查看: 5839|回复: 4
[讨论] 求CAD图纸合并的LISP程序
发表于 2011-4-18 20:39:03 | 显示全部楼层 |阅读模式
谁有把多张CAD图纸合并到一张图纸文件的LISP程序吗?最好能按文件名顺序排列在一张图纸上,先表感谢!
因工作原因,经常需要把多张相同格式的图纸合并到一张图纸上,便于一起修改和打印,一个个拖拉或插入较麻烦。但本人只会编写简单一些的LISP应用程序,在网站搜寻一下,也没找到合适的,哪位同仁有的话,可以共享一下吗?
发表于 2013-1-22 21:20:37 | 显示全部楼层
源代码,我不会用,你们看看
(defun c:mlpt (/ distx disty ent file files maxpoint minpoint path pmax
          pmin pt1 pt2 sca
(command ".UNDO" "BE")
  (setq sca (getvar "dimscale"))
  (setq cmd (getvar "cmdecho"))
  (setq oldos (getvar "OSMODE"))
  (setvar "cmdecho" 0)
  (setvar "OSMODE" 0)
   (getstring "\n本程序将合并指定目录内的所有文件,执行速度较慢,请耐心等待。回车继续...")
  (setq pt2 (getpoint "\n请选择插入点:"))
  (setq path (browseforfolder "请选择要合并图纸的目录"))
  (if (/= path nil)
      (if (/= (substr path (strlen path) 1) "\\")
  (setq path (strcat path "\\"))
      (setq files (vl-directory-files path "*.dwg" 0))
      (while files
  (setq file (strcat path (car files)));;;  (princ file)
;;;  (princ "\n")
  (command "-INSERT" file pt2 1 1 0)
  (setq ent (entlast));;;  (princ ent)
  (vla-getboundingbox (vlax-ename->vla-object ent) 'minpoint 'maxpoint)
  (setq pmax (vlax-safearray->list maxpoint)
        pmin (vlax-safearray->list minpoint)
  (setq distx (- (car pmax) (car pmin)))
  (setq disty (- (cadr pmax) (cadr pmin)))
  (setq pt1 (list (car pmax) (cadr pmin)))
  (command "move" ent "" pt1 pt2)
  (command "EXPLODE" ent "")
  (setq pt2 (polar pt2 (/ pi 2) (+ disty (* 40 sca))))
  (setq files (cdr files))
  (setvar "OSMODE" oldos)
  (setvar "CMDECHO" cmd)
  (command ".UNDO" "E")
;;; [功能] 以目录树方式浏览文件夹并返回路径
;;; [参数] msg---提示信息
;;; [返回] 文件夹路径,如果选择了cancel, 返回nil
;;; [测试] (browseforfolder "选择文件保存路径: ")
(defun browseforfolder (msg / shfolder path catchit)
  (setq shfolder (vlax-invoke-method (vlax-create-object "Shell.Application")
         'browseforfolder
         (vlax-get-property
       (vlax-get-acad-object)
       'hwnd
         ) msg 1
catchit (vl-catch-all-apply '(lambda ()
           (setq shfolder
          (vlax-get-property shfolder
        'self
          path
        'path
  (if (vl-catch-all-error-p catchit)
    nil
    path
发表于 2012-12-20 16:01:28 | 显示全部楼层
我也想要,楼主现在解决没有哦
发表于 2012-12-20 16:10:30 | 显示全部楼层
longer1000 发表于 2012-12-20 16:01
我也想要,楼主现在解决没有哦
发个批量插图程序[2012.12.20]
http://bbs.mjtd.com/thread-99685-1-1.html
发表于 2016-6-29 16:06:15 | 显示全部楼层
学习学习  谢谢分享
GMT+8, 2026-1-21 04:31 , Processed in 0.165413 second(s), 27 queries , Gzip On.
