楼主: qcw911
[基础] 首尾相连的N条直线 选中其中任何一条都能选中N条线段 如何用lisp实现啊
发表于 2022-6-17 11:13:00 | 显示全部楼层
  1. (defun s2e(s / n lst)(if(=(type s)'pickset)(repeat(setq n(sslength s))(setq n(1- n)lst(cons(ssname s n)lst)))))
  2. (defun chains(es fuz / e a b s pts)
  3. (setq s(ssadd))
  4.   (while es
  5.     (setq e(car es)es(cdr es)
  6.           p1(mapcar'+'(0 0)(vlax-curve-getStartPoint e))p2(mapcar'+'(0 0)(vlax-curve-getendPoint e)))
  7.     (foreach a(S2E(ssget"CP"(list p1(list(car p1)(cadr p2))p2(list(car p2)(cadr p1)))'((0 . "arc,*spline,*polyline,line"))))
  8.       (or(SSMEMB a s)
  9.          ((lambda()
  10.             (setq p1(mapcar'+'(0 0)(vlax-curve-getStartPoint a))
  11.                   p2(mapcar'+'(0 0)(vlax-curve-getendPoint a)))
  12.             (and(vl-some'(lambda(x)(or(equal p1 x fuz)(equal p2 x fuz)))pt)
  13.                 (setq es(cons a es)pt(vl-list* p1 p2 pt))
  14.                 (ssadd a s)))))))
  15.   (sssetfirst'nil s))
  16. (defun c:tt()
  17.   (chains(s2e(ssget'((0 . "arc,*spline,*polyline,line"))))0.1))
发表于 2023-5-22 14:48:55 | 显示全部楼层
好程序,正在找一个能选择首尾相连线段的。
发表于 2024-6-29 23:04:39 | 显示全部楼层
得出的是空的,麻烦有时间看下
GMT+8, 2026-1-27 19:50 , Processed in 0.178969 second(s), 20 queries , Gzip On.
