楼主: licream
有没有类拟lsp生成一个边界框
发表于 2013-1-22 13:36:22 | 显示全部楼层
这是一个经典的写法,佩服楼主。
发表于 2013-11-3 07:43:15 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-1-17 10:39:12 | 显示全部楼层
这程序不错哦,先收藏了
发表于 2014-2-21 09:41:12 | 显示全部楼层
收藏,很好用,干脆出个通用函数,选择集的max和min。
发表于 2019-6-19 18:00:33 | 显示全部楼层
谢谢版主,很好用
发表于 2019-6-25 00:01:38 | 显示全部楼层
;【PF工具箱--自动边界盒】
(defun c:bjh (/ ss i l1 l2 ll ur os d)
   (setq os (getvar 'osmode))
   (PRINC "\n【PF工具箱--QQ交流群:214654218】--自动边界盒 ")(PRINC)
   (setq d (getreal "\n偏距<5>"))
   (if (null d)
     (setq d 5)
   (setq ss (ssget))
   (repeat (setq i (sslength ss))
     (vla-getboundingbox
       (vlax-ename->vla-object (ssname ss (setq i (1- i))))
       'll
       'ur
     (setq l1 (cons (vlax-safearray->list ll) l1)
           l2 (cons (vlax-safearray->list ur) l2)
   (mapcar 'set
           (list 'll 'ur)
           (mapcar '(lambda (a b) (apply 'mapcar (cons a b)))
                   '(min max)
                   (list l1 l2)
   (command
     "rectang"
     (trans (polar ll (* pi 1.25) (setq d (sqrt (+ (* d d) (* d d)))))
            0
            1
     (trans (polar ur (* pi 0.25) d) 0 1)
   (setvar 'osmode os)
发表于 2019-12-15 13:24:05 | 显示全部楼层
感谢版主
东拼西凑加了记忆功能,和外框指定图层,以及中途退出捕捉恢复
(defun c:wk (/ ss i l1 l2 ll ur os d)
  (defun *MYERR* (MSG)
(setvar "CMDECHO" CMD_OLD)
(setvar "OSMODE" OS_OLD)
(setq *ERROR* *OLDERR*)
(if (= MSG "完美退出。谢谢使用。")
     (princ (strcat "\\n>>>" MSG))
     (princ "\n>>>虽然中途退出了,对象捕捉已经被恢复。")
    (setq *OLDERR* *ERROR*
   *ERROR*  *MYERR*
   OS_OLD   (getvar "OSMODE")
   CMD_OLD  (getvar "CMDECHO")
(setvar "CMDECHO" 0);_关闭命令提示
(Setq osmode_bak (getvar "osmode"));_记录捕捉
(Setvar "osmode" 0);_关闭捕捉
(if *Scale* (setq d (getreal (strcat  "\n偏距<" (rtos *Scale* 2 2) ">:") ) )  (setq d (getreal  "\n偏
距:")))
(if (null d) (setq d *Scale*) (setq *Scale*  d ))
(setq ss (ssget))
    (vla-getboundingbox
      'll
      'ur
  (mapcar 'set
          (list 'll 'ur)
                  '(min max)
                  (list l1 l2)
  (command
    "rectang"
           0
           1
(command "CHPROP" "L" "" "LA" "_3" "");指定图层
(Setvar "osmode" osmode_bak);_还原捕捉
(setvar "CMDECHO" 1);_打开命令提示
发表于 2019-12-15 20:02:34 | 显示全部楼层
要这抓外框再取整就完美了
GMT+8, 2026-1-14 12:40 , Processed in 0.176867 second(s), 20 queries , Gzip On.
