查看: 2049|回复: 2
[求助龙版]标注程序
发表于 2010-2-22 11:33:00 | 显示全部楼层 |阅读模式
我想用你以前编的这个程序,但是捕捉设置会被清空,
能否帮忙修改一下。谢
;;这是一个很久以前的程序,写得不太好,也很少用(因现在有double_click功能)!!
(defun C:D (/    HOLDOSMODE      HOLDECHO HOLDBLIP P340
    P340ENTGET10     A1      AAA1     A        AAA
    AAL    AAPT     Q%Q      Q%Q1     Q%Q11
  (setq HOLDECHO (getvar "cmdecho"))
  (setq HOLDBLIP (getvar "blipmode"))
  (setq HOLDOSMODE (getvar "osmode"))
  (setvar "cmdecho" 0)
  (setvar "blipmode" 0)
  (setvar "osmode" 0)
  (while (null AAA1)
    (setq AAA1 (nentsel))
  (setq AAL (length AAA1))
  (cond
    ((/= AAL 2)
     (setq AAL (length (last AAA1)))
     (if (/= AAL 1)
  (setq A1 (car AAA1))
  (setq AAPT (cadr AAA1))
  (setq AAA (entget A1))
  (setq Q%Q (cdr (assoc 0 AAA)))
  (setq Q%Q11 (cdr (assoc 0 (entget (car (last AAA1))))))
  (if (= Q%Q11 "DIMENSION")
    (setq Q%Q NIL)
  (setq Q%Q1 (cdr (assoc 0 (entget (car AAA1)))))
  (cond
    ((and (/= Q%Q1 "LINE")
   (/= Q%Q1 "CIRCLE")
   (/= Q%Q1 "ARC")
   (/= Q%Q1 "MLINE")
   (/= Q%Q1 "VERTEX")
     (setq Q%Q NIL)
  (setq A1 (car (last AAA1)))
  (setq AAPT (cdr AAA1))
    ((= AAL 2)
  (cond
    ((or (= Q%Q "LINE") (= Q%Q "MLINE"))
     (command "_.DIMLINEAR" "" AAPT)
    ((= Q%Q "CIRCLE") (command "_.DIMDIAMETER" AAPT))
    ((= Q%Q "ARC") (command "_.DIMRADIUS" AAPT))
    ((= Q%Q "DIMENSION") (command "_.DIMTEDIT" A1))
    ((= Q%Q "LEADER")
     (setq P340 (cdr (assoc 340 (entget A1))))
     (setq P340ENTGET10 (cdr (assoc 10 (entget P340))))
     (command "_.move" P340ENTGET10 "")
    ((= Q%Q "MTEXT") (command "_.DDEDIT" AAPT))
    ((= Q%Q "TEXT") (command "_.DDEDIT" AAPT))
    ((= Q%Q "HATCH")
     (initdia 1)
     (command "_.HATCHEDIT" AAPT)
     (initdia 0)
    ((= Q%Q "ATTDEF") (command "_.DDEDIT" AAPT))
    ((= Q%Q "ATTRIB") (command "_.DDATTE" AAPT))
    ((= Q%Q "SPLINE") (command "_.SPLINEDIT" AAPT))
    ((= Q%Q "TOLERANCE")
     (if (wcmatch (getvar "acadver") "15*")
  (if (not DDMODIFYY)
    (load "ddmodifyy")
  (DDMODIFYY A1)
  (if (not DDMODIFY)
    (load "ddmodify")
  (DDMODIFY A1)
    ((or (= Q%Q "VERTEX")
  (= Q%Q "LWPOLYLINE")
  (= Q%Q "POLYLINE")
     (setq AA (entget (car AAA1)))
     (setq AAA (cdr (assoc 42 AA)))
     (if (= AAA 0)
    ((= Q%Q "INSERT")
     (setq Q%Q (cdr (assoc 0 AA)))
     (cond
     (= Q%Q "POLYLINE")
 (if (= AAA 0)
       (t
 (prompt "\n不能编辑及标注区块中之非线类")
    (t
  (setvar "blipmode" HOLDBLIP)
  (setvar "osmode" HOLDBLIP)
  (setvar "cmdecho" HOLDECHO)
发表于 2010-2-22 13:13:00 | 显示全部楼层
  (setvar "osmode" HOLDOSMODE)
把程序结尾修改一下
 楼主| 发表于 2010-2-22 21:01:00 | 显示全部楼层
原来是这样的,谢了。
发一个几年前的经典作品,适用于从未体验过批量处理快乐的新手。
高手不要看了。
GMT+8, 2025-12-18 03:50 , Processed in 0.175813 second(s), 26 queries , Gzip On.
