楼主: tjuzkj
标注随层,该怎么编写?
发表于 2012-4-28 18:50:01 来自手机 | 显示全部楼层
亦在求解。
发表于 2012-4-28 19:12:32 | 显示全部楼层
(setq EN (entsel "\n选择标注对象: ")
        OBJ (vlax-ename->vla-object(car EN))
(vla-put-dimensionlineColor OBJ 256)
(vla-put-extensionlineColor OBJ 256)
(vla-put-textColor OBJ 256)
发表于 2012-4-30 11:52:26 | 显示全部楼层
;;标注随层
(defun c:sc ()
  (setq ss (ssget '((0 . "DIMENSION"))))
  (setq n 0)
  (repeat (sslength ss)
    (setq EN  (cdr (assoc -1 (entget (ssname ss n)))))
    (setq OBJ (vlax-ename->vla-object  EN))
(princ en)
    (setq n (1+ n))
发表于 2012-4-30 12:03:14 | 显示全部楼层
MaKaiJin 发表于 2011-11-8 08:45
(setq ss (ssget "X" '((0 . "DIMENSION"))))
(command "Chprop" ss "" "LA" "标注层" "")
(defun c:dimoe()
(command "_dimordinate" pause pause)
这个可以行
GMT+8, 2025-12-18 17:07 , Processed in 0.140371 second(s), 19 queries , Gzip On.
