楼主: vbyu1987
[讨论] 请教皮带轮做图的autolisp程序
发表于 2011-5-27 08:01:45 | 显示全部楼层
xyp1964 发表于 2011-5-27 00:12
显摆也得靠本领和资本!
对于你的水平还真得佩服,但有时候对待新人还是得授之以“渔”;
发表于 2011-5-27 08:04:12 | 显示全部楼层
这是对院长的褒奖啊,院长误会了?
 楼主| 发表于 2011-5-27 09:39:37 | 显示全部楼层
看来你文学功底也很深厚阿,
院长不错的,还把源码贴了出来,虽然我看不懂
发表于 2011-5-27 11:16:47 | 显示全部楼层
  1. (defun c:test ()
  2.   (setq od (getdist "\n 输入皮带轮外径:"))
  3.   (setq h (getdist "\n 输入轮齿高度:"))
  4.   (setq n (getint "\n 输入皮带轮齿数:"))
  5.   (setq rw (getdist "\n 输入皮带轮根部宽度:"))
  6.   (setq sa (getangle "\n 输入皮带轮齿夹角:")) ;返回弧度值
  7.   (setq rr (getdist "\n 输入根部倒圆角:"))
  8.   (setq tipr (getdist "\n 输入顶部倒圆角:"))
  9.   (setq p0 (getpoint "\n 输入一个中心点:"))
  10.   (setq os (getvar "osmode"))
  11.   (setvar "osmode" 0)  ;捕捉设置为0
  12.   (SETVAR "CMDECHO" 0)
  13.   (command "undo" "g")
  14.   (setq js (* Pi 0.5))
  15.   (setq pt1 (polar p0 js (/ od 2)))
  16.   (setq rota (/ (* (/ 180 n) pi) 180))        ;rota单齿一半的角度(弧度)
  17.   (setq pt2 (polar p0 (- js rota) (/ od 2)))
  18.   (setq pt3 (polar pt1 (* pi 1.5) H))        ;根部起点pt3的坐标
  19.   (setq pt4 (polar pt3 0 (* rw 0.5)))        ;根部终点pt4的坐标
  20.   (setq pt5 (polar pt4 (- js (* sa 0.5)) (* H 1.1)));齿侧直线终点pt5坐标
  21.   (command "arc" pt2 "c" p0 pt1)        ;绘制外径弧线pt2pt1
  22.   (setq en1 (entlast))                        ;保存弧线pt2pt1为en1
  23.   (command "line" pt3 pt4 "")                ;绘制根部直线
  24.   (setq en2 (entlast))                        ;保存直线pt3pt4为en2
  25.   (command "line" pt4 pt5 "")                ;齿侧直线pt4pt5
  26.   (setq p45 (mapcar '(lambda (a b) (/ (+ a b) 2)) pt4 pt5))
  27.   (setq en3 (entlast))                        ;保存齿侧直线pt4pt5为en3
  28.   (command "fillet"
  29.            "r"
  30.            rr
  31.            "fillet"
  32.            (list en2 pt3)
  33.            (list en3 p45)
  34.   )                                        ;绘制根部倒圆角
  35.   (setq en4 (entlast))
  36.   (command "fillet"
  37.            "r"
  38.            tipr
  39.            "fillet"
  40.            (list en3 p45)
  41.            (list en1 pt2)
  42.   )                                        ;绘制顶部倒圆角
  43.   (setq        en5 (entlast)
  44.         ent en5
  45.   )
  46.   (setq ss nil)
  47.   (setq ss (ssadd))
  48.   (command "mirror" en1 en2 en3 en4 en5 "" pt1 pt3 "n")
  49.   (while (setq ent (entnext ent))
  50.     (ssadd ent ss)
  51.   )
  52.   (command "-array" en1 en2 en3 en4 en5 ss "" "p" p0 n "" "")
  53.   (setvar "osmode" os)
  54.   (command "undo" "e")
  55.   (SETVAR "CMDECHO" 1)
  56.   (princ)
  57. )
GMT+8, 2025-12-18 17:05 , Processed in 0.182002 second(s), 20 queries , Gzip On.
