楼主: 1078815748
[函数] 读取
 楼主| 发表于 2011-7-18 16:58:21 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-7-18 21:22:41 | 显示全部楼层
贴重复了,删掉一个
发表于 2011-7-18 21:23:23 | 显示全部楼层
  1. ;;====================================================
  2. ;;将由相同分隔字符分隔的字符串组成表(忽略“空”字串)
  3. ;;====================================================
  4. (defun zhy_string_tok (sstring sstr / n1 n2 m2 str_1 string_list)
  5.   (setq string_list '())
  6.   (setq n1 (strlen sstring))
  7.   (setq n2 (strlen sstr))
  8.   (while (setq m2 (vl-string-search sstr sstring))
  9.     (setq m2 (1+ m2))
  10.     (setq str_1 (substr sstring 1 (- m2 1)))
  11.     (setq sstring (substr sstring (+ m2 n2)))
  12.     (if        (/= str_1 "")
  13.       (setq string_list (cons str_1 string_list))
  14.     )
  15.   )
  16.   (if (/= sstring "")
  17.     (setq string_list (cons sstring string_list))
  18.   )
  19.   (reverse string_list)
  20. )
  21. ;;;=========================================================
  22. ;;;主程序===================================================
  23. ;;;=========================================================
  24. (defun 4L (/ p1 a d e c b p2 aaa aa dd p4 bbb bb cc p3)
  25.   (setq
  26.     p1        (getpoint "\n四边形初始位置:")
  27.     a        (atof (nth 0 fn_str_lst))
  28.     d        (atof (nth 1 fn_str_lst))
  29.     e        (atof (nth 2 fn_str_lst))
  30.     c        (atof (nth 3 fn_str_lst))
  31.     b        (atof (nth 4 fn_str_lst))
  32.     p2        (polar p1 0 a)
  33.     aaa        (/ (+ (* a a) (* b b) (* c c -1.)) (* 2. a b))
  34.     aa        (XYP-TF-ACOS aaa)
  35.     dd        (- pi aa)
  36.     p4        (polar p2 dd b)
  37.     bbb        (/ (+ (* b b) (* d d) (* e e -1.)) (* 2. b d))
  38.     bb        (XYP-TF-ACOS bbb)
  39.     cc        (- pi (+ aa bb))
  40.     p3        (polar p2 cc d)
  41.   )
  42.   (command "pline" "non" p1 "non" p2 "non" p3 "non" p4 "c")
  43.   (command "change" "L" "" "p" "la" "00铝单板" "")
  44.   (princ)
  45. )
  46. ;;;===========================================================
  47. (defun c:4l ()
  48.   (setq fn (getfiled "选择数据文件" "" "TXT" 8))
  49.   (setq fn (open fn "r"))
  50.   (setq fn_str (read-line fn))
  51.   (while (setq fn_str (read-line fn))
  52.     (setq fn_str_lst (zhy_string_tok fn_str  "\t"))
  53.     (setq n (length fn_str_lst))
  54.     (4l)
  55.   )
  56.   (close fn)
  57. )
上传一个TXT样式,我试读取一下。谢谢  发表于 2011-7-18 21:35
zhynt 大师可以放一个文本样式过来看一下吗?可不可以做成求助图片4那种TXT样式读取呀?谢谢  发表于 2011-7-18 21:33
参与人数 1金钱 +25 收起 理由
1078815748 + 25
发表于 2011-7-18 21:50:41 | 显示全部楼层
就是方式4
l1 l2 l3 l4 l5
51 24 44 37 59
54 25 45 36 55
 楼主| 发表于 2011-7-18 22:00:57 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2011-7-18 22:19:26 | 显示全部楼层
已经修改,请试一下。
发表于 2011-7-18 22:47:27 | 显示全部楼层
csv是cad和Excel都兼容的一种格式,这种格式读取数据我本人比较喜欢,因为用CAD来操作Excel我不在行。
发表于 2011-7-18 23:07:40 | 显示全部楼层
不管是什么格式,只要有分隔符就好办。
谢谢Z版,解决了  发表于 2011-7-19 08:12
发表于 2011-7-19 12:43:49 | 显示全部楼层
稀奇古怪的功能,意义不大。
感觉读取xls文件比txt文件更方便些。
 楼主| 发表于 2011-7-19 13:24:52 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-12-17 06:08 , Processed in 0.170855 second(s), 20 queries , Gzip On.
