楼主: tianyuan
[基础] [求助]求助一个根据距离提取坐标的程序
发表于 2010-10-9 16:37:00 | 显示全部楼层
  1. (defun c:tt(/ en d dist pt pts)
  2.   (vl-load-com)
  3. (setq en (car(entsel "\n选择要计算的曲线:")))
  4. (setq d (getreal "\n请输入间距:"))
  5.   (setq CurveLength (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)))
  6.   (setq dist d)
  7.   (while (< dist CurveLength)
  8.     (setq pt (vlax-curve-getPointAtDist en dist))
  9.     (setq pts (cons pt pts))
  10.     (setq dist (+ dist d))
  11.     )
  12.   ;;;坐标文件存放在我的文档,文件名 坐标.csv
  13.   (setq filename (strcat (getvar "mydocumentsprefix") "\\坐标.csv"))
  14.   (setq fn (open filename "w"))
  15.   (foreach coors pts
  16.     (princ (rtos (car coors) 1 3) fn)
  17.     (princ "," fn)
  18.     (princ (rtos (cadr coors) 1 3) fn)
  19.     (princ "," fn)
  20.     (princ "0.0" fn)
  21.     (princ "\n" fn)
  22.
  23.     )
  24.   (close fn)
  25.   (princ)
  26. )
 楼主| 发表于 2010-10-9 16:54:00 | 显示全部楼层
坐标值的格式不对,现在导出的格式为“
3.96E+07 4.15E+06
能不能把导出坐标格式改为 例如     5876423.231  414958761.624
发表于 2010-10-9 19:14:00 | 显示全部楼层
将(princ (rtos (car coors) 1 3) fn) 和(princ (rtos (cadr coors) 1 3) fn)改为(princ (rtos (car coors) 2 3) fn),(princ (rtos (cadr coors) 2 3) fn),请去学习一下rtos函数的用法!要学会编程,首先要熟练编程语言的基础语法和基础函数!
 楼主| 发表于 2010-10-11 09:31:00 | 显示全部楼层
谢谢Gu_xl
发表于 2010-11-2 06:45:00 | 显示全部楼层
  谢谢Gu_xl
来学习了,从中又领会到了一些东西
谢谢楼上与楼主
发表于 2012-7-9 20:39:06 | 显示全部楼层
今天看到这个帖子,也来好好的学习了一下.
GMT+8, 2025-12-17 22:18 , Processed in 0.177690 second(s), 19 queries , Gzip On.
