楼主: yjr111
G版和HIGHFLYBIRD及高人请进!如何能求出所有的路径呢?
发表于 2014-1-23 12:27:41 | 显示全部楼层
看了一下,没有看懂,慢慢学了、、
发表于 2014-4-21 15:50:59 | 显示全部楼层
最短路径的问题?我在网上看到过类似的代码,贴出来给大家看看,先声明,这是别人的作品。
(defun z_timer (/ stime h m s)
  (if (not zhf_time_dot)
    (setq zhf_time_dot (getvar "date") h nil)
      (setq stime (getvar "date"))
      (setq stime (- stime zhf_time_dot))
      (setq stime (* 86400.0 (- stime (fix stime))))
      (setq h (fix (/ stime 3600)))
      (setq m (fix (/ (- stime (* h 3600)) 60)))
      (setq s (fix (- stime (* m 60) (* h 3600))))
      (setq zhf_time_dot nil)
      (strcat (if (> h 0)
                (strcat (rtos h 2 0) "小时")""
              (if (> m 0)
                (strcat (rtos m 2 0) "分钟")""
              (rtos s 2 0)
              "秒"
(defun show (lst stop)
  (mapcar '(lambda (x) (redraw (vlax-vla-object->ename x) 3))
          lst
  (if stop (progn(getpoint)
  (mapcar '(lambda (x) (redraw (vlax-vla-object->ename x) 4))
          lst
(defun ss2lst (ss vla / re e)
  (if ss
    (repeat (setq n (sslength ss))
      (if vla
        (setq e (vlax-ename->vla-object (ssname ss (setq n (1- n)))))
        (setq e (ssname ss (setq n (1- n))))
      (setq re (append re (list e)))
  re
(defun getss@ (p)
  (ssget "c"
         p
         (polar p (/ pi 4) (/ (getvar "viewsize") 5000))
         '((0 . "arc,ellipse,*line"))
(defun getconnect (e)
  (vl-remove e
             (append (ss2lst (getss@ (vlax-curve-getStartpoint e)) t)
                     (ss2lst (getss@ (vlax-curve-getEndpoint e)) t)
(defun remove:same (lst / re)
  (foreach n lst
    (if        (member n re)
      (setq re (append re (list re)))
  re
(defun get:len (e)
  (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e))
;;;________________________________________________
(defun main (pt1 pt2 show / ss sse line path paths shortlen shortlst ss1 shortest)
  (setq count 0)
  (setq        ss  (ss2lst (getss@ pt1) t)
        sse (ss2lst (getss@ pt2) t)
  (if (and ss sse)
      (setq passed-ss ss
            path-ss   (mapcar '(lambda (x) (list x)) ss)
            dist-ss   (mapcar '(lambda (x) (list x (get:len x))) ss)
            dist-ss   (vl-sort dist-ss '(lambda (a b) (< (cadr a) (cadr b))))
            complete  nil
                 (if (member x sse)
                   (setq complete (append complete (list(list x (get:len x)))))
              ss
      (if complete
        (setq complete (vl-sort        complete
              shortest (cadar complete)
      (if (and shortest (= shortest (distance pt1 pt2)))
        (list (cadar complete) (list(caar complete)))
      (while (and dist-ss (> (length sse) (length complete)))
        (setq now     (car dist-ss)
              dist-ss (cdr dist-ss)
        (if show
            (vlax-put (car now) 'color (+ 21 (* 10 (rem count 20))))
            (vla-update (car now))
          (if (member (car now) sse)
              (setq complete (append complete (list now)))
              ;;;__________________________________________________
              ;;;到达终点后剔出所有距离已经超出最小路由长度的未完成方向
              (setq complete
                     (vl-sort complete
                    dist-ss (mapcar '(lambda(x)(if (< (cadr x) shortest) x nil)) dist-ss)
                    dist-ss (vl-remove nil dist-ss)
              (setq count (1+ count))
              (setq ss (getconnect (car now)))
              (mapcar '(lambda (x) (setq ss (vl-remove x ss)))
                      passed-ss
              (setq passed-ss (append passed-ss ss)
                    path-ss   (append
                                path-ss
                                (mapcar '(lambda (x) (list x (car now))) ss)
                    dist-ss   (append
                                dist-ss
                                (mapcar
                                  '(lambda (x)
                                     (if (or (not shortest) (< (get:len x) shortest))(list x (+ (cadr now) (get:len x))))
                                  ss
        (if show
            (mapcar '(lambda (x) (vlax-put x 'color 0)) passed-ss)
            (mapcar '(lambda (x) (vla-update x)) passed-ss)
      (if complete
          (setq
            n (car complete)
          (setq        len (cadr n)
                n   (car n)
          (while n
            (setq ss1 (append ss1 (list n)))
            (setq n (cadr (assoc n path-ss)))
          (list len (reverse ss1 ))
        nil
    nil
(defun c:tt (/ pt1 pt2 ss1 ss2 complete)
  (redraw)
  (setq        pt1 (getpoint "\n起点:")
        pt2 (getpoint "\n终点:")
  (mapcar
    '(lambda (pt)
       (grdraw (polar pt (* pi 0.25) (/ (getvar "viewsize") 40))
               (polar pt (* pi -0.75) (/ (getvar "viewsize") 40))
               1
       (grdraw (polar pt (* pi 0.75) (/ (getvar "viewsize") 40))
               (polar pt (* pi -0.25) (/ (getvar "viewsize") 40))
               1
    (list pt1 pt2)
  (z_timer)
  (setq ss1 (main pt1 pt2 t))
  (if ss1
      (setq ss2 (ssadd))
                 (setq ss2 (ssadd (vlax-vla-object->ename x) ss2))
              (cadr ss1)
      (princ (strcat "\n虚线显示最短路线, 共需" (itoa (sslength ss2)) "步,总长度为:"
                     (rtos (car ss1))
                     "  历时:"
                     (z_timer)
      (show (cadr ss1) nil)
    (princ (strcat "\n两点间没有可连通路径,历时:" (z_timer)))
(princ "\n寻找连接两点的最近路线,by wkai @ xdcad ")
(princ "\n前提 所有路线只在交点处交叉,起点和终点选择路线的端点.")
(princ "\n核心函数 (main 起点 终点 是否显示搜索过程) ")
(princ "\n返回值   (最短路线长度  最短路线途径实体表)")
(princ "\n测试命令:tt\n")
发表于 2019-1-4 12:03:45 | 显示全部楼层
想看下G版的程序,不过权限不够。
发表于 2019-4-19 09:55:16 | 显示全部楼层
G 版对算法很精通,学习了
发表于 2019-4-23 17:15:59 | 显示全部楼层
好贴标记。
GMT+8, 2026-1-19 10:37 , Processed in 0.158638 second(s), 19 queries , Gzip On.
