楼主: cumtjh
[基础] 沿着指定的路径曲线阵列问题?
发表于 2011-7-4 14:18:03 | 显示全部楼层
你这个等分是距离等分还是线长等分?
线长等分好办,现成的vl函数;
距离等分我用的还是圆(程序没校验)。
(defun cy_pl_p0_dp(e-pl p0 d / E-CIR PB);;由p0点求pl上的距离为d的点表
  (#m_cir p0 d "0" -1)
  (setq e-cir(entlast)
        pb(cy_get_inters e-cir e-pl ACEXTENDNONE))
  (entdel e-cir)
  pb
(defun cy_list_jjsz(b a0);;表内数同时加a0
  (setq b1'())
  (foreach x b
    (setq b1(cons (+ x a0) b1)))
  (setq b1(reverse b1))
(defun cy_list_zfzj(b a0 / B-F B-Z B1 FS ZS);;求正负最近的数,即负数最大及正数最小
  (setq b1(cy_list_jjsz b (- a0))
        b-z'() b-f'())
  (foreach x b1
    (cond
      ((equal x 0) )
      ((< x 0)(setq b-f(cons x b-f)))
      (t (setq b-z(cons x b-z)))
  (if (and  (setq fs(apply 'max b-f)) (/= fs 0))
    (setq fs(+ fs a0))
    (setq fs nil)
  (if (and (setq zs(apply 'min b-z)) (/= zs 0))
    (setq zs(+ zs a0))
    (setq zs nil)
  (list fs zs)
;;;(cy_list_zfzj '(7 5 9 5 4 -6 -4) -15)
(defun cy_pl_get_p0_k(CURVE e0 p0 d0 k / D DB DI0 DMIN-MAX P PB X);;k=0为负向点,k=1为正向点
  (setq pb(cy_pl_p0_dp e0 p0 d0)
        di0(vlax-curve-getdistatpoint CURVE p0))
  (if pb(progn
    (setq db(mapcar '(lambda (x) (vlax-curve-getdistatpoint CURVE x)) pb)
          dmin-max(cy_list_zfzj db di0))
    (cond
      ((and (= k 0)(car dmin-max))
        (setq d(car dmin-max)
              p(vlax-curve-getpointatdist CURVE d)))
      ((and (= k 1)(cadr dmin-max))
        (setq d(cadr dmin-max)
      (t (setq p nil))
  p
(defun cy_pl_get_pl-zfb(e0 p0 d0 / CURVE E0 K P P000 PBF PBZ);;;获得按距离分点正负表
  (setq CURVE (vlax-ename->vla-object e0)
        p0(vlax-curve-getClosestPointTo CURVE p0)
        k t pbz(list p0) pbf(list p0)
        p000 p0)
  ;;;pbz
  (while k
    (setq p(cy_pl_get_p0_k CURVE e0 p0 d0 1))
    (if p
      (setq pbz(append pbz (list p))
            p0 p)
      (setq k nil)
  ;;;pbf
  (setq k t p0 p000)
  (while k
    (setq p(cy_pl_get_p0_k CURVE e0 p0 d0 0))
    (if p
      (setq pbf(append pbf (list p))
            p0 p)
      (setq k nil)
  (list pbf pbz)
(defun c:pldf(/ CURVE D0 E0 P0 P000 PBF PBZ PBZF STARTP);;曲线按直线距离分点
  (undo_begin)
  (cy_get_sysmode '(("cmdecho""pickbox""aperture""osmode""blipmode") (1 4 4 544 1)))
  (setq e0(car (entsel "\n选择一条要进行距离分点的曲线:")))
        startp(vlax-curve-getstartpoint CURVE)
        p0(pri1 getpoint startp "\n输入分点起始点" startp)
        d0(pri1 getdist p0 "\n输入分点距离:" 500)
        p000 p0)
  (setq pbzf(cy_pl_get_pl-zfb e0 p0 d0)
        pbf(car pbzf) pbz (cadr pbzf))
  (if pbz (#m_pl2 0 0 0 pbz "0" 1))
  (if pbf (#m_pl2 0 0 0 pbf "0" 3))
  (cy_set_sysmode)
  (undo_end)(princ)
没整理也没查内部函数,看个思路。
发表于 2011-7-30 10:15:49 | 显示全部楼层
呵呵 不够5贴
发表于 2011-9-9 23:25:31 | 显示全部楼层
只可惜我是新手,还有好多不懂的地方要学习。
发表于 2011-9-11 10:16:53 | 显示全部楼层
学习中的一员
发表于 2011-9-20 19:49:49 | 显示全部楼层
留名学习一下~
发表于 2012-2-3 12:41:17 | 显示全部楼层
能这样沿指定路径排列吗?本人从事道路设计,经常需要,希望有个这样的LISP
发表于 2012-2-3 12:59:02 | 显示全部楼层
就是这样的
发表于 2012-3-16 16:28:22 | 显示全部楼层
一直在思考沿曲线阵列的问题,看到这个终于有些想法了
发表于 2012-3-16 21:47:24 | 显示全部楼层
留个脚印,以后有用
发表于 2012-12-11 16:23:33 | 显示全部楼层
ZZXXQQ 发表于 2011-7-2 21:34
程序调试通过。
[/post]
真心想要个像湘源里面种行道树的小命令啊,可惜那个不能对其,有莫有高手拔刀相助啊……
GMT+8, 2026-1-18 08:06 , Processed in 0.703137 second(s), 21 queries , Gzip On.
