查看: 1518|回复: 1
[求助]运行后选择集.count=0该怎么办
发表于 2010-4-11 21:23:00 | 显示全部楼层 |阅读模式
大家好!最近编的程序含选择集的部分如下所示。有两个问题请教高人:
(1)调试过程是用一个正方形和4个孤立点的。case 1的调试过程中,设置了Sset.count为参数,发现一直为0,不知道哪里出错?
(2)case 2运行中,jh_dian.count正常,大方向没问题。但粗线部分该怎么写啊?就是说令Shy=该图元的类型该用何语句?
在此先多谢各位不吝指教了!
Dim Sset As AcadSelectionSet
Dim insPoint As Variant
Dim KeyWord As String
On Error Resume Next
Set Sset = ThisDrawing.SelectionSets.Add("mky")
If Err Then
        Err.Clear
        Set Sset = ThisDrawing.SelectionSets.Item("mky")
        Sset.Clear
End If
'新建空选择集
ThisDrawing.Utility.InitializeUserInput 0, "1 2"
KeyWord = ThisDrawing.Utility.GetKeyword(vbCrLf & "选择选点方式1)在屏幕上直接指点;(2)一次性框选点 <1>")
If KeyWord = "" Then KeyWord = "1"
Select Case KeyWord
    Case "1"
        Do
            insPoint = ThisDrawing.Utility.GetPoint(, "请在屏幕上指定点(右键退出):")
            If Not (Err.Number = 13 Or Err.Number = -2145320928) Then
                Sset.Add insPoint
            End If
        Loop Until Err.Number = 13 Or Err.Number = -2145320928
        Err.Clear
    Case "2"
        Dim PointOBj As AcadBlockReference
        Dim Point As AcadPoint
        Dim TemPnt(0 To 1) As Double
        Dim jh_dian As AcadSelectionSet
        Call Addselection(jh_dian, "JH_Dian")
        Dim FilterType(6) As Integer
        Dim FilterData(6) As Variant
        Dim layername As String
        layername = ThisDrawing.ActiveLayer.Name
        FilterType(0) = -4
        FilterData(0) = "<and"
        FilterType(1) = -4
        FilterData(1) = "<or"
        FilterType(2) = 0
        FilterData(2) = "point"
        FilterType(3) = 2
        FilterData(3) = "block"
        FilterType(4) = -4
        FilterData(4) = "or>"
        FilterType(5) = 8
        FilterData(5) = layername
        FilterType(6) = -4
        FilterData(6) = "and>"
        ThisDrawing.Utility.Prompt vbCrLf + "请从屏幕上选取点!" + vbCrLf
        jh_dian.SelectOnScreen FilterType, FilterData
        Dim Sty As String
        Dim i As Long
        For i = 0 To (jh_dian.Count - 1)
        Sty = jh_dian.Item(i).HasExtensionDictionary
            If Sty = "Point" Then
                Set Point = jh_dian.Item(i)
                TemPnt(0) = Point.Coordinates(0)
                TemPnt(1) = Point.Coordinates(1)
            Else
                Set PointOBj = jh_dian.Item(i)
                TemPnt(0) = PointOBj.InsertionPoint(0)
                TemPnt(1) = PointOBj.InsertionPoint(1)
        End If
            Sset.Add TemPnt
        Next
        jh_dian.Delete
End Select
If Sset.Count = 0 Then
       Sset.Delete
       MsgBox "已选取 0 个点,不能生成表格。", vbExclamation
       Exit Sub
End If
ThisDrawing.Utility.Prompt vbCrLf + "命令:你在屏上选定了" & Sset.Count & "个坐标点 " + vbCrLf
发表于 2010-4-17 17:15:00 | 显示全部楼层
你的过滤器写的有问题,要选择的是什么样实体的?
GMT+8, 2026-1-18 04:18 , Processed in 0.141080 second(s), 24 queries , Gzip On.
