查看: 1602|回复: 1
[讨论]请问如何恢复块定义
发表于 2010-2-8 14:19:00 | 显示全部楼层 |阅读模式
图纸中有很多块参照,但却没有块定义,请问如何才能恢复这些块参照的块定义
 楼主| 发表于 2010-2-8 15:20:00 | 显示全部楼层
[讨论]没想到竟这么简单
Sub ReSetBlockReference()
'恢复块定义
    On Error Resume Next
    Dim blockEnt As AcadBlockReference
    Dim blkName As String
    Dim getobj As Object
    Dim p As Variant
    Dim i As Integer
    Dim ssetObj As AcadSelectionSet
    If Not IsNull(ThisDrawing.SelectionSets.item("Example")) Then
        Set ssetObj = ThisDrawing.SelectionSets.item("Example")
        ssetObj.Delete
    End If
    Set ssetObj = ThisDrawing.SelectionSets.Add("Example")
    ThisDrawing.Utility.InitializeUserInput 0,
    ssetObj.SelectOnScreen
    For i = 0 To ssetObj.count - 1
        Set blockEnt = ssetObj(i)
        blockEnt.Name = blockEnt.Name
    Next
        ssetObj.Delete
End Sub
GMT+8, 2026-1-18 04:17 , Processed in 0.153698 second(s), 23 queries , Gzip On.
