楼主: sachindkini
[基础] how to vector image in dcl
 楼主| 发表于 2010-4-12 19:22:00 | 显示全部楼层
  1. The following is a quotecaoyinStatements in 2010-4-12 15:48:00:
  2. From AutoCAD help file
  3. Draws a vector in the currently active dialog box image
  4. (Vector_image x1 y1 x2 y2 color)
  5. This function draws a vector in the currently active dialog box image (opened by start_image) from the point (x1, y1) to (x2, y2). The origin (0,0) is the upper-left corner of the image. You can obtain the coordinates of the lower-right corner by calling the dimension functions (dimx_tile and dimy_tile).
  6. Arguments
  7. x1
  8. X coordinate of the first point.
  9. y1
  10. Y coordinate of the first point.
  11. x2
  12. X coordinate of the second point.
  13. y2
  14. Y coordinate of the second point.
  15. color
  16. An AutoCAD color number, or one of the logical color numbers shown in the following table:
  17. Symbolic names for color attribute
  18. Color numberADI mnemonicDescription
  19. -2BGLCOLORCurrent background of the AutoCAD drawing area
  20. -15DBGLCOLORCurrent dialog box background color
  21. -16DFGLCOLORCurrent dialog box foreground color (text)
  22. -18LINELCOLORCurrent dialog box line color
  23. Return Values
  24. An integer representing the color of the vector.
  25. Examples
  26. (Setq color -2);; color of AutoCAD drawing area
  27. (Vector_image
  28. 0
  29. 0
  30. (Dimx_tile "slide_tile")
  31. (Dimy_tile "slide_tile")
  32. color
  33. )
  34. (End_image)
dear sir
thx for reply & u r time
very use full
how can sld file in store in vlx
 楼主| 发表于 2010-4-12 19:30:00 | 显示全部楼层
  1. The following is a quotefsxmStatements in 2010-4-12 17:18:00:
  2. [Em32] [em49] [em23]
  3. Please speak Chinese!
复制代码
Dear sir
sorry for my english
im not chinese im indian
im using google translate for see the site
发表于 2010-4-12 19:41:00 | 显示全部楼层
SLD file can't be stored in the VLX.
Usually people are by "Vector_image" function "draw" out of.
I'm sorry! My English is not good, So I can't explain in more detail!
 楼主| 发表于 2010-4-12 19:56:00 | 显示全部楼层
  1. The following is a quotecaoyinStatements in 2010-4-12 19:41:00:
  2. SLD file can't be stored in the VLX.
  3. Usually people are by "Vector_image" function "draw" out of.
  4. I'm sorry! My English is not good, So I can't explain in more detail!
复制代码
dear sir,
u written chinese
im using google transalte
some file found me share with u see attched file
发表于 2010-4-12 20:18:00 | 显示全部楼层
 sld file can not in store in vlx ,
It can add to DLL
发表于 2010-4-12 20:21:00 | 显示全部楼层
以下网址有很多 Vector_image 的用法,可以参考一下:
http://web2.airmail.net/terrycad/Tutorials/MyDialogs.htm
发表于 2010-4-13 11:19:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-4-13 11:39:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-4-13 11:42:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2010-4-13 12:53:00 | 显示全部楼层
  1. The following is a quoteliminnetStatements in 2010-4-13 11:39:00:
  2. [Upload = gif] UploadFile/2010-4/201041311392167653.gif, viewFile.asp? ID = 51392 [/ upload]
复制代码
Dear Sir
Thx for Reply
it's very good image file in dcl,
actual i want this type of dcl
how is create
plz sir u can share u r program
GMT+8, 2026-1-16 19:52 , Processed in 0.254709 second(s), 19 queries , Gzip On.
