楼主: tm20038175
【已解决】新建图层出错问题~~~
 楼主| 发表于 2012-3-27 20:45:16 来自手机 | 显示全部楼层
好像不是这个命令呀,求高人指点。。。。。
发表于 2012-3-27 21:45:14 | 显示全部楼层
是不是高版本的CAD才会出现这个问题???
 楼主| 发表于 2012-3-27 22:20:42 来自手机 | 显示全部楼层
也许吧,我的是2012 64bit,但是用了半年都很好的程序突然出现了这个问题,真奇怪!…
发表于 2012-3-27 23:35:11 | 显示全部楼层
;批量建层
(defun c:tc()(command
"layer" "m" "2虚线" "c" "251" "" "lw" "0.13" "" "l" "DASHED" "" ""
"layer" "m" "3中心线" "c" "1" "" "lw" "0.13" "" "l" "CENTER" "" ""
"layer" "m" "4点划线" "c" "140" "" "lw" "0.13" "" "l" "ACAD_ISO10W100" "" ""
"layer" "m" "5双点划线" "c" "230" "" "lw" "0.13" "" "l" "DIVIDE" "" ""
"layer" "m" "6不打印" "c" "44" "" "lw" "0.13" "" "l" "Continuous" "" "p" "n" "" ""
"layer" "m" "7标注" "c" "3" "" "lw" "0.13" "" "l" "Continuous" "" ""
"layer" "m" "8细线" "c" "7" "" "lw" "0.13" "" "l" "Continuous" "" ""
"layer" "m" "9文字" "c" "7" "" "lw" "0.3" "" "l" "Continuous" "" ""
"layer" "m" "99图框" "c" "7" "" "lw" "0.3" "" "l" "Continuous" "" ""
"layer" "m" "螺纹" "c" "53" "" "lw" "0.13" "" "l" "Continuous" "" ""
"layer" "m" "填充" "c" "11" "" "lw" "0.13" "" "l" "Continuous" "" ""
"layer" "m" "张号" "c" "230" "" "lw" "0.3" "" "l" "Continuous" "" ""
"layer" "m" "张数" "c" "240" "" "lw" "0.3" "" "l" "Continuous" "" ""
"layer" "m" "0" "lw" "0.3" "" ""
)(princ))
 楼主| 发表于 2012-3-28 06:28:02 | 显示全部楼层
RE: 新建图层出错问题~~~
669423907 发表于 2012-3-27 23:35
;批量建层
"layer" "m" "2虚线" "c" "251" "" "lw" "0.13" "" "l" "DASHED" "" "" ...
呵呵,谢谢,但是好像不是语法的问题。。。
发表于 2012-3-28 08:45:44 | 显示全部楼层
我的几个建层程序在CAD2006上能用,到了CAD2010以上版本都不能用了,我也在查这个问题,好像与哪个函数或参数设置有关!!!
 楼主| 发表于 2012-3-28 19:02:01 来自手机 | 显示全部楼层
lidaxiu 发表于 2012-3-28 08:45
我的几个建层程序在CAD2006上能用,到了CAD2010以上版本都不能用了,我也在查这个问题,好像与哪个函数或 ...
我的找到原因了,原来是 qaflags 这个系统变量被修改了
GMT+8, 2025-12-16 10:53 , Processed in 0.168529 second(s), 18 queries , Gzip On.
