楼主: 啵浪鼓
列出所有图层
发表于 2011-4-7 19:51:30 | 显示全部楼层
6楼的就是VLSP 代码
LSP参见5楼
发表于 2011-4-7 20:11:32 | 显示全部楼层
(defun get-layerobj (layer / lays layobj)
  (setq        lays (vla-get-layers
               (vla-get-activedocument (vlax-get-acad-object))
  (vlax-for layerob lays
    (if        (= (vla-get-name layerob) layer)
      (setq layobj layerob)
  layobj
(defun get-layer-s (layobj)
  (setq freeze (vla-get-freeze layobj))
  (setq lock (vla-get-lock layobj))
  (setq layeron (vla-get-layeron layobj))
  (if (= freeze :vlax-true) (setq st1 "冻结着")(setq st1 ""))
  (if (= lock :vlax-true) (setq st2 "锁着")(setq st2 ""))
  (if (= layeron :vlax-true) (setq st3 "")(setq st3 "关着"))
  (princ(strcat"图层" st1 st2 st3))
例:(get-layer-s(get-layerobj"BP"))
 楼主| 发表于 2011-4-7 21:15:31 | 显示全部楼层
1,上面程序区分大小写?
2,我只想知道如图层 dim 层返回值是 freeze layoff laylock,想改一下上面的程序,居然无计可施
:vlax-true 这是什么东东啊,只接触过lisp没接触过vlisp,,,上面的程序好难懂,哈哈
发表于 2011-4-10 20:06:03 | 显示全部楼层
不是“冻结着,锁着,关着"吗?
冻结着-freeze
锁着---laylock
关着---layoff
发表于 2011-4-10 20:16:14 | 显示全部楼层
要区分大小写(图层名)
  layobj
  (if (= freeze :vlax-true) (setq st1 "FREEZE")(setq st1 ""))
  (if (= lock :vlax-true) (setq st2 "LOCK")(setq st2 ""))
  (if (= layeron :vlax-true) (setq st3 "")(setq st3 "LAYERON"))
  (list st1 st2 st3)
例:(get-layer-s (get-layerobj  "dim"))
返回 ("FREEZE" "LOCK" "LAYERON")
发表于 2011-4-10 20:23:26 | 显示全部楼层
:vlax-true----真
:vlax-false----假
GMT+8, 2025-12-18 11:36 , Processed in 0.161105 second(s), 19 queries , Gzip On.
