楼主: flytoday
30币求指定承台下桩数统计
 楼主| 发表于 2011-12-29 19:21:30 | 显示全部楼层
feng582304 发表于 2011-12-29 15:30
先加一句(vl-load-com)试试看,因为我这边正常啊
哥。你发的又不是源码怎么加啊[em0]
发表于 2011-12-29 19:53:50 | 显示全部楼层
把(vl-load-com) 复制到命令行 回车就好
 楼主| 发表于 2011-12-29 20:21:29 | 显示全部楼层
很好哈。。哥能不能公布代码让更多人受益啊。。我很想知道这个图为什么关了承台的CT图层(桩属性是块名称是ZH100显示也属于CT层)为什么关了层还会显示呢。。。。。。。。
最好加入能输入如ZH7-2下包括的桩数(如ZH7-2(1),ZH7-2(2),ZH7-2(3)。。。。全部数量)
发表于 2011-12-29 21:36:18 | 显示全部楼层
  1. (defun feng-zct-pmin-pmax ( s1 / pmax pmin )
  2.   (setq s1 (vlax-ename->vla-object s1))
  3.   (vla-GetBoundingBox s1 'pmin 'pmax)
  4.   (MAPCAR '(LAMBDA (x)
  5.        (trans (MAPCAR 'fix (vlax-safearray->list x)) 0 1)
  6.        )
  7.     (list pmin pmax)
  8.     )
  9.   )
  10. (defun feng-zct-ssget ( filter poli n / ss li )
  11.   (setq ss (ssget "c" (car poli) (cadr poli) filter))
  12.   (if ss
  13.     (cond
  14.       ((= n 1) (ssname ss 0))
  15.       (t (repeat (setq n (sslength ss)) (setq li (cons (ssname ss (setq n (1- n))) li))))
  16.       )
  17.     nil
  18.     )
  19.   )
  20. (defun feng-get-insertionpoint ( s1 )
  21.   (trans (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint s1))) 0 1)
  22.   )
  23. (defun feng-zct-addtext ( ms st stylename po num / pp obj)
  24.   (if (null (TBLSEARCH "LAYER" "桩编号")) (vla-add (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))) "桩编号"))
  25.   (MAPCAR '(LAMBDA (x)
  26.        (vla-put-layer (vla-addline ms (vlax-3d-point (trans (car x) 1 0)) (vlax-3d-point (trans (cadr x) 1 0))) "桩编号")
  27.        )
  28.     (list
  29.       (list po (setq pp (MAPCAR '+ po '(350 350 0))))
  30.       (list pp (MAPCAR '+ pp '(1200 0 0)))
  31.       )
  32.     )
  33.   (vla-put-layer (setq obj (vla-addtext ms (strcat st "(" (itoa num) ")") (vlax-3d-point (trans (MAPCAR '+ pp '(100 100 0)) 1 0)) feng-heigth)) "桩编号")
  34.   (vla-put-StyleName obj stylename)
  35.   )
  36. (defun feng-ssget->list ( ss / li n )
  37.   (repeat (setq n (sslength ss))
  38.     (setq li (cons (ssname ss (setq n (1- n))) li))
  39.     )
  40.   )
  41. (defun feng-zct-obj ( ss / li n yx pp tt s1 )
  42.   (setq ss (MAPCAR '(LAMBDA (x);选承台线
  43.           (FENG-ZCT-SSGET '((8 . "Ct") (0 . "*POLYLINE")) x nil)
  44.           )
  45.        (MAPCAR '(LAMBDA (x);引线框
  46.             (list (MAPCAR '+ (car x) '(-10 -10 0)) (MAPCAR '+ (cadr x) '(10 10 0)))
  47.             )
  48.          (MAPCAR 'FENG-ZCT-PMIN-PMAX
  49.            (setq yx (MAPCAR '(LAMBDA (x);选引线
  50.                    (FENG-ZCT-SSGET '((0 . "*LINE") (8 . "Jno")) x 1)
  51.                    )
  52.                 (MAPCAR '(LAMBDA (x);编号框
  53.                      (list (MAPCAR '+ (car x) '(0 -300 0)) (cadr x))
  54.                      )
  55.                   (MAPCAR 'FENG-ZCT-PMIN-PMAX
  56.                     (FENG-SSGET->LIST (ssget "x" (list (assoc 8 ss) (assoc 0 ss) (assoc 1 ss))))
  57.                     ))))))))
  58.   (setq ss (MAPCAR 'FENG-ZCT-PMIN-PMAX
  59.        (MAPCAR '(LAMBDA (x y)
  60.             (if (= (length x) 1)
  61.         (car x)
  62.         (progn
  63.           (setq n -1 tt t)
  64.           (while tt
  65.             (setq pp (vlax-variant-value (vla-IntersectWith (vlax-ename->vla-object y) (vlax-ename->vla-object (setq s1 (nth (setq n (1+ n)) x))) acExtendNone)))
  66.             (if (> (vlax-safearray-get-u-bound pp 1) 0) (setq pp (vlax-safearray->list pp) tt nil))
  67.             )
  68.           s1
  69.           )
  70.         )
  71.             )
  72.          ss yx
  73.          )
  74.        )
  75.   )
  76.   (setq li (MAPCAR '(LAMBDA (x) (list (car (cadr x)) (cadr (cadr x)) 0)) ss))
  77.   (setq ss (MAPCAR '(LAMBDA (x)
  78.           (MAPCAR 'vlax-ename->vla-object (FENG-ZCT-SSGET '((0 . "INSERT") (8 . "Ct") (2 . "ZH100")) x nil))
  79.           )
  80.        ss
  81.        )
  82.   )
  83.   (setq li (vl-sort (VL-SORT (MAPCAR 'cons li ss) '(LAMBDA (x y) (< (car (car x)) (car (car y))))) '(LAMBDA (x y) (> (cadr (car x)) (cadr (car y))))))
  84.   (setq li (MAPCAR '(LAMBDA (x)
  85.           (MAPCAR 'FENG-GET-INSERTIONPOINT
  86.             (vl-sort (vl-sort (cdr x) '(LAMBDA (y z) (< (car (FENG-GET-INSERTIONPOINT y)) (car (FENG-GET-INSERTIONPOINT z)))))
  87.                '(LAMBDA (y z) (> (cadr (FENG-GET-INSERTIONPOINT y)) (cadr (FENG-GET-INSERTIONPOINT z))))
  88.                )
  89.             )
  90.           )
  91.        li
  92.        )
  93.   )
  94.   li
  95.   )
  96. (defun c:feng-zct ( / ss stylename li ms st num )
  97.   (VL-LOAD-COM)
  98.   (princ "\n=============请选择承台编号==============")
  99.   (setq ss (ssget ":E:S" '((0 . "*TEXT") (8 . "Jno"))))
  100.   (if (car (setq feng-heigth (list (getdist (STRCAT "\n请输入字高<" (if feng-heigth (itoa feng-heigth) (progn (setq feng-heigth 200) "200")) ">:")) feng-heigth)))
  101.     (setq feng-heigth (fix (car feng-heigth)))
  102.     (setq feng-heigth (cadr feng-heigth))
  103.     )
  104.   (if ss (vl-cmdf "undo" "be" "zoom" "e"))
  105.   (if ss
  106.     (progn
  107.       (setq ms (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object)))
  108.       li (feng-zct-obj (entget (ssname ss 0)))
  109.       stylename (cdr (assoc 7 (setq ss (entget (ssname ss 0)))))
  110.       st (cdr (assoc 1 ss))
  111.       num 0
  112.       )
  113.       (MAPCAR '(LAMBDA (x)
  114.      (MAPCAR '(LAMBDA (y)
  115.           (FENG-ZCT-ADDTEXT ms st stylename y (setq num (1+ num)))
  116.           )
  117.        x
  118.        )
  119.      )
  120.         li
  121.         )
  122.       )
  123.     )
  124.   (if ss (vl-cmdf "zoom" "p" "undo" "e"))
  125.   (princ "\n===make by feng===")
  126.   (princ)
  127.   )
之所以你关闭图层后还显示,是因为你的块内容不是在0层。
flytoday + 1 很给力!
 楼主| 发表于 2011-12-30 13:14:37 | 显示全部楼层
看来最近高手都很忙哈。。。。哪位有空路过瞧瞧哈。。。。帮帮忙不胜感激
发表于 2013-2-3 15:11:29 | 显示全部楼层
SEE
GMT+8, 2025-12-17 12:28 , Processed in 0.204693 second(s), 20 queries , Gzip On.
