查看: 2929|回复: 9
如何用radio_button控制edit_box的值实时更新
发表于 2011-4-1 16:07:47 | 显示全部楼层 |阅读模式
请教各位,如何用radio_button控制edit_box的值实时更新,如图
(defun c:www()
   (setvar "cmdecho" 0)
   (setq dcl_id (load_dialog "tt"))
   (new_dialog "tt" dcl_id)
   (setq defkey1 "rb11" defkey2 "rb21")
   (set_tile defkey1 "1")
   (set_tile defkey2 "1")
   (setq name(get_attr defkey1 "label"))
   (setq ssca(get_attr defkey2 "label"))
   (action_tile "rb11" "(setq name(get_attr $key \"label\"))")
   (action_tile "rb12" "(setq name(get_attr $key \"label\"))")
   (action_tile "rb13" "(setq name(get_attr $key \"label\"))")
   (action_tile "rb14" "(setq name(get_attr $key \"label\"))")
   (action_tile "rb21" "(setq ssca(get_attr $key \"label\"))")
   (action_tile "rb22" "(setq ssca(get_attr $key \"label\"))")
   (action_tile "rb23" "(setq ssca(get_attr $key \"label\"))")
   (action_tile "rb24" "(setq ssca(get_attr $key \"label\"))")
   (action_tile "rb25" "(setq ssca(get_attr $key \"label\"))")
   (action_tile "ins_ok" "(done_dialog 1)")
   (set_tile "dwgnum" (strcat name ssca))
   ;(setq txt (get_tile "dwgnum"))
   (setq dd(start_dialog))
   (if (= dd 1)
(setq p1 (getpoint  "\n 第一点:"))
(setvar "osmode" 0)
(command "ortho" "off")
(setq p2 (getpoint p1 "\n 第二点:"))
(command "ortho" "on")
(setq p3 (getpoint p2 "\n 第三点:"))
(if (= (tblsearch "layer" "尺寸线层") nil)(new_lay "尺寸线层"   4    "CONTINUOUS"))
(setvar "clayer" "尺寸线层")
(if (= p3 nil)
     ;(command  "leader"   p1 p2  "" txt "")
     ;(command  "leader"   p1 p2 p3 ""  txt "")
     (command  "leader"   p1 p2  "" (strcat name ssca) "")
     (command  "leader"   p1 p2 p3 ""  (strcat name ssca) "")
   两个radio_button的选择改变时set_tile "dwgnum" 的值同时实时更新,最后将值传回给txt
不知道要如何控制它才能实现实时更新
发表于 2011-4-1 20:35:28 | 显示全部楼层
1、在对话框中定义key
如:
:radio_column{
key="type";
value="a0";
:radio_button{label="1/8";key="a0";}
:radio_button{label="1/4";key="a1";}
:radio_button{label="3/8";key="a2";}
:radio_button{label="1/2";key="a3";}
:radio_button{label="3/4";key="a4";}
在程序中
(action_tile "type" "(chedit &value)")
(defun chedit (a)
(setq b
  (cond
   ((= a "a0") "PT1/8")
   ((= a "a1") "PT1.4")
(settile "gyxh" b)
发表于 2011-12-26 00:35:19 | 显示全部楼层
我这是图层的控制,墙体是新建图层,然后旁边那个是控制他的显示和隐藏 冻结属性,请问应该怎么去做
发表于 2011-12-26 20:10:23 | 显示全部楼层
每行后面都加上"(set_tile \"dwgnum\" (strcat name ssca))"
发表于 2011-12-27 21:53:37 | 显示全部楼层
   (action_tile "rb12" "(setq name(get_ ...
QQ:342670425,求加友请教LISP&DCL
发表于 2012-3-6 09:13:08 | 显示全部楼层
zzxxqq,请写出此贴的完整LISP代码,我只能实现单个单选按钮框的实时变化,无法将其两者联系出来,两个一起的话就不能实时了
发表于 2012-5-29 12:54:46 | 显示全部楼层
发表于 2012-6-2 20:35:39 | 显示全部楼层
看得我都不好意思说了
发表于 2013-3-11 11:17:05 | 显示全部楼层
楼主 你的这功能实现了没?能否给参照学习一下qq:328302216  邮箱328302216@qq.com
发表于 2013-3-12 01:13:57 | 显示全部楼层
类似如下效果吧
GMT+8, 2025-8-27 04:10 , Processed in 0.179075 second(s), 26 queries , Gzip On.
