楼主: duotu007
[基础] 修改任何文字,已修改(DCL合并到LSP中)。
发表于 2011-4-28 02:06:44 | 显示全部楼层
目前开源中最强大的工具
发表于 2011-6-5 16:06:03 | 显示全部楼层
非常好使.非常好使.非常好使.
发表于 2011-6-6 18:08:11 | 显示全部楼层
多谢了,学习
发表于 2011-6-6 18:13:42 | 显示全部楼层
希望添加块文字和嵌套块文字的支持。
发表于 2011-6-7 09:36:10 | 显示全部楼层
这个确实不错,还是源码啊,哈哈,谢谢
发表于 2011-6-18 00:30:24 | 显示全部楼层
谢谢楼主分享,下载试用一下。
发表于 2011-6-20 00:11:31 | 显示全部楼层
下来学习谢谢!
发表于 2011-6-21 08:08:45 | 显示全部楼层
很实用的工具,下来学习学习
发表于 2011-7-25 16:47:43 | 显示全部楼层
这个不错,一直在用,呵呵
发表于 2011-7-26 00:27:32 | 显示全部楼层
;;; 修改过的文字编辑器.支持天正字体
(princ "\n修改文字已加载,启动命令GT.")
(defun ef:undobegin ()
  (setvar "CMDECHO" 0)
  (command "_.undo" "_group")
);_结束defun
(defun ef:undoend ()
  (command "_.undo" "_end")
);_结束defun
(defun c:Gt (/ dcl_id1 oba ob1 obn obt ptn otxt txt sty styno lay cyn layno hig wid ang col cnu etlst style layer)
  (vl-load-com)
  (setvar "cmdecho" 0)
  (graphscr)
  (ef:undobegin)
  (setq olderr *error*)
  (defun *error* (msg)
    (princ "\n*ERROR*...")
    (princ msg)
  );_结束defun error.
  (defun set_color (conm / costr)
    (defun map_color (ckey mno)
      (start_image ckey)
      (fill_image 0 0 (dimx_tile ckey) (dimy_tile ckey) mno)
      (end_image)
    );_结束defun_map_color
    (cond
      ((= 0 conm)
(setq costr "Byblock")
      ((= 1 conm)
(setq costr "Red")
      ((= 2 conm)
(setq costr "Yellow")
      ((= 3 conm)
(setq costr "Green")
      ((= 4 conm)
(setq costr "Cyan")
      ((= 5 conm)
(setq costr "Bule")
      ((= 6 conm)
(setq costr "Magenta")
      ((= 7 conm)
(setq costr "color")
      ((= 256 conm)
(setq costr "Bylayer")
      (t
(setq costr "")
    );_结束cond
    (cond
      ((= 0 col)
(map_color "col" 7)
      ((= 256 col)
(map_color "col" (cdr (assoc 62 (tblsearch "layer" lay))))
      (t
(map_color "col" conm)
    );_结束cond
    (if (= 256 conm)
      (set_tile "cnu" (strcat "<" (itoa (cdr (assoc 62 (tblsearch "layer" lay)))) ">" costr))
      (set_tile "cnu" (strcat "<" (itoa conm) ">" costr))
    );_结束if
  );_结束set_color
  (defun map_keylist (key keylst) ; set popuplist
    (start_list key)
    (mapcar
      'add_list
      keylst
    (end_list)
  );_结束map
  (defun layer_get_all (/ lay layer layname)
    (setq layer nil         ; all layer
   lay (tblnext "LAYER" t)
    (while (/= lay nil)
      (setq layname (cdr (assoc 2 lay))
     layer (cons layname layer)
      (setq lay (tblnext "LAYER"))
    (setq layer (acad_strlsort layer))
    layer  ; all layer.
  );_结束defun
  (defun style_get_all (/ sty style sty_list)
    (setq sty_list nil
   sty (tblnext "style" t)
    (setq style (cdr (assoc 2 sty)))
    (while style
      (if (/= "" style)
(setq sty_list (append
    sty_list
    (list style)
      );_结束if
      (setq sty (tblnext "style"))
    );_结束while
    (setq sty_list (acad_strlsort sty_list))
    sty_list
  );_结束defun
  (defun set_error (str)
    (set_tile "error" str)
  );_结束defun
  (defun sub_mtext (color entlist / ei newlist)
    (setq ei 0
   newlist nil
    (while (< ei (length entlist))
      (setq newlist (cons (nth ei entlist) newlist))
      (if (= 8 (car (nth ei entlist)))
(setq newlist (cons (cons 62 color) newlist))
      );_结束if
      (setq ei (1+ ei))
    );_结束while
    (reverse newlist)
  );_结束defun
  (setq ob1 (entsel "\n选择要修改的任何文本:"))
  (setq obn (car ob1)
ptn (car (cdr ob1))
  (setq obt (car (nentselp ptn)))
  (setq oba (cdr (assoc 0 (entget obt))))
  (if (or
(= oba "TEXT")
(= oba "MTEXT")
(= oba "ATTRIB")
(= oba "TCH_TEXT")
(= oba "TCH_MTEXT")
    (setq otxt (cdr (assoc 1 (entget obt))))
  );_结束if
  (if (= oba "ATTDEF")
    (setq otxt (cdr (assoc 2 (entget obt))))
  );_结束if
  (if otxt
      (setq sty (cdr (assoc 7 (entget obt)))
     lay (cdr (assoc 8 (entget obn)))
     hig (cdr (assoc 40 (entget obt)))
     ang (cdr (assoc 50 (entget obt)))
      );_结束setq
      (if (or
     (= oba "TEXT")
     (= oba "MTEXT")
     (= oba "ATTRIB")
   (setq col (cdr (assoc 62 (entget obt))))
   (setq wid (cdr (assoc 41 (entget obt))))
(setq col (cdr (assoc 62 (entget obn))))
      );_结束if
      (setq ang (* 180 (/ ang pi)))
      (if (or
     (= oba "TEXT")
     (= oba "MTEXT")
     (= oba "ATTRIB")
     (= oba "ATTDEF")
   (if (null col)
       (setq cyn 0)
       (setq col 256)
     (setq cyn 1)
   );_结束if
);_结束progn
      );_结束if
      (setq style (style_get_all))
      (setq layer (layer_get_all))
      (setq styno (- (length style) (length (member sty style))))
      (setq layno (- (length layer) (length (member lay layer))))
      (if (or
     (= oba "TEXT")
     (= oba "MTEXT")
     (= oba "ATTRIB")
     (= oba "ATTDEF")
   (setq dclname (cond
     ((setq tempname (vl-filename-mktemp "tt-dcl-tmp.dcl")
     filen (open tempname "w")
       (foreach stream '(
                                            "\n"
                                            "文字修改:dialog {\n"
                                            " label = \"文字编辑器...\";\n"
                                            " : boxed_radio_column {\n"
                                            "  label = \"文字编辑...\";\n"
                                            "  : edit_box {\n"
                                            "   label= \"文字:\";\n"
                                            "   key = \"text\";\n"
                                            "   edit_width = 50;\n"
                                            "  }\n"
                                            "  : row {\n"
                                            "   : popup_list {\n"
                                            "    label=\"样式\";\n"
                                            "    key = \"sty\";\n"
                                            "    edit_width = 13;\n"
                                            "    fixed_width = true;\n"
                                            "   }\n"
                                            "   : edit_box {\n"
                                            "    label=\"高度\";\n"
                                            "    key = \"hig\";\n"
                                            "    edit_width = 7;\n"
                                            "   }\n"
                                            "   : edit_box {\n"
                                            "    label=\"宽度\";\n"
                                            "    key = \"wid\";\n"
                                            "   }\n"
                                            "  }\n"
                                            "  : row {\n"
                                            "   : popup_list {\n"
                                            "    label=\"图层\";\n"
                                            "    key = \"lay\";\n"
                                            "   }\n"
                                            "   : image_button {\n"
                                            "    key = \"col\";\n"
                                            "    width= 4;\n"
                                            "    aspect_ratio = 0.75;\n"
                                            "   }\n"
                                            "   : text_part {\n"
                                            "    key = \"cnu\";\n"
                                            "    width= 12;\n"
                                            "   }\n"
                                            "   : edit_box {\n"
                                            "    label=\"角度\";\n"
                                            "    key = \"ang\";\n"
                                            "   }\n"
                                            "  }\n"
                                            "  spacer_1;\n"
                                            " }\n"
                                            " : row {\n"
                                            "  alignment = right;\n"
                                            "  : spacer {\n"
                                            "   width = 1;\n"
                                            "   }\n"
                                            "  ok_cancel;\n"
                                            " }\n"
                                            " errtile;\n"
                                            "}\n"
         (princ stream filen)
       (close filen)
       tempname
   );_结束cond
   );_结束setq
);_结束progn
   (setq dclname (cond
       (foreach stream '(
                       "\n"
                                            "文字修改:dialog {\n"
                                            "  : edit_box {\n"
                                            "  }\n"
                                            "  : row {\n"
                                            "   : popup_list {\n"
                                            "    label=\"样式\";\n"
                                            "    key = \"sty\";\n"
                                            "   }\n"
                                            "   : edit_box {\n"
                                            "    label=\"高度\";\n"
                                            "    key = \"hig\";\n"
                                            "   }\n"
                                            "  }\n"
                                            "  : row {\n"
                                            "   : popup_list {\n"
                                            "    label=\"图层\";\n"
                                            "    key = \"lay\";\n"
                                            "   }\n"
                                            "   : edit_box {\n"
                                            "    label=\"角度\";\n"
                                            "    key = \"ang\";\n"
                                            "   }\n"
                                            "  }\n"
                                            "  spacer_1;\n"
                                            " }\n"
                                            " : row {\n"
                                            "  : spacer {\n"
                                            "   width = 1;\n"
                                            "   }\n"
                                            "  ok_cancel;\n"
                                            " }\n"
                                            " errtile;\n"
                                            "}\n"
       (close filen)
       tempname
   );_结束cond
   );_结束setq
);_结束progn
      );_结束if
      (setq dcl_id1 (load_dialog dclname))
      (if (not (new_dialog "文字修改" dcl_id1))
(exit)
      );_结束if
      (if (or
     (= oba "TEXT")
     (= oba "MTEXT")
     (= oba "ATTRIB")
     (= oba "ATTDEF")
   (set_color col)
   (set_tile "wid" (rtos wid 2 3))
   (action_tile "wid" "(setq wid (distof $value))(if (>= 0 wid)(progn (mode_tile \"wid\" 3)(mode_tile \"wid\" 2)(set_error \"Input error ! \"))(set_error \"\"))")
   (action_tile "col" "(if (setq cnu (ACAD_ColorDlg col))(progn (setq col cnu)(set_color col)))")
);_结束prgon
      );_结束if
      (set_tile "text" otxt)
      (set_tile "hig" (rtos hig 2 2))
      (set_tile "ang" (rtos ang 2 2))
      (mode_tile "text" 2)
      (map_keylist "sty" style)
      (set_tile "sty" (itoa styno))
      (map_keylist "lay" layer)
      (set_tile "lay" (itoa layno))
      (action_tile "text" "(setq txt $value)")
      (action_tile "sty" "(setq styno (atoi $value))")
      (action_tile "hig" "(setq hig (distof $value))(if (>= 0 hig)(progn (mode_tile \"hig\" 3)(mode_tile \"hig\" 2)(set_error \"Input error ! \"))(set_error \"\"))")
      (action_tile "lay" "(setq layno (atoi $value))")
      (action_tile "ang" "(setq ang (distof $value))")
      (action_tile "accept" "(done_dialog 1)")
      (action_tile "cancel" "(done_dialog 0)")
      (if (= 1 (start_dialog))
(if txt
     (setq sty (nth styno style))
     (setq lay (nth layno layer))
     (setq ang (* (/ ang 180) pi))
     (setq etlst (entget obt))
       (setq etlst (subst
       (cons 2 txt)
       (assoc 2 etlst)
       etlst
       (setq etlst (subst
       (cons 1 txt)
       (assoc 1 etlst)
       etlst
     );_结束if
     (setq etlst (subst
     (cons 7 sty)
     (assoc 7 etlst)
     etlst
     (setq etlst (subst
     (cons 8 lay)
     (assoc 8 etlst)
     etlst
     (setq etlst (subst
     (cons 40 hig)
     (assoc 40 etlst)
     etlst
     (setq etlst (subst
     (cons 50 ang)
     (assoc 50 etlst)
     etlst
     (if (or
    (= oba "TEXT")
    (= oba "MTEXT")
    (= oba "ATTRIB")
    (= oba "ATTDEF")
  (setq etlst (subst
         (cons 41 wid)
         (assoc 41 etlst)
         etlst
  (if (= 1 cyn)
    (setq etlst (subst
    (cons 62 col)
    (assoc 62 etlst)
    etlst
    (if (= "MTEXT" oba)
      (setq etlst (sub_mtext col etlst))
      (setq etlst (cons (cons 62 col) etlst))
    );_结束if
  );_结束if
       );_结束progn
     );_结束if
     (entmod etlst)
     (entupd obt)
     (entupd obn)
   );_结束progn
);_结束if
      );_结束if
      (if (= 11 (start_dialog))
(command "_help")
      );_结束if
    );_结束progn
  );_结束if
  (setq *error* olderr)
  (ef:undoend)
  (unload_dialog dcl_id1)
  (vl-file-delete dclname)
  (setvar "cmdecho" 1)
);_结束defun
GMT+8, 2025-12-12 15:22 , Processed in 0.157369 second(s), 20 queries , Gzip On.
