楼主: cindy_fisher
关于文字编辑的lisp
发表于 2011-9-28 10:49:59 | 显示全部楼层
(defun c:blkcl (/ NUM OUT P1 P2 PT PTS PTSN SS TEXT TEXT2 X Y Z)
  (vl-load-com)
  (if (setq ss (ssget '((0 . "INSERT"))))
      (setq out (ss->vla-list ss))
      (setq out        (mapcar        '(lambda (x)
                           (vla-GetBoundingBox x 'p1 'p2)
                           (list (vlax-safearray->list p1)
                                 (vlax-safearray->list p2)
                        out
      (setq ss (mapcar '(lambda        (x)
                          (ssget "c" (car x) (cadr x) '((0 . "text")))
                       out
      (setq ss (mapcar 'ss->vla-list ss))
      (foreach item ss
        (setq item (mapcar '(lambda (x)
                              (setq pts        (list (vlax-safearray->list p1)
                              (setq pts        (mapcar        '(lambda (y z)
                                                   (* 0.5 (+ y z))
                                                (car pts)
                                                (cadr pts)
                              (list x pts)
                           item
        (setq item (vl-sort item
                            '(lambda (x y)
                               (< (cadr (cadr x)) (cadr (cadr y)))
        (setq text (mapcar '(lambda (x)
                              (vla-get-textstring (car x))
                           item
        (setq text (mapcar 'vl-string->list text))
                              (vl-remove 32 x)
                           text
        (setq text2 (cadr text))
        (setq text2 (mapcar '(lambda (x)
                               (if (and        (>= x 48)
                                        (<= x 57)
                                 (list t x)
                                 (list nil x)
                            text2
        (setq num (mapcar '(lambda (x)
                             (if (= t (car x))
                               (cadr x)
                          text2
        (setq num (vl-remove nil num))
                               (if (= nil (car x))
                                 (cadr x)
                            text2
        (setq text2 (vl-remove nil text2))
        (setq text (list (append num (car text)) text2))
        (setq text (mapcar 'vl-list->string text))
        (mapcar        '(lambda (x y)
                   (vla-put-textstring (car x) y)
                item
                text
        (setq pts (mapcar 'cadr item))
        (setq item (mapcar 'car item))
        (setq ptsn (mapcar '(lambda (x)
                              (setq pt (list (vlax-safearray->list p1)
                                         (* 0.5 (+ y z))
                                      (car pt)
                                      (cadr pt)
                           item
        (mapcar        '(lambda (x y z)
                   (vla-move x (vlax-3d-point y) (vlax-3d-point z))
                item
                ptsn
                pts
(defun ss->vla-list (ss / I OUT)
  (setq        i   -1
        out '()
  (repeat (sslength ss)
    (setq out (cons (ssname ss (setq i (1+ i))) out))
  (setq out (mapcar 'vlax-ename->vla-object out))
 楼主| 发表于 2011-9-28 11:54:49 | 显示全部楼层
  (vl-load-com)
  (if (setq ss (s ...
我想让程序实现自动搜索块名字,然后进行文字编辑,就改成了下面的语句:
(setq ss (ssget  "X" '((0 . "INSERT") (2 . "DCS_FUNC_ACCESS_IN_PRIME_LOC")))))
结果就出现了语法错误,请指教,谢谢
发表于 2011-9-29 11:46:24 | 显示全部楼层
如果是这句出现了问题,可能是多了一个括号。
 楼主| 发表于 2011-10-8 15:24:08 | 显示全部楼层
去掉一个括号,成功了,谢谢,但是去掉后右括号和左括号的个数是不对应的,很奇怪。
我的图上不只这个块要执行,其他还有三个块(DDCS_B, DDCS_C,DDCS_D)也要执行,ssget后面两个括号表示“并”的意思,有没有什么方法表示或者的意思。
谢谢。
发表于 2011-10-8 16:17:07 | 显示全部楼层
或者的话用块名用逗号分开就可以了,如(2 . "b1,b2,b3"))))
 楼主| 发表于 2011-10-9 11:21:34 | 显示全部楼层
谢谢,解决了我的大问题,我还想着用好几个cond ,然后执行修改动作的那个sub
GMT+8, 2025-12-17 02:47 , Processed in 0.162999 second(s), 20 queries , Gzip On.
