楼主: xieling888
求半圆变整圆的程序,谁有施舍一个,谢谢!
发表于 2012-5-31 14:25:15 | 显示全部楼层
相当简单:输入J ,选择半圆,输入L, Enter
不错,好方法,可以在此基础上做一个与楼上不同的程序了  发表于 2012-6-2 08:15
发表于 2012-6-1 11:25:12 | 显示全部楼层
偶打酱油的哟
发表于 2012-11-5 16:54:59 | 显示全部楼层
  1. ;圆弧转圆
  2. (defun C:XX( / i s1 ss)
  3. (KX-COMA)
  4.   (KX-princA "圆弧转圆")
  5.   (KX-princ "圆弧对象对象")
  6.    (while (setq ss  (ssget":s" '((0 . "ARC"))))
  7.              (setq  i   -1)
  8.     (while (setq s1 (ssname ss (setq i (1+ i))))
  9.      (kx-mk-CIRCLE (KX-GET-DXF 10 S1) (KX-GET-DXF 40 S1))
  10.     )
  11.     (KX-E SS)
  12.    )
  13. (KX-COMB)
  14. )
发表于 2012-11-5 17:03:41 | 显示全部楼层
kaixin准备学院长吗?也放伪源码
发表于 2012-11-5 20:26:56 | 显示全部楼层
那就来个不一样的
(defun C:ZZ (/ i ss)
  (setq ss (ssget' ((0 . "ARC"))))
  (repeat (setq i (sslength ss))
    (entmake (cons '(0 . "CIRCLE") (cddr (reverse (cdddr (reverse (entget (ssname ss (setq i (1- i))))))))))
  (command "erase" ss "")
发表于 2012-11-5 22:31:15 | 显示全部楼层
【KAIXIN】 发表于 2012-11-4 22:54
杯具,学院长了
发表于 2012-11-6 12:14:23 | 显示全部楼层
这个似乎啰嗦很多,但是对于3D图档转过来的ARc的Z坐标以及什么平面
有问题的似乎好用一些,
(DEFUN C:aC (/ ss1 emax count en ed ls ename)
  (SETQ SS1 NIL)
  (setq ss1 (ssget (list (cons 0 "circle,arc"))))
  (if ss1
    (PROGN
      (SETQ EMAX NIL
            COUNT 0
      (setq emax (sslength ss1))
      (while (< count emax)
        (setq EN (ssname ss1 COUNT)
              ED (ENTGET EN)
        (if (= (setq ls (last (assoc 210 ed))) 1)
          (SETQ
            LS
             (list (cons 0 "circle")
                   (cons 8 "ok")
                   (list 10 (cadr (assoc 10 ed)) (caddr (assoc 10 ed)))
                   (CONS 62 222)
                   (CONS 40 (CDR (assoc 40 ed)))
          (SETQ
            LS (list (cons 0 "circle")
                     (cons 8 "ok")
                     (list 10
                           (- 0 (cadr (assoc 10 ed)))
                     (CONS 62 222)
        (ENTMAKE LS)
        (entdel en)
        (SETQ COUNT (1+ COUNT))
        (setq ename nil)
        (setq ls nil)
      )                                        ;WHILE
    )                                        ;FIRST OF PROGN
    (PROMPT "\n 未选取到 Arc实体,请重新选择!<circle>")
  (setq en nil)
  (prompt "     ___CIRCLE.lsp")
 楼主| 发表于 2012-11-8 15:13:20 | 显示全部楼层
谢谢各位的奉献!
发表于 2012-11-9 07:39:05 | 显示全部楼层
这个不难啊,用半圆求出圆心和两个端点
GMT+8, 2025-12-17 09:02 , Processed in 0.175003 second(s), 20 queries , Gzip On.
