- 积分
- 75936
- 明经币
- 个
- 注册时间
- 2001-6-7
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
Public Sub Use3PDimAngle()
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex As Variant
Dim FirstPoint As Variant, SecondPoint As Variant
Dim TextPoint As Variant
' Define the new Dim3PointAngular object
'AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
'FirstPoint(0) = 50: FirstPoint(1) = 50: FirstPoint(2) = 0
'SecondPoint(0) = 50: SecondPoint(1) = 100: SecondPoint(2) = 0
'TextPoint(0) = 150: TextPoint(1) = 150: TextPoint(2) = 0
AngleVertex = ThisDrawing.Utility.GetPoint(, "选择第1个点:")
FirstPoint = ThisDrawing.Utility.GetPoint(, "选择第2个点:")
SecondPoint = ThisDrawing.Utility.GetPoint(, "选择第3个点:")
'TextPoint = ThisDrawing.Utility.GetPoint(SecondPoint, "选择文字位置:")
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
'ZoomAll
'MsgBox "A Dim3PointAngular object has been created."
End Sub
Public Sub DimAngular()
Dim entObj1 As AcadEntity
Dim pickPnt1 As Variant
Dim oldOSMODE As Integer
'选择被标注多义线的第1个标注边
ThisDrawing.Utility.GetEntity entObj1, pickPnt1, "选择被标注对象:"
If StrComp(entObj1.ObjectName, "AcDbPolyline", 1) <> 0 Then
MsgBox "选择的图元不是多义线,程序将退出!"
Exit Sub
End If
Dim vetexCount As Integer '多义线顶点数
Dim sVetex As Variant '始顶点坐标
Dim eVetex As Variant '终顶点坐标
'先求出顶点的元素数
vetexCount = UBound(entObj1.Coordinates)
'求顶点个数
vetexCount = (vetexCount + 1) / 2
'准备判断第1个顶点和最后一个顶点是否重合
sVetex = entObj1.Coordinate(0)
eVetex = entObj1.Coordinate(vetexCount - 1)
'求多义线非自动闭合时的实际顶点个数
If sVetex(0) = eVetex(0) And sVetex(1) = eVetex(1) Then
vetexCount = vetexCount - 1
End If
oldOSMODE = ThisDrawing.GetVariable("OSMODE")
ThisDrawing.SetVariable "OSMODE", 512
Dim dimPnt1 As Variant, dimPnt2 As Variant
dimPnt1 = ThisDrawing.Utility.GetPoint(, "选择第一个标注点:")
dimPnt2 = ThisDrawing.Utility.GetPoint(, "选择第二个标注点:")
Dim I As Integer, J As Integer
Dim lineObj1 As AcadLine
Dim lineObj2 As AcadLine
Dim sPnt(0 To 2) As Double
Dim ePnt(0 To 2) As Double
Dim X As String, Y As String
On Error Resume Next
'判断第一条临时直线的交点落在多义线的哪条边上
For I = 0 To vetexCount - 2
sVetex = entObj1.Coordinate(I)
eVetex = entObj1.Coordinate(I + 1)
Y = (dimPnt1(1) - sVetex(1)) / (eVetex(1) - sVetex(1))
X = (dimPnt1(0) - sVetex(0)) / (eVetex(0) - sVetex(0))
'MsgBox "X1 = " & X & Chr(13) & "Y1 = " & Y
If StrComp(X, Y, 1) = 0 Then
sPnt(0) = sVetex(0): sPnt(1) = sVetex(1): sPnt(2) = 0
ePnt(0) = eVetex(0): ePnt(1) = eVetex(1): ePnt(2) = 0
Set lineObj1 = ThisDrawing.ModelSpace.AddLine(sPnt, ePnt)
lineObj1.Visible = False
GoTo lineMark1
End If
Next
End If
lineMark1:
Y = (dimPnt2(1) - sVetex(1)) / (eVetex(1) - sVetex(1))
X = (dimPnt2(0) - sVetex(0)) / (eVetex(0) - sVetex(0))
'MsgBox "X2 = " & X & Chr(13) & "Y2 = " & Y
Set lineObj2 = ThisDrawing.ModelSpace.AddLine(sPnt, ePnt)
lineObj2.Visible = False
GoTo lineMark2
End If
Next
End If
lineMark2:
Dim dimObj As AcadDimAngular
Dim insectVert As Variant
Dim angVert(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double
Dim SecondPoint(0 To 2) As Double
'求第二和第三条临时直线的交点,此交点
'就是要标注的2条边的角度标注的标注顶点
insectVert = lineObj1.IntersectWith(lineObj2, acExtendBoth)
'删除已不用的临时线
lineObj1.Delete
lineObj2.Delete
ThisDrawing.SetVariable "OSMODE", oldOSMODE
'确定角度标注的顶点
angVert(0) = insectVert(0)
angVert(1) = insectVert(1)
angVert(2) = insectVert(2)
'确定第一条标注边上的标注点
FirstPoint(0) = dimPnt1(0)
FirstPoint(1) = dimPnt1(1)
FirstPoint(2) = dimPnt1(2)
'确定第二条标注边上的标注点
SecondPoint(0) = dimPnt2(0)
SecondPoint(1) = dimPnt2(1)
SecondPoint(2) = dimPnt2(2)
'确定标注文字的位置
TextPoint = ThisDrawing.Utility.GetPoint(SecondPoint, "选择标注文字位置:")
'创建角度尺寸标注对象
Set dimObj = ThisDrawing.ModelSpace.AddDimAngular(angVert, FirstPoint, SecondPoint, TextPoint)
'ZoomAll
End Sub
Public Sub Add5PointDimAngular()
Dim dPnt1 As Variant, dPnt2 As Variant
Dim dPnt3 As Variant, dPnt4 As Variant
'保存原目标捕捉的设定
'设定自动捕捉图元对象上的最近点
'选择第1条尺寸界线上的第1个标注点
dPnt1 = ThisDrawing.Utility.GetPoint(, "选择界线1标注点1:")
'选择第1条尺寸界线上的第2个标注点
dPnt2 = ThisDrawing.Utility.GetPoint(dPnt1, "选择界线1标注点2:")
'选择第2条尺寸界线上的第1个标注点
dPnt3 = ThisDrawing.Utility.GetPoint(, "选择界线2标注点1:")
'选择第2条尺寸界线上的第2个标注点
dPnt4 = ThisDrawing.Utility.GetPoint(dPnt3, "选择界线2标注点2:")
Dim lineObj1 As AcadLine, lineObj2 As AcadLine
Dim insectPnt As Variant
'创建第1条临时尺寸界线
Set lineObj1 = ThisDrawing.ModelSpace.AddLine(dPnt1, dPnt2)
lineObj1.Visible = False '将其设为不可见
'创建第2条临时尺寸界线
Set lineObj2 = ThisDrawing.ModelSpace.AddLine(dPnt3, dPnt4)
'求出2条临时尺寸界线的交点,即标注顶点angVert
insectPnt = lineObj1.IntersectWith(lineObj2, acExtendBoth)
'恢复原来的目标捕捉设定
'删除2条临时尺寸界线
lineObj1.Delete
lineObj2.Delete
'选定标注文字的显示位置
TextPoint = ThisDrawing.Utility.GetPoint(dPnt4, "选择标注文字位置:")
'用dPnt1点作为FirstPoint点,dPnt3点作为SecondPoint点
Set dimObj = ThisDrawing.ModelSpace.AddDimAngular(insectPnt, dPnt1, dPnt3, TextPoint)
dimObj.AngleFormat = acRadians
End Sub |
