查看: 3461|回复: 0
MNS[原创]
发表于 2002-6-7 15:15:00 | 显示全部楼层 |阅读模式
**实用工具
**实用
ID_Mytool      [_Toolbar("实用", _Right, _Show, 0, 0, 1)]
ID__0          [_Button("插入图框", "B_DRAWING.bmp", "B_DRAWING")]^C^C^P(if (null B_DRAWING) (load "B_DRAWING")) (B_DRAWING) ^P
ID_Edit_Attribute_0 [_Button("Edit Attribute", "ICON_16_ATTEDI", "ICON_24_ATTEDI")]^C^C_ddatte
ID__mylayer_0  [_Flyout("图层管理", B_LAYER_ONALL.bmp, B_LAYER_ONALL, _OtherIcon, ACAD.图层管理)]
               [_Button("改变当前层", "B_LAYER_TO.bmp", "B_LAYER_TO.bmp")]ID__mylayer-to^C^C^P(if (null B_LAYERCTR) (load "B_LAYERCTR")) (B_LAYERCTR "4") ^P
ID__change     [_Button("改变线层", "B_CHANGE.bmp", "B_CHANGE")]^C^C^P(if (null B_CHANGE) (load "B_CHANGE")) (B_CHANGE) ^P
ID_BnsLayfrz   [_Button("图层冻结", "B_LAYER_FREEZE.bmp", "B_LAYER_FREEZE.bmp")]^C^C^P(if (null B_LAYERCTR) (load "B_LAYERCTR")) (B_LAYERCTR "6") ^P
ID_mycenter    [_Button("绘中心线", "B_CEN_LINE.bmp", "B_CEN_LINE.bmp")]^C^C^P(if (null B_CIRCLINE) (load "B_CIRCLINE")) (B_CIRCLINE) ^P
ID__mybase_0   [_Flyout("基本", B_BASE.bmp, B_BASE, _OtherIcon, ACAD.基本)]
ID__mybase_0   [_Flyout("尺寸修改", B_DIMENSION_CIRCLE.bmp, B_DIMENSION_CIRCLE, _OtherIcon, ACAD.尺寸修改)]
ID__screw_col  [_Button("内六角圆柱头螺钉", "B_SCREW_COLUMN.bmp", "B_SCREW_COLUMN")]^C^C^P(load "B_SCREW_COLUMN")(B_SCREW_COLUMN) ^P
ID__nut        [_Button("螺母", "B_NUT.bmp", "B_NUT")]^C^C^P(if (null B_NUT) (load "B_NUT"))(B_NUT) ^P
ID__sprocket   [_Button("链轮", "B_SPROCKET.bmp", "B_SPROCKET.bmp")]^C^C^P(if (null B_SPROCKET) (load "B_SPROCKET"))(B_SPROCKET) ^P
ID__my_mxl     [_Button("指引框", "B_CATALOG.bmp", "B_CATALOG")]^C^C^P(if (null B_CATALOG) (load "B_CATALOG")) (B_CATALOG) ^P
ID__TECHNOLOGY [_Button("技术要求", "B_TECHNOLOGY_REQUIRE.bmp", "B_TECHNOLOGY_REQUIRE")]^C^C^P(if(null B_TECHNOLOGY_REQUIRE) (load "B_TECHNOLOGY_REQUIRE")) (B_TECHNOLOGY_REQUIRE) ^P
ID__TOLERANCE  [_Button("公差选择", "B_TOLERANCE.bmp", "B_TOLERANCE")]^C^C^P(if(null B_TOLERANCE) (load "B_TOLERANCE")) (B_TOLERANCE) ^P
GMT+8, 2026-1-21 04:29 , Processed in 0.244906 second(s), 26 queries , Gzip On.
