- 积分
- 26077
- 明经币
- 个
- 注册时间
- 2003-6-27
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2011-2-11 09:56:53
显示全部楼层
 - using aApp = Autodesk.AutoCAD.ApplicationServices.Application;
- using aPolyline = Autodesk.AutoCAD.DatabaseServices.Polyline;
- public class sPolylineJig : EntityJig
- /// <summary>
- /// 模拟AutoCAD画多义线命令Polyline
- /// </summary>
- static public void DrawPolylineJig()
- try
- Editor ced = aApp.DocumentManager.MdiActiveDocument.Editor;
- Database cdb = aApp.DocumentManager.MdiActiveDocument.Database;
- Autodesk.AutoCAD.DatabaseServices.TransactionManager ctm = aApp.DocumentManager.MdiActiveDocument.Database.TransactionManager;
- PromptPointOptions opts = new PromptPointOptions("\nStart Point :");
- PromptPointResult res = ced.GetPoint(opts);
- if (res.Status != PromptStatus.OK) return;
- Point3dCollection p3ds = new Point3dCollection();
- p3ds.Add(res.Value);
- sPolylineJig jig = new sPolylineJig(p3ds);
- sPolylineJig jig_bake = jig;
- int pcount = p3ds.Count;
- ced.Drag(jig);
- while (jig.Status == 1)
- jig_bake = jig;
- p3ds = new Point3dCollection();
- for (int i = 0; i <= pcount; i++)
- p3ds.Add(((aPolyline)jig.Entity).GetPoint3dAt(i));
- jig = new sPolylineJig(p3ds);
- pcount += 1;
- ced.Drag(jig);
- if (jig.Status == 0)
- return;
- if (jig.Status == 2)
- ((aPolyline)jig_bake.Entity).Closed = true;
- using (Transaction ctrans = ctm.StartTransaction())
- BlockTable cbt = (BlockTable)ctm.GetObject(cdb.BlockTableId, OpenMode.ForRead, false);
- BlockTableRecord cbtr = (BlockTableRecord)ctm.GetObject(cbt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
- cbtr.AppendEntity(jig_bake.GetEntity());
- ctm.AddNewlyCreatedDBObject(jig_bake.GetEntity(), true);
- ctrans.Commit();
- jig_bake.Entity.Dispose();
- jig.Entity.Dispose();
- p3ds.Dispose();
- catch (System.Exception ex)
- Debug.WriteLine("\n" + ex.Message);
- static public aPolyline GetPolylineJig()
- return sPolylineJig.GetPolylineJig(Point3d.Origin, 0);
- static public aPolyline GetPolylineJig(Point3d basePoint, int index)
- try
- switch (index)
- case 0:
- break;
- default:
- p3ds.Add(basePoint);
- break;
- bool continuous = true;
- while (continuous)
- ced.Drag(jig);
- if (jig.Status == 1)
- jig_bake = jig;
- pcount += 1;
- else
- continuous = false;
- return null;
- p3ds.Dispose();
- return (aPolyline)jig_bake.Entity;
- return null;
- Point3d _EndPoint, _StartPoint;
- int _Status = 1;
- public sPolylineJig(Point3dCollection p3ds)
- : base(new aPolyline())
- ////注意: 在此不能用aPolyline作为基类,原因是aPolyline无法初始化,
- ////而对aPolyline的操作基本上都是要求实体已经实例化,在DataBase已经有记录
- ////但aPolyline的结果在外面表示就是LWPolyline
- try
- for (int i = 0; i < p3ds.Count; i++)
- ((aPolyline)Entity).AddVertexAt(i, new Point2d(p3ds.X, p3ds.Y), 0, 0, 0);
- ((aPolyline)Entity).AddVertexAt(p3ds.Count, new Point2d(p3ds[p3ds.Count - 1].X, p3ds[p3ds.Count - 1].Y), 0, 0, 0);
- pcount = p3ds.Count;
- _EndPoint = p3ds[p3ds.Count - 1];
- _StartPoint = _EndPoint;
- private int pcount = 0;
- protected override bool Update()
- try
- ((aPolyline)Entity).SetPointAt(pcount, new Point2d(_EndPoint.X, _EndPoint.Y));
- return false;
- return true;
- protected override SamplerStatus Sampler(JigPrompts prompts)
- try
- JigPromptPointOptions jigopts = new JigPromptPointOptions();
- jigopts.UserInputControls = UserInputControls.NullResponseAccepted;
- jigopts.BasePoint = _StartPoint;
- jigopts.UseBasePoint = true;
- jigopts.Keywords.Add("Close");
- jigopts.Message = "\nNext Point [Close]:";
- PromptPointResult dres = prompts.AcquirePoint(jigopts);
- if (dres.Value != _EndPoint)
- _EndPoint = dres.Value;
- else
- return SamplerStatus.NoChange;
- if (dres.StringResult == "Close")
- _Status = 2;
- return SamplerStatus.Cancel;
- if (dres.Status == PromptStatus.Cancel || dres.Status == PromptStatus.Error)
- _Status = 0;
- else if (dres.Status == PromptStatus.None)
- _Status = 3;
- else
- return SamplerStatus.OK;
- public int Status { get { return _Status; } }
- public Entity GetEntity()
- return Entity;
