楼主: xiaoyingzi
如何用lisp分别保存多个打印设置为打印页面设置
发表于 2019-9-15 06:41:07 来自手机 | 显示全部楼层
这个程序很有用,配合"秋枫批量打印"。
发表于 2019-9-15 06:46:10 来自手机 | 显示全部楼层
pxt2001 发表于 2019-9-15 06:41
这个程序很有用,配合"秋枫批量打印"。
秋枫批量打印程序虽然可以记忆页面设置,但是第一次打印图纸缺页面设置,每次需要手动设置。这个程序设置了"打印机页面设置",然后(c:bplot)启动秋枫批量打印,是完美解决CAD打印图纸的方案。
有空放个视频演示一下。
发表于 2020-8-28 09:42:59 来自手机 | 显示全部楼层
从这个帖子学到很多,感谢楼主
发表于 2020-8-30 09:31:54 来自手机 | 显示全部楼层
简易的多文件批量打印 1.预先设置好页面设置ps1 2.按照ps1打印打开的几个dwg文件 问题是,程序只能打印当前的dwg文件,求网友查错。  (defun ax:2dpoint (pt)   (vlax-make-variant     (vlax-safearray-fill       (vlax-make-safearray vlax-vbdouble '(0 . 1))       (list (car pt) (cadr pt))     )   ) )  (defun objs-lst        (objs)   (setq obj-lst nil)   (vlax-for obj objs (setq obj-lst (cons obj obj-lst)))   (reverse obj-lst) )  (defun getblock_name-yf        (str var)   (princ str)   (if (and (/= var nil) (/= var ""))     (progn (princ "<") (princ var) (princ ">"))   )   (princ ":")   (if (setq in (entsel ""))     (setq var (cdr (assoc 2 (entget (car in)))))     (eval var)   ) )   ;;;获取打印文件存储位置 (defun qf_getfolder (msg / winshell shfolder path catchit)   (vl-load-com)   (setq winshell (vlax-create-object "Shell.Application"))   (setq shfolder (vlax-invoke-method winshell 'browseforfolder 0 msg 1))   (setq     catchit (vl-catch-all-apply               '(lambda ()                  (setq shfolder (vlax-get-property shfolder 'self))                  (setq path (vlax-get-property shfolder 'path))                )             )   )   (if (vl-catch-all-error-p catchit)     nil     path   ) )  ;;;边界函数AX:GETBOUNDINGBOX (ENT) (defun ax:getboundingbox2 (obj)   (vla-getboundingbox obj 'll 'ur)   (mapcar 'vlax-safearray->list (list ll ur)) )  (defun dwj-plot                 (path doc layout plotcfg drawingframe-blkname) ;;;根据图框块名过滤出某个布局中的图框   (setq drawingframe_lst nil)   (vlax-for block (vla-get-block layout)     (if        (and (= (vla-get-objectname block) "AcDbBlockReference")              (= (vla-get-name block) drawingframe-blkname)         )       (setq drawingframe_lst (cons block drawingframe_lst))     )   )    (setq llurs nil)   (foreach obj drawingframe_lst     (setq llur (ax:getboundingbox2 obj))     (setq ll (reverse (cdr (reverse (car llur)))))     (setq ur (reverse (cdr (reverse (cadr llur))))) ;;;    获取属性变量     (setq var (vla-getattributes obj)) ;;;    属性变量转为属性表     (setq attr-lst (vlax-safearray->list (vlax-variant-value var))) ;;;    根据属性标签,寻找属性文字     (foreach attr attr-lst       (setq tagstring (vla-get-tagstring attr))       (cond         ((= tagstring "图号")          (setq tuhao (vla-get-textstring attr))         )         ((= tagstring "图纸名称")          (setq tuming (vla-get-textstring attr))         )         ((= tagstring "图纸名称1")          (setq tuming1 (vla-get-textstring attr))         )         (t t)       )     )     (setq filename (strcat tuhao "_" tuming tuming1))     (setq llur (list ll ur filename))     (setq llurs (cons llur llurs))   )    (setq llurs (sxzy llurs 10))    (foreach x llurs     (setq ll (car x))     (setq ur (cadr x))     (setq filename (last x)) ;;;设置打印范围     (vla-setwindowtoplot       plotcfg       (ax:2dpoint ll)       (ax:2dpoint ur)     ) ;;;指定页面设置为当前     (vla-copyfrom layout plotcfg) ;;;获取当前页面设置     (setq plot (vla-get-plot doc)) ;;;打印     (vla-plottofile       plot       (strcat path "\\" filename)     )   ) )   (defun c:mp ()   (vl-load-com)   (load "_lib-yf.lsp")   (princ     "\nmp-批量打印-多文件,预设页面设置,打开的文件都将被打印"   )   (setq old (getvar "OSMODE"))   (setvar "OSMODE" 0) ;;;cad     (setq app (vlax-get-acad-object)) ;;;文档   (setq docs (vla-get-documents app)) ;;;当前文档   (setq *doc* (vla-get-activedocument app)) ;;;当前布局   ;;;  (setq *lay* (vla-get-activelayout *doc*)) ;;;页面设置   (setq *plotcfgs* (vla-get-plotconfigurations *doc*))   (setq tmp2 (nth 2 (objs-lst *plotcfgs*))) ;;;页面设置名表   (setq pagesetup_name-lst nil)   (vlax-for *plotcfg* *plotcfgs*     (setq pagesetup_name (vla-get-name *plotcfg*))     (setq modeltype (vla-get-modeltype *plotcfg*))     (setq pagesetup_name-lst (cons pagesetup_name pagesetup_name-lst))   )   (setq pagesetup_name-lst (reverse pagesetup_name-lst))   (setq index 1)   (setq tmp nil)   (foreach x pagesetup_name-lst     (setq tmp (cons (itoa index) tmp))     (setq tmp (cons "->" tmp))     (setq tmp (cons x tmp))     (setq tmp (cons ";" tmp))     (setq index (+ 1 index))   )   (setq tmp (reverse tmp))   (setq string (apply 'strcat tmp))   (setq string (strcat "\n选择页面设置名称<" string ">"))   (setq index2 (getint-yf string index2)) ;;;页面设置名称   (setq pagesetup_name (nth (- index2 1) pagesetup_name-lst)) ;;;页面设置,用户要用的   (setq *plotcfg* (vla-item *plotcfgs* pagesetup_name))    (setq *windowtitle* (vla-get-windowtitle *doc*))   (vlax-for doc        docs ;;;;;;当前文档的页面设置复制到其他文档     (if        (/= (strcase (vla-get-windowtitle doc))             (strcase *windowtitle*)         )       (progn ;;;        在其他文档创建页面设置名为pagesetup_name的页面设置         (setq plotcfg (vla-add                         (vla-get-plotconfigurations doc)                         pagesetup_name                         :vlax-false                       )         ) ;;;将*plotcfg*复制进plotcfg         (vla-copyfrom plotcfg *plotcfg*)         (vlax-for layout (vla-get-layouts doc)           (if (/= (vla-get-name layout) "Model")             (vla-copyfrom               layout               plotcfg             )           )         )       )     )   )    (setq        drawingframe-blkname          (getblock_name-yf            "\n选择图框,获取图框块名"            drawingframe-blkname          )   )   (princ drawingframe-blkname)    (setq path (qf_getfolder "选择打印文件保存位置"))    (vlax-for doc        docs     (setq doc doc)     (setq plotcfgs (vla-get-plotconfigurations doc))     (setq plotcfg (vla-item plotcfgs pagesetup_name)) ;;;    (vla-put-activedocument app doc) ;;;    (vla-activate doc)     (vlax-for layout (vla-get-layouts doc)       (setq name (vla-get-name layout))       (if (/= name "Model")         (dwj-plot path doc layout plotcfg drawingframe-blkname)       )     )   )  ;;;  (setq docs (vla-get-documents (vlax-get-acad-object)))   ;;;  (setq doc (vla-item docs 0)) ;;;  (setq plotcfgs (vla-get-plotconfigurations doc)) ;;;  (setq plotcfg (vla-item plotcfgs "yf-dwg to pdf-A2")) ;;;  (setq layout (vla-get-activelayout doc))   ;;;  (dwj-plot path doc layout plotcfg drawingframe-blkname)    (princ) )
发表于 2022-9-22 13:59:52 | 显示全部楼层
很有想法,值得学习。
发表于 2023-12-28 19:10:47 | 显示全部楼层
感谢楼主分享优秀源码,本人结合chatGPT优化,能实现一键设置A4、A3打印,一键发布A4、A3到打印机打印,一键导JPG、PDF到桌面。兼容“模型”环境“布局”环境随便打。
详见此贴
http://bbs.mjtd.com/thread-189219-1-1.html?_dsign=607bb88b
发表于 2024-5-15 20:45:08 | 显示全部楼层
my0314cn 发表于 2020-8-30 09:31
简易的多文件批量打印 1.预先设置好页面设置ps1 2.按照ps1打印打开的几个dwg文件 问题是,程序只能打印当 ...
似乎多一个右括号
发表于 2024-5-15 20:47:53 | 显示全部楼层
这个保存为lsp的文件,提示多一个右括号,我删掉了
GMT+8, 2026-1-14 07:14 , Processed in 0.157745 second(s), 19 queries , Gzip On.
