于 2010-2-2 14:01:00 | 显示全部楼层
(defun TrueColor2RGB (col /)
  (strcat (itoa (lsh (fix col) -16))
          (itoa (lsh (lsh (fix col) 16) -24))
          (itoa (lsh (lsh (fix col) 24) -24))
 楼主| 发表于 2010-2-2 22:09:00 | 显示全部楼层
谢谢caoyin
 楼主| 发表于 2010-2-2 22:20:00 | 显示全部楼层
下面这一行能够成功执行:
(vla-put-Color (vla-add (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) "col-p4") 4)
可换成这样就不行了,请求帮助:
(vla-put-Color (vla-add (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) "col-p4") "252,219,161")
发表于 2010-2-2 23:25:00 | 显示全部楼层
(setq ACAD   (vlax-get-acad-object)
      ColObj (vla-getinterfaceobject
               ACAD
               (strcat "AutoCAD.AcCmColor." (substr (getvar "AcadVer") 1 2))
      LayObj (vla-add (vla-get-Layers (vla-get-ActiveDocument ACAD)) "col-p4")
(vla-SetRGB colObj 252 219 161)
(vla-put-TrueColor LayObj colObj)
 楼主| 发表于 2010-2-2 23:43:00 | 显示全部楼层
谢谢caoyin,上楼的代码能否简单解释一下?!万分感谢!
发表于 2010-2-2 23:58:00 | 显示全部楼层
要怎么解释?
(vla-getinterfaceobject ACAD (strcat "AutoCAD.AcCmColor." (substr (getvar "AcadVer") 1 2)));;加载真彩色对象
(vla-SetRGB colObj 252 219 161);;设置真彩色对象的Red Green Blue各自的值
(vla-put-TrueColor LayObj colObj);;将真彩赋与图层对象
GMT+8, 2025-12-18 03:50 , Processed in 0.191238 second(s), 27 queries , Gzip On.
