楼主: linshiyin2
写个批量生成fas的程序如下
 楼主| 发表于 2012-11-25 01:27:18 | 显示全部楼层
  1. (defun c:lsptofas ( / f fname ml n str)
  2.   (command "vlisp")
  3.   (vl-load-com)
  4.
  5.   (setq fname (getfiled "lisp数据文件" ".lsp" "lsp" 16))
  6.   (if (not fname)
  7.     (exit)
  8.   )
  9.   (if (not (setq f (vl-filename-directory fname)))
  10.     (exit)
  11.   )
  12.   (setq ml (vl-directory-files f "*.lsp" 1))
  13.   (setq n (length ml))
  14.   (princ "\n 转换中...请稍等! \n")
  15.   (repeat n
  16.     (setq str (car ml)
  17.     str (strcat f "\" str)
  18.     )
  19.     (vlisp-compile 'st str)
  20.     (vl-file-delete  str)
  21.     (setq ml (cdr ml))
  22.   )
  23.   (princ (strcat "转换数:" (itoa n)))
  24.   (princ)
  25. )
不用打开vle就可以执行啦。
发表于 2012-11-25 08:51:09 来自手机 | 显示全部楼层
谢谢分享!
发表于 2013-3-8 11:58:06 | 显示全部楼层
不错,真的很好用,删除(vl-file-delete  str)可不删源文件
GMT+8, 2025-12-17 20:08 , Processed in 0.152097 second(s), 19 queries , Gzip On.
