楼主: chlh_jd
[函数] 单选图块在位图元
发表于 2018-1-11 17:52:44 | 显示全部楼层
修改如下可出现不在原位置情况:
  1. ;;; Nentsel
  2. ;;; function : to nentsel a entity In situ
  3. ;;; arg      : string to princ in command-line
  4. ;;; return   : a list ( ename point is-of-block? )
  5. ;;; Note     : if the ename is of a block , the routine copy a similar entity , so you must entdel it later
  6. ;;; by GSLS(SS)
  7. ;;;
  8. (defun ss-Nentsel (msg / en en1 pt mat ins mat ent)
  9.   (setq en (Nentsel msg))
  10.   (if (= (length en) 4)
  11.     (progn
  12.       (setq en1        (car en)
  13.             ang       (cdr (assoc 50 (entget (last en))))
  14.             pt        (cadr en)
  15.             mat        (caddr en)
  16.             ins        (last mat)
  17.             mat        (reverse (cdr (reverse mat)))
  18.             mat        (append
  19.                   (mapcar '(lambda (x y)
  20.                              (append x (list y))
  21.                            )
  22.                           mat
  23.                           ins
  24.                   )
  25.                   '((0. 0. 0. 1.))
  26.                 )
  27.             ent        (entget en1 '("*"))
  28.             ent        (vl-remove (assoc -1 ent) ent)
  29.             en1        (entmakex ent)
  30.       )
  31.       (if en1
  32.         (progn
  33.           (setq obj (vlax-ename->vla-object en1))
  34.           (vla-TransformBy obj (vlax-tmatrix mat))
  35.           (vla-Rotate Obj (vlax-3d-point ins) (* 2.0 ang))
  36.           (setq en1 (vlax-vla-object->ename obj))
  37.         )
  38.       )
  39.       (list en1 pt T)
  40.     )
  41.     (append en (list nil))
  42.   )
  43. )
GMT+8, 2026-1-20 11:53 , Processed in 5.195616 second(s), 19 queries , Gzip On.
