查看: 8760|回复: 5
(求助)程序运行过程中总是出现错误:参数类型错误:VLA-OBJECT nil
发表于 2011-10-27 15:37:10 | 显示全部楼层 |阅读模式
(defun C:sjk()
  (vl-load-com)
  (setq exlib "C:Program files\\Microsoft office\\Office12\\Excel.exe")
  (setq exlib "C:Program files\\Microsoft office\\Office10\\Excel.exe")
  (setq exlib "C:Program files\\Microsoft office\\Office11\\Excel.exe")
  (vla-put-visible Xlobj 1)
  (if(null MX-acos)
     (vlax-import-type-library
           :tlb-filename         exlib
    :methods-prefix       "MX-"
    :properties-prefix    "MX-"
    :constants-prefix     "MX-"
  (setq XLobj(vlax-create-object"Excel.Application"))
  (vlax-invoke-Method(vlax-get-Property XLobj'Workbooks)'Open filename)
  (setq filename"f:\\1.xls")
  (setq sheetobj(MX-get-activesheet XLobj))
  (setq cells(MX-get-cells sheetobj))
  (setq cell-1-2 (vlax-variant-value(MX-get-value-sheetobj-1-2)))
  (princ"\nCELL-1-2=")(princ cell-1-2)
  (vlax-invoke-method XLobj 'QUIT)
  (vlax-release-object XLobj)
  (setq XLobj nil)
大家帮忙看一下这个程序哪个地方需要修改,运行过程中总是出现错误:参数类型错误:VLA-OBJECT nil。
谢谢啦!
发表于 2011-10-28 15:40:36 | 显示全部楼层
这一句执行的时候,xlobj的值还是nill
还有这句(if(null MX-acos)
也是没赋值就引用参数了
还有,有个“)”的位置错了
 楼主| 发表于 2011-10-29 09:23:10 | 显示全部楼层
请问怎么将MX-acos赋值?还有那个Xlobj不需要赋值吧?谢谢了,我刚开始学习,不大懂
发表于 2011-10-29 12:31:41 | 显示全部楼层
1、 (vla-put-visible Xlobj 1) 的一行右括号是多余的
2、将 (vla-put-visible Xlobj 1) 移动到 (setq XLobj(vlax-create-object"Excel.Application"))行的下面一行
3、其余如下:
  1. (defun C:sjk()
  2.
  3.   (vl-load-com)
  4.
  5.   (if (not (findfile (setq exlib "C:\\Program files\\Microsoft office\\Office12\\Excel.exe")))
  6.       (if (not (findfile (setq exlib "C:\\Program files\\Microsoft office\\Office10\\Excel.exe")))
  7.           (if (not (findfile (setq exlib "C:\\Program files\\Microsoft office\\Office11\\Excel.exe")))
  8.               (vl-exit-with-error "不能引入Excel类型库!")
  9.           )
  10.       )
  11.   )
  12.   (if(null MX-acos)
  13.      (vlax-import-type-library
  14.            :tlb-filename         exlib
  15.            :methods-prefix       "MX-"
  16.            :properties-prefix    "MX-"
  17.            :constants-prefix     "MX-"
  18.      )
  19.
  20.    )
  21.    (setq XLobj (vlax-create-object "Excel.Application"))
  22.    (vla-put-visible Xlobj :vlax-true)
  23.    (vlax-invoke-Method(vlax-get-Property XLobj'Workbooks)'Open filename)
  24.    (setq filename"f:\\1.xls")
  25.    (setq sheetobj(MX-get-activesheet XLobj))
  26.    (setq cells(MX-get-cells sheetobj))
  27.    (setq cell-1-2 (vlax-variant-value(MX-get-value-sheetobj-1-2)))
  28.    (princ"\nCELL-1-2=")(princ cell-1-2)
  29.    (vlax-invoke-method XLobj 'QUIT)
  30.    (vlax-release-object XLobj)
  31.    (setq XLobj nil)
  32.    (princ)
  33. )
 楼主| 发表于 2011-10-29 15:52:49 | 显示全部楼层
2、将 (vla-put-visible Xlobj 1) 移动到 (setq XLo ...
谢谢了!
发表于 2013-5-14 10:08:35 | 显示全部楼层
又学了一手,谢谢了
GMT+8, 2025-5-30 07:36 , Processed in 0.153024 second(s), 25 queries , Gzip On.
