查看: 3681|回复: 14
[下载][原创]cad看小说
发表于 2010-11-10 13:00:00 | 显示全部楼层 |阅读模式
最近亚运比较闲,做了个看小说的lsp,就是在命令行里阅读txt文档
欢迎大家下载使用
如果大家有意见可以提出,或自行修改
其实这个lisp是一个双击鼠标的反应器
加载后第一次双击会要求打开一txt文本
然后再双击则逐行在命令行显示文本内容
在c盘会有一个阅读记录,记录你当前阅读到第几行
方便下次接着看
中午上传得太仓促
(defun opentext()
写成了
(defun C:opentext()
我把阅读的时候设成了一次显示两行
如果想只显示一行,找到这句可以自行修改
(setq n 2);一次阅读的行数
;忙里偷闲看书器
(if vlr-mouse-reactor1 (vlr-remove vlr-mouse-reactor1))
(setq vlr-mouse-reactor1 (vlr-mouse-reactor "DATA" '((:vlr-beginDoubleClick . mouse))) )
(defun mouse (vlrobj Lst)
(IF txt_path
(princ "\n")
(repeat n
 (SETQ PRINC_TEXT NIL)
 (WHILE (= PRINC_TEXT NIL)
  (get_page)
  (SETQ txt_ID (OPEN txt_path "r"))
  (REPEAT page (SETQ WORD (read-line txt_ID)) )
  (if WORD
   (if (/= word "")
    (princ page)
    (princ word)
    (SETQ PRINC_TEXT "T")
   );end progn
   );end if
  );end if
  (CLOSE txt_ID )
  (princ "\n")
  (reading_record)
 );end while
);end repeat
(if (= word nil) (princ "\n你的文档已经阅读完毕!"))
(princ "\n")
);end progn
(opentext)
);end if
);end defun
(defun opentext()
(setq txt_path (getfiled "选择要阅读的小说" "C:/Temp/" "txt" 0))
(setq n 2);一次阅读的行数
(defun reading_record()
(SETQ temp1_ID (OPEN "C://阅读记录.txt" "r"))
(SETQ temp2_ID (OPEN "C://temp.txt" "w"))
(if temp1_ID
(while (/= (SETQ TXT (read-line temp1_ID)) NIL)
 (IF (/= TXT "")
 (WRITE-LINE TXT temp2_ID)
);end while
);end if
(if temp1_ID (CLOSE temp1_ID ) )
(if temp2_ID (CLOSE temp2_ID ) )
(SETQ temp1_ID (OPEN "C://阅读记录.txt" "w"))
(SETQ temp2_ID (OPEN "C://temp.txt" "r"))
(setq txt_name (car (cdr (fnsplitl txt_path))))
(setq txt_record nil)
(if temp2_ID
 (while (/= (SETQ TXT (read-line temp2_ID)) NIL)
 (IF (/= TXT "")
 (PROGN
  (if (AND (vl-string-search txt_name TXT) (= txt_record nil) )
   (WRITE-LINE (STRCAT txt_name (ITOA page) ) temp1_ID)
   (setq txt_record "t")
   );end progn
   (WRITE-LINE TXT temp1_ID)
  );end if
 );END PROGN
 );END IF
 );end while
);end if
(if (= txt_record nil) (WRITE-LINE (STRCAT txt_name (ITOA page) ) temp1_ID) )
(vl-file-delete "C://temp.txt")
);end defun
(defun get_page()
(setq page nil)
(if temp1_ID
  (IF (vl-string-search txt_name TXT)
  (setq page (ATOI (SUBSTR TXT (1+ (STRLEN txt_name)))) )
 );end while
);end if
(IF (= page NIL)
(SETQ page 0)
(SETQ page (1+ page))
);end if
);end defun
发表于 2010-11-10 19:41:00 | 显示全部楼层
什么?没看明白,干什么用的?
发表于 2010-11-12 19:46:00 | 显示全部楼层
太不错了,牛人,什么时候弄个更好玩的出来玩玩,像QQ之类的是最好了。
发表于 2010-11-13 10:16:00 | 显示全部楼层
很有创意,适合上班族!
啥时 再弄个 局域网 聊天器?
这个是能搞出来的  发表于 2011-9-13 21:50
发表于 2011-4-21 17:25:30 | 显示全部楼层
怎么关闭这个反应器啊
发表于 2011-4-21 17:35:19 | 显示全部楼层
回复 egos 的帖子
把CAD关了
发表于 2011-4-21 23:14:18 | 显示全部楼层
这个东东好,谢谢楼主
发表于 2011-4-28 18:54:19 | 显示全部楼层
如何用呀,说清楚点好吗,好像不能用啊
发表于 2011-4-29 01:01:07 | 显示全部楼层
很有创意,适合上班族
GMT+8, 2025-7-19 05:30 , Processed in 0.192925 second(s), 33 queries , Gzip On.
